Question about Microwave Ovens
Cooker is not working checked fuse and plug socket was working then just stopped
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 28, 2010
Has stopped working. light gone off at same time. plug fuse has not broke. any ideas ?
There is a fuse inside the microwave also.It is a ceramic fuse,usually 15A.It has to be replaced with another ceramic fuse of the same rating.Bear in mind,the fuse blew for a reason,so if it is the interior fuse replace it after a search for a fault.
Dec 17, 2014 | Microwave Ovens
Everything went out
you blew a circuit breaker...find fuse panel and reset breaker. It will be the one that is tripped
Apr 05, 2014 | Maytag MMV5207BAW Microwave Oven
How to fix mircowave
Other then checking the plug and wall socket...Have you checked the fuse? It's inside under the vent panel. Most hardware stores carry common fuses.
Mar 20, 2014 | GE JVM1190 Microwave Oven
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
Emerson microwave 1100 watt microwave keeps running even when timer stops bought about 7 months ago
the problem of this unit is power related.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Oct 18, 2011 | Emerson MW8168B Microwave Oven
My cooker has just stopped working, half way through cooking my roast dinner? any reason for this?
You may have blowen the fuse link on power board. Because of electric compents could cause bad shock. I suggest a tech to repair. If it is a fuse it should not be expencive. I hope this helps.
Sep 11, 2011 | Microwave Ovens
I had bought the electric pressure cooker 2 months ago and was working fantastic, suddenly it stopped working this week and there is no power light even coming up - PLEASE help
Probably the main wire is faulty or the fuse has blown out.open the cooker from below
{find,check the fuse with a continuity tester}do check the main wire with the help of a continuity tester too for any kind of breakage.If there is no continuity or the tester bulb does not light up there is a fault with the component.Replace the wire/Fuse with the same rating or quality and your cooker will surely work
Dec 04, 2010 | Microwave Ovens
Gas cooker elc starter not working , iv have all ready change fuse in plug.
it could be the coil in the spark ignighter,,,or dirty spark plugs!
grease can get into the switch as well
Aug 30, 2010 | Microwave Ovens
Everything quit working no power anywhere
Have you checked the fuse in the plug? Also there is an internal fuse that you have to remove the outer casing to get at. Please make sure the power is off and the plug is removed from wall socket before you start and do not power up until the casing is back on. Hope this helps.
May 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Russell hobs microwave oven
I am a recently retired appliance engineer of 20 years, microwaves are not normally things worked on yourself, i would be reluctant to help normally but yes there is an internal fuse ( a special quick blow type )just inside where the wire enters the cabinet on a small circuit board, if a replacement is needed it must be exact match bought from an electronic shop, microwaves are dangerous they store powerful electric and can still shock after removing the plug, if the replacement fuse blows, there is a fault elsewhere, and i do not recommend further self repair, work with safety
Sep 09, 2007 | Microwave Ovens
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
