Question about Dryers
I have a sears kenmore gas dryer model 87592820 it keeps blowing the breaker. It was running about 1 min. then a spark flew out and it tripped the breaker. When I reset the breaker it continues to trip it. The electrical socket that it was plugged into is working.
  • Dryers Master
  • 43,501 Answers
This sounds like you have a wire that rubbed through and is shorting out...
open up the back or where you saw the sparks come from and you will easily see the burnt mark...then you can fix it...
Do not keep trying the breaker... it is tripping to protect you and keep you safe.
heatman101
Posted on Sep 28, 2010
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
GE dryer will not start the push button was messed up and when i was fixing it sparks flew and now it wont come on
Check the breaker panel and make sure you did not trip the breaker to the dryer.
Jan 21, 2013 | Dryers
The dryer will not heat up
Instructions
    • 1 Check the cycle selector control to make sure a heating cycle has been selected. The selector should be in an "Off" position when not in use, but it should be turned to a drying cycle when in use. On some models, make sure you are not accidentally running the dryer on the "Air" cycle, which does not use heat.
    • 2 Check the gas supply valve to make sure it is open if your dryer is a gas dryer. If it is not open, just lift the valve open.
    • 3 Look at your house's main breaker box to determine whether a circuit breaker is tripped. The electric dryer runs on 220-240 volts and has a double breaker. If the breaker for the heating element is tripped, the drum may tumble the clothes without heat. Turn the dryer's breakers to off, then back on; test whether the dryer will produce heat.
    • 4 Consult a technician if troubleshooting does not resolve the problem.
Jan 15, 2013 | Kenmore Dryers
Kenmore elite dryer runs for about 3 min. then trips the breakers
The circuit breaker may be tripping because of a fault with the dryer or it may be a fault with the circuit breaker being weak.
From the description you give the circuit breakers trip frequently.
I'd suggest you first try selecting the no heat air fluff cycle and run it to see if the breaker trips. If the circuit breaker doesn't trip in air fluff then there is likely a short in the heating element.
With a clamp-on amp meter you can read the amp draw of the dryer when it is heating. With the motor and element both working you would see approximately 25-26 amperes being drawn. The breaker is rated at 30 amps. If the breaker trips and only 26 amps are being drawn then the breaker is the problem.
Try the air fluff cycle first and see if the breaker will trip. Then with additional details I may be able to help you further.
Jan 05, 2011 | Kenmore Dryers
Dryer has lost heat.
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Dec 11, 2010 | Kenmore 700 6972 Dryer
My kenmore dryer runs but not drying and no heat.plz let me know waht i should do?
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore 63942 Dryer
Kenmore 80 series dryer does not hest
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore Dryers
Dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
Our kenmore 697267 keeps tripping it's circuit every 5 minutes or so... what's the problem with it? Is it dangerous to just keep resetting it?
definatly a prob if tripping breaker every5 miin, resetting breaker is not good for either the breaker nor hte dryer, that would be hard to determine why without actually looking at though, i would probably calll someone to have a look at that one
May 02, 2008 | Kenmore 73952 Gas Dryer
Dryer will run about 5 mins. then trips the circuit breaker.
I would change the breaker frist and see if that sovles the problem
Oct 14, 2007 | Kenmore 62602 Electric Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
