Question about Brother HL-2040 Laser Printer
Paper tray problems
The printer doesn't pick up the paper from the feed tray. I have to manually place the paper on that outer slot for the paper feed and print.
  • kirbear2 Dec 01, 2008
    I have the same problem but my paper wont even go through the manual feed.
  • Anonymous Dec 06, 2008
    I have the same problem, it will not pick up the paper in the feed tray. It will go through the manual feed but when I want to print 50 copies of something that becomes very frustrating. I looked in the instructions on how to load the paper like this solution suggests and I was doing everything right and still does not work.
    Problem Solver:
  • 18 Answers
If you take your paper tray out and remove your drum unit, out the machine on its bum, so to speak, and it should sit nicely. If u look at the belly of the machine there should be a little grey roller just at the top, if you get some soapy water on an old rag and give it a wipe. Then if you look at the paper tray there is a grey pad give that a wipe as well and then wipe off all the excess water and try to feed from it again.
Good Luck
Posted on Dec 09, 2008
    Problem Solver:
  • 5 Answers
Re-Read the install data that came with the printer as to filling and inserting the paper tray
Posted on Jun 04, 2008
Our infoprint 1125 is on a ibm mid range computer system & is accessible to 9 users. when we print an envelope, the printer asks for a manual load of the envelope, how do i change this to automatic...
It's been my experience with these machines that envelopes are always fed through the manual feed tray.
The Tray 2 cassette's pick up assembly is different than the manual feed,
it has 2 rollers that have a wide area they can pick up while the manual feed has just 1 single roller.
If you remove the tray cassette and look under the printer you can see the two rollers, these would probably have a hard time picking up a standard size envelope.
Also the tray would have to path the paper up and would have to bend it through the paper path which can cause problems with the flaps on the envelopes.
Best method is to use the manual feed tray and to also have the back cover open so that the envelopes path straight through the printer without being curled.
(I've seen these in a ton of places ranging from small business to banks and they always have the envelopes in the manual feed)
Jun 08, 2011 | IBM Infoprint 1125 Laser Printer
I cannot get the paper to load into the printer
I had an issue with the cassette tray paper feed. I loaded paper in the rear tray, manually used the printer properties button to make it print from the rear tray and printed from there. The next day I manually did the same thing but forced it to print from the cassette (bottom) tray. It worked fine today. It no longer thinks that there is no paper and the rollers are picking up the paper edge for proper feeding of the paper. I did not go through the roller cleaning procedure but I would do that if switching back and forth manually between trays doesn't work.
Sep 20, 2010 | Canon MP560 All-In-One InkJet Printer
Printer is saying manual feed insert paper. Will not print
To load paper or other media in the Manual Feed Slot (directly above the Paper Tray)
You can load envelopes and special print media one at a time into this slot. Use the manual feed slot to print or copy on labels, envelopes or thicker paper.
1. Slide the paper guides to fit the paper size.
2. Using both hands put one sheet of paper in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the machine feed the paper in a short distance.
Note: When you put paper in the manual feed slot, please remember the following:
■ The side to be printed on must be face up.
■ Put the leading edge (top of the paper) in first and push it gently into the slot.
■ Make sure that the paper is straight and in the proper position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
■ Do not put more than one sheet or envelope in the manual feed slot at a time or you may cause the machine to jam.
■ You can remove smaller sizes of printed paper from the output paper tray more easily if you lift the scanner cover using both hands as shown in the illustration.
You can still use the machine when the scanner cover is raised. You can return the scanner cover to its home position by pushing it down with both hands.
If you would like to disable Manual Feed Mode, check that the manual feed mode is not selected in the printer driver.
Here is a copy of the User's Manual for the Brother MFC-7820N.
Jul 07, 2010 | Brother MFC-7820N Laser Printer
Does not print says manual paper feed
Try putting a piece of paper in the manual feed tray which is right above the paper tray, its a slot you have to flip open, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Jun 15, 2010 | Brother MFC-7340 All-In-One Laser Printer
Printer will not pick paper
As a test, please try to print something using paper in the manual feed bin.
If that works, remove the tray, take all the paper out, verify the springs on the tray are working again then reinsert the paper and tray and try again.
Thank you.
Oct 04, 2009 | HP LaserJet 1320 Printer
Keeps telling me to fill paper in manual feed -- I need to type an envelope. Where is the manual feed?
Hello there, ocon7954.
The manual feed tray is actually right in the front of the printer. It is that slot in between the two blueish sliders above the main paper tray in the exact middle of the door.
Since it kinda blends into the front, a lot of people miss it.
All you have to do to use this tray is to place the paper into it, then the machine will "grab" it and prepare it to be fed.
Good luck solving your problem. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Manual feed pickup
replaced the manual feed tray separation pad (it is right under the pick-up roller). The HP part # is RG5-2703. First remove the pickup roller then you can pops it out with a small straight slot screw driver.
Jan 23, 2009 | HP LaserJet 8150n Printer
Paper feed
Check tray 1 there should be an arm hanging down in the center of the tray the arm goes thru a slot in the metal plate. This arm moves when you install paper in tray 1. If the arm is missing or not in the slot the machine will think paper is in tray 1 and try to feed from tray 1. You can try changing the paper size setting for tray one to something other than the size in tray 2.
For example If tray 2 is set for 8.5x11 set tray 1 for legal.
The machine should then pull the correct size based on the print job.
Hope this helps
Jan 21, 2009 | HP LaserJet 5si Printer
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Brother HL-2040 Laser Printer Logo
335 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
