Question about Nokia 2630 Cell Phone (Unlocked) - Black
Lcd backlight not working - Nokia 2630 Cell Phone (Unlocked) - Black
    Sergeant:
  • 194 Answers
Your phone settings may changed .Try with restore factory settings in your phone.If its not work check manually your dispaly settings.Otherwise you have to contact a service center to change it
Posted on Sep 28, 2010
How do I repair backlight?
Repair: LCD Monitor Backlight - YouTube
? 6:06
https://www.youtube.com/watch?v=BTjH-jkuo9Y
Jan 30, 2014 - Uploaded by Heilman Hackatronics
This videos shows how to repair an LCD monitor Backlight. ... I've Samsung SA300 21.5 inch led monitor ...
How To Replace a LCD Backlight - Instructables
www.instructables.com/id/How-To-Replace-a-LCD-Backlight/
InstructablesHere are some simple instructions on how to replace a burnt out LCD backlight with a new working one to bring your LCD back to life. ... To get the the LCD screen and thebacklight inside, you must first disassemble the LCD housing; this is different depending on whether it is an ...
A (very) Simple LCD Backlight Fix - Instructables
www.instructables.com/id/A-very-Simple-LCD-Backlight-Fix/
InstructablesFix any broken LCD backlight with an ordinary light bulb and a dead CRT monitor.Broken LCD monitors basically come in three categories:1) Cracked LCD ...
Dec 30, 2015 | Samsung Televison & Video
Command lcd backlight
The LCD backlighting is LEDS and.they are integrated.. unless you have some good electronics knowledge replacing them will be next to impossible.. the only other way is to replace the entire unit either from the dealer or a savage yard.. good luck
Dec 18, 2013 | Mercedes-Benz C-Class Cars & Trucks
Samsung LCD TV backlight switched off
Most likely you will need to get a diagnoses done on the set. It could be a faulty 24vdc circuit (power supply capacitors), defective inverter, or a failing CCFL backlamp.
Oct 28, 2012 | Samsung LE-46A566 46 in. LCD TV
if your TV is LCD or LED you have a faulty inverter board just replace it and your TV works fine again..
If plasma you have faulty y-sustain.
Hope it helps,,don't forget to rate and write a testimonial
Oct 28, 2012 | Televison & Video
Sony cyber shot dsc-t10 backlight not working
Yes, the backlight is a separate part. It can be removed from the LCD and replaced.
The following video shows how to replace the backlight in a Sony camera.
http://www.desmontalo.com/?p=275
Apr 01, 2012 | Sony Cyber-shot DSC-T10 Digital Camera
Sound but no picture, has worked for 4 years and went black. Cycling power displays video for a half second then goes black again.
LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get the picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Feb 28, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Bush TV LCD 32 TV 005 HD
The black screen problem of your TV can be attributed to a backlight driver failure, busted backlight, or LCD driver failure.
The flickering indicates a failing backlight driver or a failing backlight. The screen should be totally black, without any glow, when either of them is not working. To verify, grab a torch and shine it on the screen. You will be able to see a faint display telling you that the backlight is busted or the backlight driver is faulty. If not, the LCD driver or the LCD panel itself is faulty, although it has a low probability due to the symptoms of the problem. The only way to fix the problem is replacement of the faulty part. You may need the service of a qualified technician to determine exactly which one is the root of the problem that needs replacement.
Dec 07, 2009 | Televison & Video
Sidekick III 3 LCD Backlight stopped working sometimes
yes you need to replaced the LCD to make it work again.
Jun 03, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Video shows up momentarily then disappears audio works fine westinghouse flat panel
This is a backlight or inverter (power supply for backlight) failure.
These parts may be availble. The backlights are difficult to replace. If not careful, you will break the LCD Material of the LCD Panel when replacing backlights
May 04, 2009 | Westinghouse SK-32H240S Television
Backlight on the screen not working
there is dim light on the screne
Nov 12, 2008 | Nokia N95 Cellular Phone
Nokia 2630 Cell Phone (Unlocked) - Black Logo
98 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
