Question about Refrigerators
We want replacement of new defective refrigeretor pls tell me procedure
  • 3,740 Answers
You make a warranty claim for repair via the manufacturers website first. They attempt repairs and if it can not be repaired it is replaced with an exact or equal or model. Since you did not mention make or model number I can not help you with what website to make your claim on. The warranty information should be with the Owners / user's manual your NEW refrigerator. It states exactly what to do for a warranty claim. You will need make, model date of purchase and installer information when you make your claim. Possibly even the purchase price. If it has not worked since the day of delivery you can go back to the retailer that sold it to you and demand they take it back and replace it. They may push for warranty repairs but I can tell you from personal experience any reputable retailer will work closely with you to resolve the problem on a NEW unit.
Thanks for choosing FixYa.
Kelly
Posted on Sep 28, 2010
My refrigerator is not making ice and the control pad displays Er IF when i cut the power and put it again there is a small explotion in the dispenser.
HI,REPLACE THE ICE MAKER BLOWER MOTOR AND THE MAIN CONTROL BOARD,CHECK THE DISP IF THE EXPLOTION DAMAGE ANY PART..I ASUME THAT YOU OWN A LG OR SUNSUNG REFRIGERETOR WITH FRANCH DOORS..
Jul 05, 2011 | Refrigerators
Como soluciono el error 7000 que me sale en la kyocera
Code 7000
Contents: Toner motor lock error A motor over-current signal is detected
continuously for 5 seconds since the toner motor is activated.
Causes: Lump of toner inside toner container.
Check procedures/corrective measures: Replace the toner container.
Causes: Defective toner replenishment drive system.
Check procedures/corrective measures: Replace the developer unit
Causes: Defective toner motor.
Causes: Defective engine PWB.
Check procedures/corrective measures: Replace the engine PWB
Jan 21, 2011 | Kyocera FS-2000D Laser Printer
Pls tell me how to remove the keyboard of compaq nc6220 laptop
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00622160/c00622160.pdf
CHECK THIS ... EXPAND REMOVAL AND REPLACEMENT PROCEDURES AND 6.9 KEYBOARD ... IT WILL GIVE YOU STEP BY STEP PROCEDURE AS IN HOW TO DO THE JOB.. GOOD LUCK
Jan 27, 2010 | HP Compaq nc6220 Notebook
Rebooting my lenovo pc
push power button or click on apple logo on left side corner then go down click on restart. is it helpful plz rate this..
Mar 10, 2009 | Computers & Internet
Ford Escort 1.6 ztech 16 valve
Based on your description, the engine would have a defective injector (always open) on the no 1 cylinder.moz-screenshot-1.jpg It would look something like this image 1d0ec93.jpg. In some instances, it could be the electronic box/computer that controls the opening and closing of these injector valves that may be at fault. The normal procedure calls for replacement and it wold be to your advantage to replace all not only the defective one should that be determined to be at fault.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 16, 2008 | 2003 Ford Escort
Sony tv no picture only horizontal line
The probable defective part is the vertical IC. If changing that does not resolve the problem, check the capacitors in the same circuit. Also, check for the proper voltages at the vertical IC. If the IC is not being fed its power, it won't work either. I don't have a listing for your specific model. If you can post the vertical IC part number (LA7837 for example), I can list the voltages per pin.
Dan
Apr 09, 2008 | Televison & Video
My apex pf2725 tv screen is green
Your posted/describe symptom seems to be that the green color drive is defective. The "lines going across" are flyback retrace lines brought about by the safe problem.
The corrective procedure would be to replace. In most TV units, color drive are three (3) identical transistors: for the blue, green and red. They are normally located at a small squarish PCB attached to pins of the CRT right at the rear end of the neck. More often, they are heatsinked. Repair should be a straightforward desoldering the defective component and replacing with a new one.
In some versions, color drive is a single IC power pack.
Still, it is also possible that the problem may be due to cold solder on any or all of the pins of the above describe transistor (or IC).
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Feb 05, 2008 | Apex Digital PF2725 27" TV
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
