Question about ASUS Eee PC 900 Notebook
About a week ago I spilled some water on my ASUS U81A laptop keyboard. Put it upside down, turned it off, and took the battery out immediately. Opened up the keyboard to help it dry. Two days later I tried turning it on. It turned on and was on for a while, everything seemed to be working fine. But after I turned it off I couldn't turn it back on. The next day I was able to turn in on again, and this time instead of turning it off after I used it I put it in sleep mode and was able to turn it back on. But when I actually did turn the power off I couldn't turn it back on again. I haven't tried turning it on again for a few days now, in case I was somehow wearing something out. It doesn't seem short circuited and everything was working fine when it was on. Wondering what I should do
  • 2,567 Answers
You should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of water on the circuit boards & on other components. On circuit boards, water damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no water seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the water fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Posted on Sep 28, 2010
  • moscito Mar 30, 2011
    I had a similar problem and I don't know How do you dissamble the keyboard?
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Tip
How to fix a laptop keyboard if you spill something on it
Okay, I will now try to explain how to fix a laptop keyboard if you spill something on it (juice, coffe,.....). Problems caused by this are sticky keys, some keys don't work,.....
First of all, don't panic! Turn off your computer immediately, and pull the battery out. Unscrew a couple of screws that are holding the keyboard, and remove carefully keybord out of a laptop. Removing the keyboard can be different, depending on the laptop model. When you remove keyboard, fill a bowl with a fresh water with a few drops of a mild detergent for washing the dishes (3-5 drops per 1 liter of water). Bowl should be bigger than the keyboard, so you can submerge keybord in water. When you submerge the keyboard, gently press all the buttons with your palm, doing this you allow water to enter inside and clean the keyboard from inside. After pressing buttons for about 10 minutes, change the water for a fresh one, this time clean water, without the detergent. Do this with just clean water 2-3 times, and when you finish, shower the keyboard, just to make sure it is washed properly and the detergent is gone. DON'T USE THE HAIR DRYER TO DRY THE KEYBOARD, AND DON'T PUT IT ON DIRECT SUN. Turn the keyboard upside down and put it on a towel and let it dry. It should be dry in about 6-8 days on a room temperature, so be patient. DON'T EVER wash the keyboard with alcohol or something like that.
This is very good way to fix the keyboard, i solved a great number of keyboards using this method.
on May 23, 2011 | Computers & Internet
Spilled water on my asus laptop
Maybe or maybe not.They can not be opened.
Oct 23, 2012 | ASUS Computers & Internet
Keyboard inserts backslashes when I type
Unless you're fairly technically adept and mechanically inclined, the easiest fix is to replace the keyboard. They aren't that hard to find and aren't all that expensive.
If you don't have a clue how to do this, then your best bet is to send it to a professional that will source out the cheapest replacement keyboard and offers inexpensive international shipping like SuperTech-IT.com
Jun 09, 2012 | Lenovo IdeaPad Z560 Notebook
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
I spilled water on my keyboard last night. Immediately i turned my asus u81a laptop upside down to keep water from seeping under the keys and turned it off. I then removed the battery and let it dry upside...
bad news... you can try and dry it some more in warm and dry condition more another day or two... open up whatever compartment you can and see if there's any moisture... Gently blow dry (not to close) and try again. with todays laptop price, it may not be worth to repair.. probably your hard drive is safe though. worst case: salvage the hard drive and transfer the data - you can event turn it into a portable drive.
Sep 22, 2010 | Computers & Internet
I spilled a glass of water on my asus notebook fv6 series. I took the back cover off and removed as much water as i could. then use a blow drier on low heat, and let it sit upside down for acouple...
Try going to the Asus Support Website and find your model's webpage. You can download the Manuals from there.
Good Luck & Please rate my solution, ok? Thanks.. Lucky4lynn2 :)
Apr 21, 2010 | ASUS F6 Series F6V-A1 NoteBook Intel Core...
I spilled a small amount of coffee onto the keyboard while the computer was in use. I immediately turned it upside down and dried it off. I cannot get it to power " on"
Don't power it on. If that is doesn't seem kind of all water proof kind. Take out the battery and the AC power supply. Turn the laptop upside down without closing the screen monitor and let the coffee be out. Dry it/or take it on a reputable shop( I may suggest).
Have it clean. Hope it doesn't fry something inside.
Sep 21, 2009 | Lenovo ThinkPad T400 - Intel Centrino 2...
Keyboard not responding after food spill and clean up
what type of food spill and how did you clean it affects the keyboard. What type of keyboard is it? Is a separate keyboard like for a desktop or is it on a laptop? for desktops, quickly turn the keyboard upside down to prevent fluids going further into the keys. After food spill, use a can of 'air'. Use short blasts to help blow out and dry any moisture out-at the same time, be sure to have the keyboard with keys facing down. for laptops, almost same-turn entire laptop upside down to allow fluids to escape. Be careful not to let the fluids come in contact with screen. Hope you have done some of this. If it doesnt work, you may need to replace the desktop keyboard and for laptops-take to repair shop for internal cleaning. Hope this helps
Aug 24, 2009 | ASUS Computers & Internet
My kids spilled juice on my laptop and i need figure out how to
With my keyboard, I use a damp cloth with glass cleaner on it and wipe it off that way nice and gently, be sure your laptop is off when you do this, does a good job and makes it look like new again. Hopefully the kids didn't damage the keyboard.
Feb 21, 2009 | HP Pavilion G60-120US NoteBook
ASUS Eee PC 900 Notebook Logo
641 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
