Question about HP Officejet Pro L7580 All-In-One InkJet Printer
I just hooked up a used L7580 Printer.I just replaced the black ink cartridge because it was empty. I am finding that with many of the documents I print, some of the letters or numbers are not printing. It seems to be a sporatic problem. Some documents print fine.
  • 240 Answers
Run print head cleaning cycles until the prints are correct.
Posted on Sep 28, 2010
Can i print documents using black ink only when other inks are empty?
All the ink cartridges need to have ink in them to allow you to print, even if you only want to print in black only.
Oct 14, 2012 | Epson Stylus CX8300 Printer
I am trying to scan a document, however the black ink is empty. It only shows the error message that I should refill my ink. Shouldn't I still be able to scan documents?
Must be using PG830 or PG40 50?
For Canon, if either color or black cartridge is empty or out of ink, "Scanner" doesn't work.
That's why your scanner is not properly working.
It's all connected... That's Canon.
Are you refill your cartridge by yourself?
Try "ROADINK" inkjet refill kit. No drill or sharp needles are needed.
It's not only easy to refill, you can have quality printing.
Check out my youtube video, will find how easy refill can be done.
Apr 20, 2011 | Canon MP490 InkJet Printer
Hello, I have an HP Officejet Pro L7580 All In One printer. Sat for 2 years. Barely used when purchased 3 yrs ago. Just hooked it up again. Replaced all ink cartridges...now prints are very pixelated and...
Try doing running it through it's aligment process.
It is also possible that the contacts where the ink cartridges mate up with the printer are corroded. Try using an eraser to clean the corrosion off the mating surface in the printer.
Jan 22, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Printer won't use the black ink cartridge.
when you print black document the printer should only withdraw black ink,or you have go back to computer to tellthem print black and white, How? when you click print the screen will show out printer setting box ,you can find the option over there.
Dec 09, 2008 | Lexmark X2600 InkJet Printer
Black Ink won't print
Try cleaning the printheads:
On the control panel press Setup>Select Tools>Select Clean Printhead
If that doesn't work, try manual cleaning the printhead contacts. This begins on page 147 of the User Guide.
L7580 User Guide
Nov 03, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Print cartridges
  1. When one or more ink cartridges are empty, for example, Black, the LCD shows “Ink Empty Black” and “Open Cover.” Close the printer’s document support and the document tray.
  2. Lift the top cover to the open position until it locks securely into place.
  3. Pull the ink cartridge hook toward the front of the printer and remove the color ink cartridge displayed on the LCD. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  4. Open the new ink cartridge bag for the color shown on the LCD and remove the new ink cartridge. The cartridge cover may come off when you open the bag. This is not uncommon and will not damage the cartridge.
  5. Each color has its own correct position that is clearly labeled and color coded inside the printer. Keep the ink cartridge in an upright position when you insert it into slot. It will only fit in the correct direction. Press down on the ink cartridge until the hook snaps over it.
  6. If you replaced an ink cartridge while “Near Empty” was displayed on the LCD, the LCD may ask you to verify that the replacement cartridge was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand-new one, select 2.
Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
Empty ink error message
Hi, its sad to say but the printer sounds that needed to be send to the nearest service center in your area. You already reseat & replace the ink cartridge and issue still present. Please call your printer manufacturer so that they can give you more options aside from sending it to service center. Thank you so much,
Tirzo
Jun 24, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printer claims black ink cartridge is empty, but it can't be.
Se if the tape, that comes with a new cartriage is of the cartriage if not try a new cartriage if the does not work your machine needs service
Jun 11, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
98 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
