Question about Panasonic Televison & Video
I have a panasonic viera th 42px600a and cannot turn it on. It seems to be stuck on standby? Any ideas?
tvhelp-Dave
  • 178 Answers
SOURCE: Panasonic Viera TH-50PX60U Plasma is stuck on one
Forced to factory default: press and hold [VOLUME ( - )] on the TV and press [MENU] on the remote 2 seconds. Exit: Unplug Power to reset.
If it does not help, the main board need to replace. For further questions, please add your comment.
Posted on May 20, 2010
Testimonial: "Thanks TV Help-Dave! Your solution was right on the money. Speaking of money....This site just saved me a $79 service fee. Great idea for a website!!"
Kimi
  • 277 Answers
SOURCE: Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Posted on Oct 21, 2005
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
hi there, have the same kind of problem twice so far after was bought for me as x-mas present (although my viera isnt plasma, its an LCD TX-32LMD70A)..
I Pulled out the mains plug for about 10-20 seconds and then plugged back in (power button at top was pushed in, in the on position, so when the power was on, the tv just goes straight on). It then worked.
i would however like to know why this happens ( i really hope this isnt a hardware problem, as like many others... its only months old!!)
hope this helps
Posted on Apr 27, 2008
  • 4234 Answers
SOURCE: Panasonic Viera TH-37PX8B Green Screen When Turn On DVD Player
This sounds to me like you have connected a "composite" signal to a "component" input, specifically the green input. Make sure that you have the correct cable. A composite cable will contain only 1 video cable (yellow). The component one will have 3 for video (green,red, blue).
Dan
Posted on Jun 10, 2008
rockitman187
  • 2559 Answers
SOURCE: Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
Posted on Jul 29, 2009
My Viera TV: TH-P42ST30z seems to have shut down. When I turn it on the pilot light initially flashes green then starts a sequence of 7 red flashes, a gap, 7 more red flashes and this continues indefi
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 09, 2014 | Panasonic Televison & Video
12 blinks on th-p42x20m
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Apr 13, 2014 | Panasonic Viera TH-50PZ85U Plasma TV
Pls tell me the watt for tv model th-65 pv 500m
The closest thing I can find to your plasma TV is the Viera 65-in model TX-P65VT20E, which consumes 635 Watts. This should be close to the power budget for your unit.
Reference:
http://panasonic.net/avc/viera/eu2010/product/vt20_plasma_spec.html
Sep 13, 2011 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Jul 25, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Panasonic Viera TH-42PV60H displays vertical lines on left side of screen.\r\nThese lines flickers and changes colors. Initially was about 2cm wide and now it is about 4cm.
Either LCD transistor got moist or the video chipset got condensation. Keep TV on standby to dry it out. Unless there is also mechanical damage to the lcd screen on the edge..
Dec 15, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic Viera TH-50PX60U Plasma is stuck on one channel. Only the power function works on the remote and only the On/Off function works on the TV. Any ideas??
May 20, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera
vga board is bad ot the components on it are blown out.
May 08, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Oct 21, 2005 | Panasonic TH-50PV30 50 in. Plasma...
Televison & Video Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
