Question about AT&T Blackberry Curve 8300 Smartphone
Forgot password blackberry curve 8310
I forgot password. It is disabled now but if I want to enable it, I don't remember password to disable it when it asks for the password. HELP!!
  • 6 more comments
  • jermon Jun 26, 2008
    yes i forgot my password for my blackberry curve
  • nikhil_advi Aug 10, 2008
    yes
  • jmvd2 Aug 17, 2008
    i have had 9 attempts to logging in to my BB8310 with no success. Before I get locked out can I reset it somehow ?
  • Anonymous Feb 02, 2009
    forgot password
  • jencas Mar 20, 2009
    I have spent countless hours researching and my phone carrier claims that this is the utmost security feature so they couldn't help either. You would think that with the hundreds of questions asked they would be able to help in this area. There are actually two passwords for locking, one that you set up initially (called a passcode) when you first get your phone and one that you set through general settings/security. The one that you initially set up seems to be the one with the 10 attempts. I accidently clicked the side lock button while cleaning it and it started the 10 attempts. I kept putting in the same password in thinking it was the one I use daily... It wasn't, and if you don't write it down, your done. I have lost everything on mine because out of 20 phone calls and 8 visits to sprint, no one knew how to reset it, or would reset it. You can't backup though the blackberry desktop manager either because it asks for that last password. So, lesson learned... backup, backup, backup.. and it wouldn't hurt to keep your passwords listed somewhere other than your phone..
  • salih_m3 Mar 20, 2009
    i forget my password blackberry 8310
  • Anonymous Apr 02, 2009
    I see where it says Enable password, but don't know what the password is so afraid I won't be able to get in after I do this.
  • Anonymous Mar 22, 2014
    How do I retrieve my BlackBerry PlayBook I'D password or security question
I think all you can do it reset the device to disable the password completely. If you enter the password ten times incorrectly it will ask if you want to do a complete reset.
THIS WILL DELETE ALL YOUR PERSONAL DATA.
If you can, back up your device using the Blackberry Desktop Manager application before doing a reset. Then you can re-load all your personal data after the reset, instead of having to type it all in again.
Posted on May 28, 2008
  • maxine hart
    maxine hart Jan 03, 2014
    what is the desktop manager application
I forgot the password on my 8310,
Posted on Dec 19, 2008
    Sergeant:
    Champion:
  • 223 Answers
Okay, I just had this happen to me and here is what I did:
First, I tried loading everything onto my desktop manager, but it asks for your password too...obviously I wouldnt need to if I remembered my password!
So, okay, I took out my SIM card, put the battery back in and with it still hooked up, I entered the incorrect password the last time. Then a big hourglass showed up and the screen said please wait. It said that for a while and then returned to normal.
I put my SIM card back in and went to Options, Security, General and changed my password...very carefully, to something easy and disabled the lock. Then I backed everything up on the Blackberry Desktop Manager so if I somehow wipe it clean, I can reload everything from that.
If you don't have a card, I don't know what you can do, because if you enter your password incorrectly too many times (usually 10) it will erase all the data off the phone for security.
Posted on Jun 03, 2009
  • Nate-1965 Dec 15, 2010
    I did the same thing. I realized that the blackberry keys have a different upper and lower case than my computer key board. So I entered the password as i entered it on the blackberry. I looked at the lower case letters on the black berry key pad on the P.C. key board and that solved the problem. So if your password was 2654 you need to enter edfs on the computer keyboard but you must enter 2654 on the blackberry key pad. Good luck, I hope this works for you.
  • hulagan Apr 16, 2011
    Thanks this worked for me as I was able to figure out my password with the extra attempts and saved me hours of frustration. My problem was not being able to see the password I typed in when I set it so what I thought I typed was not what I actually typed. Thanks for the valuable assistance!
