Question about Singer CE-100 Futura Computerized Sewing Machine
I have tried to load the software on my laptop (Vista) at least 5 times and I am still getting the communication error check USB connection. HELP... I would really like to use the machine but at this point looks like the only thing I will be using it for is to sew. I tried the patch too... and the number on the singer webpage does not work...
    Genius:
  • 1,788 Answers
Go to www.futura-support.com and they can help you. there may be a glitch in the software. Good lucl
Posted on Sep 28, 2010
  • Beth Millar Apr 24, 2011
    First, there's a Windows 7 update available at www.Futura-support.com. Click on the lefthand side, then on CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. First, be sure the uninstall ALL Futura software you've attempted to install and reboot your PC.
    If for some reason this doesn't solve you're problem, I've posted a set of instructions athttp://www.fixya.com/support/r8955271-us... that will allow you to run the software under XP on your Windows 7 machine. This is a bit more complicated a solution, but if you follow the instructions carefully, you should be fine. Try the Futura update first, though.
    Next,
    Make sure you're plugging the USB cable from the machine into a USB port in the BACK of your computer, not one of the front ports or a port on a USB hub. The cable and machine need more power than most of those ports provide, a technical detail that Singer doesn't realize. Good luck!
I have a memory craft 12000 and I have installed the software. When I try to send an embroidery design from my PC to the sewing machine I gat a communication error stating that I need to connect the usb...
Suggestion - Your usb cable need to be installed first and recognised by your pc as "your new hardware is ready to be used"
or if not, may need to reinstalled your software ensure your usb cable is connected as well.
Oct 30, 2013 | Janome Sewing Machines
I just got my Singer Futura Xl-400, I installed the CD yesterday. It asked me if I wanted to restart it so I clicked yes. Then I think my laptop crashed or something then it kept restarting itself. So I...
You did not indicate which operating system is used on your laptop. If you have Win Vista, 7, or 8, there is a patch that you can download from singerco.com, find your XL400, go to software and download the patch (should go to your download folder) . Next go to the Control Panel and uninstall the software. Re start your computer. Turn OFF your anti virus software and install the Base Singer software. Next, go to the download folder and double click on the Futura patch. Plug in your usb to the singer, then laptop, and turn on the sewing machine. At this point you can Launch the Futura software.
1. Turn on Computer
2. Plug in usb from XL 400
3. Turn on XL
4. Launch Software
Hope this helps - 8)
Oct 22, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
Futura software says machine isnt connected
Go to the Singer website and down load the driver for your machine.
Mar 30, 2013 | Singer CE-200 Quantum Futura Computerized...
I am running vista and I click on futura symbol and get a message connection error. Both the usb cable is connected and machine turned on.
I believe that you will need to update your software in order for it to work properly with Vista. The drivers for machine communication were probably for XP. They are available online. Look in you help section of the software for procedures for updating.
Dec 12, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer CE0100 Futura connection error....
Hi I had the same problem sent question to Singer and this was their reply
"Do you have Vista 32-bit or Vista 64-bits? Unfortunately the CE-100/200 machine will not be compatible with either Vista 64-bit systems or the newest Windows 7 computers. The CE-100/200 will only be compatible with Windows 98 through Vista 32-bit operating systems.
This appears to be a hardware issue and not something that we will be able to create a patch to correct. Drivers necessary for 64-bit operating systems are not compatible with the CE-100/200 machines." so I guess we are SOL
Sep 27, 2009 | Singer CE-100 Futura Computerized Sewing...
Can't get computer and embroidery machine to connect via USB. Computer doesn't recognize embroidery machine. (Husqvarna Designer Diamond) I also have a new DELL laptop.
If your using Windows Vista, you have to have the multi user account in the off postioin. Also if you had 3D embroidery software and you upgraded to 4D software you have to be sure to uninstall the 32 bit drivers from the 3d for the 4d to work properly.
You do have to install the communication software that came with the diamond also. It won't communicate through the 3d or 4d only.
Jul 12, 2009 | Husqvarna Sewing Machines
Singer Futura CE100 Connect Error. Check that USB cable is connected and power switch is turned on.
I received an email back from Singer stating that it is not possible at this time to load the Futura software on a 64-bit system using Vista. I have emailed to ask whether it would load if the OS were XP, but I haven't heard back yet.
They said that they were working on finding a fix for this, but they aren't sure that they will since it's a hardware problem.
Mar 02, 2009 | Singer CE-100 Futura Computerized Sewing...
Cannot install software for futura error message continues to say machine not turned on or not connected Despite installing patch to my vista
First check whether your Vista is 32bit, 64bit Vista is not supported yet. If Vista is 32bit and still software cannot communicate with the machine then probably you installed an update or patch for another Futura version. Write here machine model, software version (Help->About Futura) and additional options (Autopunch,Photostich etc) if you purchased any.
Oct 08, 2008 | Singer CE-200 Quantum Futura Computerized...
Vista unable to install Futura software
check for your disk size!
try to check also for the software properties labeled on the CD especially its memory and disk allocation requirements!
it may also need you to connect the machine to the computer first before installing its software!
Nov 15, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
