Question about Lutron GRX-PCBL-346S-500 Grafik Eye Low-voltage Plenum Rated Cable
When adjusting the dimmer setting for the top button, 5 of our 14 lights went out and will not go on no matter the setting. Is there any solution to this?
  • 12,061 Answers
Whenever this happens usually we have found it is the actual Dimmer unit itself, that faults, this needs to be replaced to return full function to your light system.
Posted on Sep 30, 2010
How do I repair the backlighting on a Hitachi LE49A509 TV?
A LED is a diode if one shorts the entire set goes out or on some sets there are 2 supply lines and one the top half may light and the bottom be dark or other way around
Oct 27, 2017 | Hitachi Televison & Video
96 Lincoln towncar raido buttons have back light but do not work also the display on raido stoped working and no sound
  1. Press and hold the OFF button for a few seconds. NOTE: On some models, this will toggle the display on and off.
  2. Check to see if your car stereo has a dimmer setting, which can disable the display. If the car audio system does have this setting, try adjusting it to the different dimmer settings. Sometimes the dimmer setting is on the left side of the steering wheel where the lights are.
May 27, 2016 | 1996 Lincoln Town Car
MY CADILLAC DEVILLE DASH LIGHTS WENT OUT, CAN'T TELL HOW FAST IM GOING OR HOW MUCH GAS I HAVE
Has the light been going to out slowly or happened all at once?
Have you turned the Dimmer all the way off or did you blow a fuse?
There is a Wheel or know that you can adjust the Dimmer on the Gauges, check and see if someone accicently turned it all the way off..
Apr 07, 2013 | 1997 Cadillac DeVille
How do i increase the back light. IT has gone dimmer while setting clock
Press the snooze button 4 times. The display toggles between lo/high brightness. ;-).
Mar 31, 2012 | Sony ICFC218 Clock Radio
I have an older Lutron system - the Maestro Wireless MRF-VCTX-WH. I can't find instructions to reconnect one dimmer. The only instructions online that I can find are for the Pico, and that process doesn't...
Hard a hard time finding it too. Found an old instruction sheet lying around:
Step 1) Turn the Dimmer On
Step 2a) Press & hold the Dimmer's tap button. LEDs will blink one at a time, from the bottom up to the top. After approximately 8-seconds, the LEDs will start to cylce slowly from top to bottom (setup mode). CONTINUE to hold the tap button and go to step 2b.
Step 2b) Press and hold the "ON" button on the Wireless Controller (MRF-VCTX).
Step 2c) Once the dimmer learns the wireless controller, the LEDs on the dimmer will cycle quickly from top to bottom. Release the dimmer's tap button to exit set-up mode, and release the wireless controller's on button.
Repeat steps 1-2c for each additional dimmer.
Apr 24, 2011 | Lutron MRF-VCTX-WH Maestro Wireless White...
Does the hot wire go to the top screw on the switch or the bottom?
Unless it is a switch that is lighted it does not matter...it will work either way...
heatman101
Sep 01, 2010 | Pass & Seymour / Legrand DFB600-M 600VA...
Apparently the dimmer's sensor isn't picking up signal? It's either fill blast or off via the small adjuster button at the lower end of the main dimmer button. Tried new batteries, no luck. Time to...
If you are having to use the small air gap switch at the bottom (left to right, or pull out on newer versions) of the rocker to turn the lights on/off then the triac inside is fused and you will need to replace the switch. The triac is the piece that "dims" the lights. Once it is fused, the dimmer bar on the right side won't work, and the main dimmer button will not work either.
May 18, 2010 | Lutron ELECTRONICS MAW-600H-LA SMART...
While driving down road the interior lights won't shut off. I am sure it is a matter of the wrong button or setting but not finding answer in owners manual.
Interior lights are usually activated manually by the dimmer switch. When you turn your dashboard lights all the way up to bright, there is usually a small click that will turn on the interior lights as well. Just slightly turn the dimmer down until the click shuts off the unwanted lights. Good luck
Jan 26, 2010 | 2009 Buick LaCrosse
My lights turn on when there supose to turn off
switch the two wires going to the black and red wires on the dimmer.
Dec 21, 2009 | Maestro Lutron Electronics Mir-600thw-wh ...
Lutron GRX-PCBL-346S-500 Grafik Eye Low-voltage Plenum Rated Cable Logo
41 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
Craig Butler
Craig Butler
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