Dear Folks, I typed wrong password ten times and all the data is wiped and im not able to load the blackberry 8310 software again. Plz help me work on it
Posted on Oct 10, 2009
Livers210 - That's what he said it was going to do - erase everything. You should read the whole solution if you want to maintain your right to complain
Posted on May 08, 2009
I tried it and it erased EVERYTHING thanks a lot
Posted on Dec 17, 2008
    Genius:
  • 1,487 Answers
If you forgot your previous password, you can use a PUK code to unlock blackberry curve 8310 password, type any password until your phone asking you to enter puk code. PUK code can you found from your sim card bundle if you don't have it just call your service provider, they will give it to you. That code will make your blackberry unlocked from your previous password so you can setup new password for your phone.
Posted on Oct 28, 2011
Thanks
Posted on Jul 25, 2008
My black berry 8310 blue tooth and cam dont work could some 1 help me
Posted on Oct 13, 2009
2 Suggested Answers
statione1khi
  • 35 Answers
SOURCE: forgot password blackberry curve 8310
http://www.gsmliberty.net/shop/blackberry-curve-8310-unlocked-p-1533.html try this
Posted on Feb 06, 2009
I have blackberry 8300 /8310 it have prob is CAMERA DISABLED BY SYSTEM ADMINISTRATOR
You will need the system administrator to tenable it. Many businesses do not allow cameras in the workplace. So these profiles are set up to protect the business interests.
Dec 14, 2011 | RIM BlackBerry Curve 8310 Smartphone
I cannot enter the pin code to unlock the blackberry.
Don't worry, try this step to insert your Blackberry Curve 8310 Unlock Code :
1 - Switch on your Blackberry Curve 8310 without any Sim card,
2 - Go to Options,
3 - Select Advanced Options,
4 - Select SIM Card,
5 - Hold the ALT Key while typing in MEPE or MEPD or MEPPE or MEPPD ( not case sensitive ) ( you will not see text appear on screen while typing ),
6 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
7 - Your Blackberry Curve 8310 will now be unlocked.
If your phone still not unlocked, it means you have wrong blackberry unlock code. Don't try it again, and go to get new and correct unlock code.
Mar 07, 2011 | RIM BlackBerry Curve 8310 Smartphone
I have a BB curve 8310 and need a mep code for unlockit please send me...!!! please... thanksssss!!!!
If it is a network unlock code you need to contact you're service provider.
if it is a keypad unlock code kindly enter wrong password for 10 time's you're Handheld will get wiped off. Then it will ask for reset password, Enter the new password and remember that.
NOTE:- No data will be available when your Handheld is wiped off.
Nov 17, 2009 | RIM BlackBerry Pearl 8100
Can i reset forgotten password on BB curve if not enabled
Yes, but you would have to enter the wrong password 10x - Caution - this will wipe your BB of all saved data.
Or can contact your cell provider and see if they can reset your password if not and your BB is issued to you via your Company than you can have your BB Administrator reset your BB password.
Hope this helps.
Oct 25, 2009 | AT&T Blackberry Curve 8300 Smartphone
  • I've forgot my Blackberryid password
  • I can download apps anymore
  • And my screen keeps doing that
Feb 06, 2009 | RIM BlackBerry Curve 8310 Smartphone
I forgot my password on my 8310,
sorry that is not possible....you will need to reset it back to it's default and all data will be lost.
Dec 19, 2008 | AT&T Blackberry Curve 8300 Smartphone
BLACKBERRY 8310 CURVE
you need to enter the code incorrectly 10x for it to reset , this will blank all information.
Nov 07, 2008 | AT&T Blackberry Curve 8300 Smartphone
Deactivated camera - can i activate it
This has been disabled by what is known as an IT Policy. IT Policies are used to control certain functions of the BlackBerry when it is connected to a corporate BlackBerry Enterprise Server (BES). Once a function is disabled it is not possible to enable it.
Jul 18, 2008 | RIM BlackBerry Curve 8310 Smartphone
8310 blackberry
May 15, 2008 | AT&T Blackberry Curve 8300 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
44,672 people viewed this question
Top AT&T Computers & Internet Experts
Nataly Roberts
Nataly Roberts
castletech
castletech
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
