Question about KitchenAid BCG100 Electric Blades Grinder
Kicthen Aid Coffee Grinder BCG100
This stopped working after 1 week. You are supposed to push down to engage the blades and now it is just stuck, it appears to be stuck in the "down" possession, but nothing happens. The blades turn freely as does the mechanism under the cup that turns the blades.
There are two small little guides and i am wondering if they are somehow jammed. I've brushed over them and blown on them to try and free any coffee dust.
No clue.
  • Anonymous Feb 28, 2009
    I have the exact same problem.
  • Geoff Ratte Sep 30, 2012
    I just figured it out. The plastic cover has a ring in the top which fits the stainless steel grinding cup. If grinds get caught in that little ring on top, then the cover won't have enough clearance to depress the switches. The answer is to take a knife and scrape the grinds out of that ring. It fixed my problem.
The two small little guides you refer to are a pair of switches that get depressed when the top is pressed down. In the top is supposed to be a plastic pin in the top of each one of the grooves. When both pins push both of the switches down (look like black dots) the grinder wil operate. The proper solution would be to replace the top.
Posted on Sep 06, 2009
Had same problem. You probably simply have coffee grounds stuck in the top of the cover so that the pins cant depress the switches. Try to push switches with pointed objects ic skewers at the same time. If the blades engage the switches are fine and simply not being depressed by the top
Posted on May 24, 2010
Coffee is getting stuck in the shoot between the grinder and basket so coffee is very weak
Try using a bottle brush and cleaning out the residue from coffee grinding. Coffee grinds build up because of the oils in the beans. I clean mine twice a week and it works great.
Mar 05, 2016 | Kenmore 12-Cup Coffee Grinder and Brewer,...
How long should i grind the beans?
The simple answer (and I'm not being obtuse) is, "as long as it takes." Many factors determine how long to grind for. The most irritant is "What kind of brewing method are you using?" If it's French press, ten seconds might be enough. For drip brewing using paper filters, 20 seconds is probably better. You probably would want to use a "burr grinder" for making espresso. In the end, it's really a matter of trial and error, so have some fun with it, and ultimately you will find what works best for you.
Sep 04, 2011 | KitchenAid BCG100 Electric Blades Grinder
Coffee grinder will not turn on
I recently had this same issue - it turned out that the lock switch no longer engaged because the spring came out of alignment after the unit was dropped. Chances are you have a similar issue. You can test this by using a small screwdriver to press down on the safely latch and then pressing the ON/OFF (careful of the blades!!). then you can easily fix it.
Dec 26, 2009 | Hamilton Beach 80355 Custom Grind Coffee...
Coffee basket
Called Cuisinart - they said to remove the basket ( I unplugged and then used pliers to move the blade/shaft up and down until it wiggled loose ) ... use soap and water to remove coffee oil (the real problem) and then pour a little vegetable oil into the female end where the motor engages the grinder blade to lubricate.
May 26, 2008 | Cuisinart DGB-300 Coffee Maker
Grinder blades dull
I may be having the same problem. My coffee grinder has had more leftover beans in it more and more this week, until finally today, possibly a quarter teaspoon passed through to the filter basket and the remaining beans were still very much beans. My first assumption was the blades.
Sep 24, 2007 | Cuisinart Thermal DGB-600 Grinder
KitchenAid BCG100 Electric Blades Grinder Logo
457 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
