Question about Frigidaire Refrigerators
Hi my refrigirators model is frigidaire FPD520T. the compressors sound becam very low and the refrigirator performance becam unsuffecient in the freezer and also in the coolar .i put my hand on the rear yubes and i found it hot in the top of it and also in the botom i think this is an evedent that the cooler gas is good and there is no leakage .i dont know what is happend with the refrigirator.
    Top Expert:
  • Frigidaire Master
  • 12,962 Answers
Bad door gaskets? Auto defrost working?
Posted on Aug 08, 2017
fridgetech
  • 473 Answers
SOURCE: Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Posted on Nov 09, 2007
  • 958 Answers
SOURCE: GE REFRIGIRATOR HUMMING SOUND
it could be the evaporator fan touching the ice that builds up in the evaporator.
if it is the fan, then you may have a problem with your defrost cycle. the defrost heater isnot heating up in order to defrost the ice . if it buids up, it would be so thick that the ice could touch the fan that would create the humming sound.
tnx 4 using fixya,
drcool
Posted on Aug 02, 2008
Sea Breeze
  • 4655 Answers
SOURCE: refrigirator won't get cold and freezer not
Your refrigerator has a Control-defrost,adaptive timer ,PC board and we need to have a look to see if it's defrosting properly. It could also be another problem. Let me know, Sea breeze
Posted on Apr 22, 2009
romsky79
  • 822 Answers
SOURCE: why the walls of refrigirator become hot?
the walls of refrigerator is hot due to copper tube inside. hot oil passes this tube when compressor is running.
Posted on Jun 10, 2009
SOURCE: whirpool gold
whirpool refrigirator stopped cooling and freezing and the alarm noise wont stop plus when door opened light keeps on flashing wont stop thanks
Posted on Sep 09, 2009
Frigidaire refrigirator cools but water is dripping and everything gets wet
I would like to help you but I need information has to which model you have. This makes a difference as to the answer I can assist you with. Thanks
Jul 28, 2014 | Frigidaire Refrigerators
There is problem with our kenmore refrigirator the freezer is working but the refrigirator is not working. the refrigirator is not cold enogh it is going to 60 degree
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Refrigerators
My ge refrigirator is getting warm on refrigirator side but freezer side is doing fuine. model #csh25jftaabb send answer to
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 02, 2010 | GE GSH25JFT
My air is not running correct.. blowing hot air out.. what can we do to fix this problem
hi
this may be because following reasons.
1. you might have kept the temperature selection switch in heater please check it.
2.there may be leak in the AC line which might have drained the refrigirant so no cooling effect.check the line for leakage.
3.the refrigirant used may be less which doesnt give much cooling effect.
4.the cooling fan which cools the refrigirant may not working or speed is reduced which may reduces the heat transfer rate
if my answer were useful to you please vote me.
Jul 11, 2010 | 2003 Hyundai Santa Fe
Frigidaire Refirgerator Model # SRT18ND5AQO Pruchased July 01 HI, My Dads refrigirator runs all the time - compressor, what could cause this.. Sincerely, Hans
in both cases - probably a compressor fault, blockage in pipework or short of gas. not diy for any of these
Sep 02, 2008 | Refrigerators
Need help
A removable panel in the rear gives access to the compressor and condenser. Remove the panel and clean out the condenser. Make sure the condenser fan operates when the compressor runs. Restore the panel to its original position for normal operation.
May 27, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refrigidare model # plhs267za
sounds like the air damper control for refrig is freezing in the open positon. not a really consumer freindly repair,(dropping side control panel checking damper door for ice build up, removing ice and applying a silicone lubricant(vasiline) to prevent further freezing of air damper motor. sounds easy enoug but that panel is real tricky to drop and mount back in.
Mar 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Nov 09, 2007 | Refrigerators
Refrigerators Logo
64 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
