Question about Frigidaire Dishwashers
No water coming in to dishwasher- there is no valve other than HW valve and that is open- getting water to sink- seems to operate other than no water coming in. Thanks.
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 28, 2010
Water drains back into dishwasher from sink or disposal
You've got a broken piece of glass or something holding the drain valve open.
Solenoid operates the valve to drain water from dishwasher into drain line.
When power shuts off to solenoid...valve closes.
If valve is blocked by a piece of glass or toothpick or a sliver of bone...it can't close and draining water from disposal or sink can back flow into dishwasher.
I had a piece of glass caught in mine.
Hope this helps...
Jul 23, 2011 | GE Dishwashers
My dishwasher was working fine until yesterday, now it doesn't seem to use all the soap, I tried 2 times and there was still soap left over.
Hello there:
It doesn't get the dishes clean dot_lineone.gif 1. No water
Make sure you get water to the dishwasher. Check to see if the watershut-off valve (located under the sink) is open. If you get water tothe dishwasher, but there is still no water inside during the fillcycle, the problem might be with a faulty water valve (located at thebottom of the dishwasher, behind the kick panel, on either side), inwhich case replace the water valve. There are also screens and filters that need to be cleaned to ensure proper operation so please check these as well
2. Not enough water
If there is not enough water, the dishes would not get cleaned. Thiscould be caused by a partially closed water shut-off valve (locatedunder the sink), or a faulty dishwasher water valve (located at thebottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Makesure there is no debris blocking the holes inside each spray arm. thee are also screens and filters under these arms that may need toi be cleaned
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.if not increase the hot water heater temp
5. . Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside thedishwasher. Try cleaning you dishwasher using a dishwasher cleaner.There are a few out there, we recommend Dishwasher Magic®.
Jan 13, 2010 | Frigidaire 24 in. FDB126RB Built-in...
No water comes in my kitchenAid dishwasher
you only need prime to pump water out if you are not getting water to D/W it is most likely the water control valve
Oct 23, 2009 | Dishwashers
The first cycle water is not hot - all other cycles are hot - the water in the sink next to the dishwasher is not???
Where does the dishwasher connect to hot water? If it is connected to cold it must be changed. From your description, the water is coming from a long way off and has to warm the pipes as it travels to the dw. The dw should have a heater to bring the water up to temp after filling before it runs, if this heater is not working, the first run will be cold and the next hot because you have drawn enough water through the pipes to bring hot water to the dw.
1. Change where the dw gets hw.
2. Run hw in the sink before allowing the dw to start (if connected to same line).
3. Fix the dw's water heater.
Three possible fixes. Good luck.
Aug 27, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
My dishwasher doesn't seem to be getting water in hence dishes not being washed. motor is on. checkedunder sink . what does 'valve on' mean exactly? i don't see an on off valve. please help!
Follow the hot water fill pipe from where it connects to the dishwasher back to where it connects to the wall. (probably under the sink) Most of the time, you will find that pipe attaches to the same hot water (on/off) valve as the hot water side of the kitchen sink.
Confirm that valve is open (righty - tighty, lefty - loosy (open)) If the valve is open at the wall end then:
The next most common cause of no water entering the dishwasher is the solenoid valve on the dishwasher that is electronically opened when the dishwasher needs water to enter for wash or rinse. This valve is located just pass the connection where the fill pipe connects to the dishwasher and will have two wires connected to it.
Please post back here what you find or have more questions, OK?
Aug 10, 2009 | Dishwashers
I am getting an IE error on my control panel. It seems to start ok but once it starts to fill with water the IE error comes up and the machine shuts off. How can I fix this?
You do not list the manufacturer and model number, but it sounds like you own an LG dishwasher.
The IE error indicates that the water is not entering the dishwasher or it is entering too slowly / with little pressure. It is important to check the water inlet pipe (hot water connection under the sink) all the way to the dishwasher. Check for any kinks/blockages after you confirm that the valve at the sink is fully open.
Please report back here with what you find. If you still have problems, there are other things to check, including the solenoid valve just past the connection of the water inlet.
Aug 03, 2009 | LG Dishwashers
Dishwasher not filling
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 21, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Just a little water seems to be coming into the dishwasher and the dishes are not getting clean even on the Potscrubber cycle
Check the following to address this issue.
1. No water
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 06, 2009 | GE Dishwashers
Starts but no water enters
Jun 03, 2009 | Dishwashers
Dishes are not clean.. on top level the dishes seem to be steamy
1. No water
2. Not enough water
5. Not enough soap
Jan 30, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Dishwashers Logo
213 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
