Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Need to know where to set slave pin - Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
  • Seagate Master
  • 32,281 Answers
The pin settings are nest to the power connector.
If the location is not shown on the label then it will be marked on the circuit board.
MA = Master
SL = Slave
CS = Cable select
Posted on Sep 28, 2010
5 Suggested Answers
msuhelk
  • 106 Answers
SOURCE: slave pin settings
PLACETHE JUMPER IN THE MASTER AT FIRST POSITION AND REMOVE ALL JUMPERS FROM YOUR SLAVE DRIVE IT WILL BE DETECTED AS SLAVE... :-)
Posted on Apr 12, 2008
  • 9 Answers
SOURCE: need master slave configuration
First set the jumper pin for master or slave configuration as provided in the cover of the hard disk.
Posted on Mar 20, 2009
kirkx
  • 2019 Answers
SOURCE: need to know pin settings for slave mode
Look at the outside carefully. A drives have little pictures or something that tells what pins are for what. But if not, then look at the Western Digital site:
http://www.scsifaq.org/scsifaq.html
I can't tell you because they make 3 different configurations.
Posted on Jan 16, 2010
  • 2246 Answers
SOURCE: Need to know pin sitting
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=doc-lib&vgnextoid=ff7410ae61ba0210VgnVCM1000001a48090aRCRD
see this page
Posted on Jan 22, 2011
How to make IDE slave hard drive?
You can make it slave with jumper settings check in back side of harddrive you can see jumper which is connected to 2 pin of harddrive.
Read instruction on harddrive you can read how to set jumper for make it slave.
Then you ca use it as slave.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Need the switch setting for connection as slave
On the back of the drive is a set of six pins.
There will be writing above or below these pins it will be (cs),(sl)(ma).
There should be a cap on two of these pins make sure you put them on the two pins marked (sl) slave. If you are connecting this along with another
drive make sure the other drive is set to (ma) master.
May 12, 2010 | NEC ND 1100 (50022667) DVD+RW Burner
I need to know how to make model WD102AA-53ANA0 a slave. I am trying to move information on this hard drive.
Generally on a WD the center two pins is where the jumper goes for master with slave present. WD drives usually have it etched in the plastic SL, MA,CS.
Nov 30, 2009 | Computers & Internet
Setting Maxtor HD as Slave.
Howdy,
First "easy" one I've had in hours....
Just pull the J50 pin out of the jumper block and PRESTO it'll be a slave the OFF position literally reffers to having the J50 pin off of the hard drive. Just a note though, I highly recommend using a peice of scotch tape to affix the pin to a nearby surface cause there a real pain to find if and when you need em again.
Chris,
Armor-IT
Apr 23, 2009 | Maxtor DiamondMax 60 (33073U4) 30.7 GB...
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
Strapping or Jumpering for slave
You need the system info for the laptop you are using to see if a 2nd hdd needs to be set as slave or set in the cable select mode. Either right above the jumper pins or on the top of the hdd above the pins you should see 3 groups of 2 pins. They will be marked, ma, cs, & sl. They may not be in this order as each hdd manufacturer is different but all will have those 3 markings. If you set as slave cover the 2 jumper pins marked sl. For cable select cover the 2 pins marked cs. Hope this helps & please remember to rate my answer.
Jan 23, 2009 | Computers & Internet
Jumper setting
Put the jumper on J50(the closest set of pins to the IDE connector)
This will set the drive to master, with no pins on it's currently set to slave.
Chris
Oct 21, 2008 | Maxtor DiamondMax Plus 60 (5T040H4) 40.9...
Old maxtor harddrive
Most Maxtor Drives have jumper setting so that if "Jumper 50" is set; the two pins farthest from the power jack, is Master Drive. No pin jumper set, Slave or Cable Select. I hope this helps.
Aug 30, 2008 | Quantum Fireball Plus AS (QMP20000AS-A)...
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
51 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
