Question about Sport & Outdoor - Others
Body sculpture bt 5800t manual i have a timer on my treadmill for 7 seconds n it stops after i have to press start to get it running again how can i fix it???
  • rahissa_786 Sep 30, 2010
    hey! iv tried what you have said but none of it is working. iv tried changing the settings but it just does not let me do anything when i press start it runs for 7 seconds and stops and then a error sign comes up i need a manual can u help me get one??
  • 2,299 Answers
Try unplugging the treadmill from the wall overnight. You can also try turning on the treadmill and then press and hold the power button for about 15 seconds. This should clear the memory.
Posted on Sep 28, 2010
My BT3152 treadmill has stopped working, the belt no longer moves
Is anything jamming the belt or motor drive pulley? Look carefully for anything that could be jamming it. If you suspect the motor could be bad, take it electrically out of the circuit and connect it directly to the your power supply, if it spins up you know its working, however, it could still be tripping off when under load.
Nov 09, 2014 | Body Sculpture Bt3152 Motorised Treadmill
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 09, 2013 | Horizon T203 Treadmill
Body sculpture BT5810 motorised treadmill. My treadmill switches on normally but after the 321 countdown to start error E1 is displayed and the belt does not move at all. Appreciate any advice you can...
see the step attached. clean the s. sensor , and diagram attached.
God bless you
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.afb1d921-a008-4e96-876a-cd31ffa20ecf.gif
Oct 31, 2013 | Body Sculpture Bt3152 Motorised Treadmill
Tc 3000 will run for 15 seconds and then shuts off with error 5-5
I have a body sculpture treadmill and experienced the same cut out every time switched on. One of the magnets had come out of the pulley wheel. Just glued it back and now it works fine. Hope you find this helpful Annie
Nov 06, 2012 | Bowflex Nice Tc3000 Treadclimber Bow Flex...
Body sculpture treadmill runs for 6 seconds then stops
1( LUBE the deck belt, this happen because the lack of maintenance
2( LUBE the rollers bearing too.
3( test the input voltage motor, if there are the motor need repair.see my personal TIPS
4( test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Oct 07, 2012 | Body Sculpture Bt3152 Motorised Treadmill
I need a user manual for a body sculpture bt-6200
go to next web:
www.fitness.manualsonline.com or www.iconservice.com
sincerely. God bless you
May 07, 2012 | Exercise & Fitness
Body sculpture BT2710 instructions
hi if you email body sculpture on sales@hi-markgroup.co.uk they will send you a free manual by pdf they are brilliant i know because i have used them for the same reason myself last week
Jules
Apr 08, 2009 | Exercise & Fitness
Sport & Outdoor - Others Logo
138 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
