Question about IBM Infoprint 1352 Laser Printer
What does 914 Service DC Pick Motor mean? - IBM Infoprint 1352 Laser Printer
  • 27 Answers
Printer Error Codes 910,911,912,913 and 914 are indications that a Tray 1 paper feed problem has been detected. It's what i found hope it helps
Posted on Sep 28, 2010
MX-780. Why can't I change channels?
Need assistance or have questions?
Our Customer Service Support Center is here to help.
Call (914) 835-4484 to speak with a customer service
representative or email us at techsupport@universalremote.com
500 Mamaroneck Avenue, Harrison, NY 10528
Phone: (914) 835-4484 Fax: (914) 835-4532
www.universalremote.com
http://www.universalremote.com/pdf/MX-780_Owners_Manual.pdf
Nov 25, 2015 | Televison & Video
Tip
ERROR codes Canon 6230
Canon 6230 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace. Same possibilities as E000 E003 Fuser temperature drops. Same as E003. E004 Fuser problem. AC driver, SSR bad, wire shorted. E010 Drive problem. Main motor, gears, etc. E030 Total counter. E064 Composite power board or DC controller. E065 Composite power board or DC controller. E202 Scan motor or scan sensor problem. Panel locked with no code. Scan motor problem. E203 Scan problem or scan sensor. E204 Scan problem or scan sensor. E210 Lens sensor or motor problem. E212 Lens sensor or motor problem. E220 Exposure lamp or exposure lamp regulator board. E224 Blanking shutter motor or sensor. E240 DC controller or composite power supply problem. E244 DC controller. E400 RDF to copier communication problem. E401 RDF Pickup motor or pick up sensor. E403 RDF feed motor or pulse sensor. E404 RDF delivery motion problem. E404 RDF delivery motor problem. E411 RDF tray sensor or registration sensor. E500 Sorter main board or communication with copier. E510 Sorter feed motor. E530 Sorter guide bar motor. E531 Sorter stapler motor. E540 Sorter bin shift motor. E541 Sorter bin motor. E550 Sorter power supply. E710 DC controllerE711 DC controller E712 Document feeder IC failure. E716 DC controller. Sorter. E800 Auto power off function (DC controller) E901 Pedistal motor. E902 Jogger side plate sensor or motor.
on Jan 19, 2010 | Office Equipment & Supplies
What does error code #e1 mean on Canon CLBP 460 PS mean?
Meaning of error code E1
The motor sensor or sensors, the DC controller on the main board DC controller.
I can not give solution to your problem, because possibility of damage main board.
I suggest you contact Canon Customer Support (e-mail, telephone, or repair contacts).
Nov 16, 2011 | Canon CLBP 460 PS Laser Printer
Cartridge stuck on the left. Tried methods in manual and failed. Both lights flashing together. The cartridge always travels to the left and stays there
Usually that means the service station drive motor is broken. Its a stepping motor, not a simple dc motor and unfortunately that means the printer needs to be replaced. replacements for that motor cannot be ordered. You need to salvage that motor from another printer.
Apr 19, 2011 | HP DeskJet 5550 InkJet Printer
PLAYS CD BUT NOT DVD
hi,
first of all check the spindle motor of ur dvd mechanism. if its winding or the brush short this problem can occur. when u insert a CD it rotates in a slow rpm, but DVD needs a high rpm. if the motor is short it will not rotate in high rpm, and will not read the dvd. normally there will be two types of motor uses as spindle motor. one is dc motor with two wire and the next one is servo motor with five or more connection.
the above mentioned problem will occur only in dc motor with two wire.
Also one another problem is the laser pick up unit. first check the motor, if it has no problem the go fo the laser pick up unit.
ok
Jan 09, 2011 | Samsung HT-SK5 System
Error message service dc pick motor on screen
Get new rollers.
They are held on with a little clip you push in and the wheel slides right off
Dec 27, 2009 | Lexmark T640 Laser Printer
Error code 000051
From service manual E051-0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
Main cause The horizontal home position sensor is faulty. The horizontal registration motor is faulty. The DC controller PCB is faulty.
Action
1. Connector
Are the connectors of the horizontal registration home position sensor and the horizontal registration motor connected?
a. DC controller PCB (J304) <-> relay connector <-> horizontal registration home position sensor
b. DC controller PCB (J304) <-> relay connector <-> horizontal registration motor
NO: Connect the connectors.
2. Sensor lever (damage and interference), Sensor
Is abnormal noise heard from the horizontal registration assembly in keeping with the motor rotation?
YES: a. The horizontal registration assembly is out of place because of
damage to the sensor lever. Replace the sensor lever.
b. The horizontal registration assembly malfunctions because of the
presence of foreign matter. Remove the foreign matter.
c. The sensor is faulty and cannot detect home position. Replace the
sensor.
3. Horizontal registration motor, DC controller PCB
Is the horizontal registration motor control signal generated by the DC controller PCB?
J304-1/2: 24 V, J304-3/4/5/6: motor excitation signal
YES: The horizontal registration motor is faulty. Replace the motor.
NO: Replace the DC controller PCB. Usually E 051 is the horizonal motor problem, you can take out the pick up ***'y. On the motor have a small gear, sometime this gear broken.
Or the horizontal reg motor became stuck in the wrong position. I was able to manually move it back and rebooted copier. Not sure why the motor was in the wrong position-cust related?
Oct 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Getting service code 914 on a IBM infoprint 1145
Service code 914 does not exist. If you meant 941, that is a tray 1 lift motor issue.
Jun 16, 2009 | IBM Infoprint 1145 Laser Printer
HP LASERJET 4 PRINTER
57 (or 57.1) SERVICE Message (Main Motor
Failure)
The 57 SERVICE indicates that the DC Controller PCA detected a
general motor failure. The Main Motor drives all moving
components in the printing process. The Main Motor is a 4-phase,
DC servo motor controlled by the DC Controller PCA.
The formatter detects a Main Motor failure when:
• The Main Motor does not come up to speed within one second
of receiving drive voltage.
• The Main Motor deviates from the correct speed for one second
after reaching the correct speed.
Main Motor Functional Checks
• Inspect the gear train for debris that would block the free
operation of the gears.
• Check the gears in the Toner Cartridge for wear and binding.
• Reseat J211 (or J214 on the HP LaserJet 4 Plus/4M Plus) on
the DC Controller PCA, and the main connector on the Main
Motor Assembly. Refer to Figures 7-16 and 7-17 for the DC
Controller PCA connector locations.
• If the problem persists, check that the +24B Voltage is present
on the DC Controller. If the voltage is not present, replace the
DC Controller. If the voltage is present, and the motor does
not rotate, replace the Main Motor Assembly
Nov 06, 2008 | HP LaserJet 4 plus Printer
IBM 1352
DC Pick motor error: No Encoder feedback. Try to remove all paper from tray 1 and replace it.
It basically means there is a tray1 paper feed problem.
Oct 14, 2008 | IBM Infoprint 1352 Laser Printer
IBM Infoprint 1352 Laser Printer Logo
2,099 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
