Static i am getting static through right side on both a and b speaker output
Before you buy anything, or spray anything, simply work the
controls. You may clear a dirty potentiometer or switch simply
by moving it several times. Consider that it may not have been
worked at all in many years on vintage equipment. You might
clear the dirt from a control simply by moving it.
If that doesn't work. ...
Go to an electronics store and get some "contact cleaner" or
similar, remove the equipment covers, spray the cleaner into the controls and switches. Work the controls and switches repeatedly, preferably before the solution has evaporated.
One of the common stores for such a cleaner in US is RadioShack.
Do not use solutions containing oil or solvents not made
for electronics. For example, do not use WD-40 or automotive
agents such as carburetor or brake cleaner.
Posted on May 26, 2008
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Checked both speakers..no matter which i connect to right output speaker terminal.get static.speakers r fine. system is ten years old.
Right output transistor is fried, replace . Take old ones (both left and right) to radio shack for new replacements.Replace BOTH
Dec 07, 2009 | Adcom GFA-5300 2-Channel Amplifier
I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Aug 27, 2009 | Audio Players & Recorders
Yamaha RX-V596 main rigth channel problem
The right or left (side) output channel has blown out. If it uses discrete transistors you'll have to replace two of them (one PNP and one NPN) along with several resistors that are part of the circuit (I'm guessing the static occurs on any input source).
Now , if the static happens only on certain input, then the problem should not be in your amp.
May 21, 2009 | Yamaha RX-V596 Receiver
Speakers work only on DVD
You might have connected your TV/Stereo Receiver up to the wrong audio outputs of the DVD player. Make sure you are coming out of the FRONT left/right audio outputs and not the CENTER?REAR left/right audio outputs.
Mar 13, 2009 | Panasonic SB-TP55 System
Static and popping from Harmon Kardon AVR 340
You seem have a problem with a component in that channel, the bad news is that it is hard to fix that type of problem (you would be better off if the channel died). All of the components in the final output section are part of the same audio loop (per channel), which makes it hard to find the faulty part.
Sounds to me like a bypass or coupling capacitor is faulty or need to be re-soldered, either way to fix this problem you should take it in to a repair shop.
I hope that helps and sorry for the bad news.
Jan 28, 2009 | Harman Kardon AVR 25 MKII
2004 Harley UC Radio - no sound on Left side
how about the antenna this could be the main problem im not a motorcycle expert but radios i do know and if your getting static the antenna which is called the aireal << spell check is not picking up enough signal
also head phones could be also a bad set
May 26, 2008 | Harley Davidson 426290 AM/FM Radio
Right rear speaker has static
Sounds like damaged channel in output circuitry. Take to pro/tech
Apr 12, 2008 | Sony STR-DG510 Receiver
51 people viewed this question
 Grubhead
Grubhead
