Question about LG RU-42PX11 42 in. EDTV-Ready Plasma Television
How can I use my plasma tv as a monitor so I can connect my laptop computor
  • Rommel Cana
    Rommel Cana Sep 28, 2010
    you need to insure that your Computer Video Card have the updated Video Card drivers
    configure to use any or your LG RU42PX11 as your secondary monitor ,
    check for your
    computer Video Card documentations for more details ,
    Check for your laptop documentation for configuring a secondary monitor
    or post the laptop model and make to help you further
    and insure that you have the necessary cables for PC connection to TV
  • LG Master
  • 736 Answers
Assuming your laptop has an S Video output you would connect it to the S Video input of the television with an S video cable. Before doing so you should have turned the resolution on your laptop down as far as it will go. I believe the proper S Video resolution is 640 x 480. You can find an extensive resolutions list here http://en.wikipedia.org/wiki/List_of_common_resolutions
After setting the laptop at the resolution you're going to try you should turn it off (not restart it; actually turn it off). Now connect the S Video cable between the television and the laptop and turn the television on first before the laptop. Turn the laptop on and switch the television to the proper video input. Hold down the function (fn) button on the laptop and the dual monitor key (usually f5 or f8) for about 15 seconds or longer until you get an image on the television screen.
Posted on Sep 28, 2010
My acer laptop screen has broke and i would like to know if its possible to connect it up to my 42" samsung plasma ?
Most laptops have a 15pin D-sub connection that allows you to attach an external display. Most LCD and plasma TV's also have a 15pin D-sub connector to connect a PC to.
Look on the side of your laptop and the back of your TV for this connector and if both have it just find a standard monitor cable to connect them.
Your laptop will have a function key to enable or disable the external display.
Mar 18, 2013 | Televison & Video
I would like you to tell witch keys i should used to get hp pavilion dv9000 pc lobtop screen to display on a samsung plasma monitor
I'm assuming you are connecting the laptop to the plasma screen with an HDMI cable. If you have done so, then have both the TV and laptop turned on. Log into the laptop with an account. After you have logged in, you can press the function key (Fn) and usually its F4 (the key has a picture of a square, this represents the external display connection) at the same time. The plasma tv should display what is on the laptop.
So, Fn + F4 should work.
May 21, 2011 | HP Pavilion dv9000z Notebook
I connected my hp laptop to my pioneer plasma via svga cables. When i select my pc input using my tv remote it says "plasma display no input signal". How do I fix this?
Hello. You have to go into your Display Settings, in your HP Laptop, and chose the Dual Screen/Monitor Setting & make sure you check the "Extend my Windows Desktop onto this Monitor" Box. If you are trying to view your Internet Browser on your TV - you will need to Click on and Drag your Browser to the Right... of off your Laptop Screen and onto your TV Screen. This will take care of your problem!
Jan 11, 2010 | Pioneer PDP-5071HD 50 in. Plasma HDTV
Connecting asus M51V to Panasonic TH-42PX8A plasma via HDMI
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
Mar 14, 2009 | ASUS Computers & Internet
Can´t connect my laptop to tv monitor
Try lowering your screen resolution on the laptop first. (Right click on desktop > properties > settings tab > and move the bar to the left - try the lowest setting to start with
Jan 22, 2009 | Acer Aspire 4720 Notebook
I want to connect my Gateway(model No.:MA2) to samsung plasma tv
you could plug a video cable into the back of your laptop and turn it back on it should recognize your external monitor
Dec 21, 2008 | HP Compaq nx6115 Notebook
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
S cable to pioneers 43
there will be a hotkey to output video (ctrl+f 6 or ctrl+f4 or fn+f4) depending on the model of your laptop
also set the display properties to output video to tv or external device.
thanks get back to me if it dosent work.
Jul 20, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Connecting plasma tv to pc
You need to either connect to the TV the cord that your computer monitor would connect to or have a video card that supports S-Video and the appropriate cables S-Video and RCA audio out cables for either.
Then you must select the appropriate input on your TV, such as VGA or S-Video (and audio in.) .
Let us know how you make out.
Feb 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
Can not connect my MEDION 8828 MD computor via a HDMI cable to my SAMSUNG ps42q97 hdx 42
use a vga connector. this tv doesn't support pc mode on hdmi. don't forget the 3.5mm stereo jack out fron your sound card to the 3.5mm input(next to vga on tv). you will get 1024x768 res.
Dec 23, 2007 | Computers & Internet
Open Questions:
See all LG RU-42PX11 42 in. EDTV-Ready Plasma Television Questions
LG RU-42PX11 42 in. EDTV-Ready Plasma Television Logo
97 people viewed this question
Computer Repairing
Computer Repairing
