Question about Hammering
How would i fit down lights into my stairs? i am wanting to place 2 down lights into each step. i am replacing the 50wat bulbs that came with them to new supabrite led 1.4wat blue. just need an idea of how to fit them and wire them up so they come on when you turn the stair light on.
  • 377 Answers
Find where the voltage source is controlled to turn the present lights on and off and disconnect. You need to retrofit a Malibu type voltage transformer that will provide the appropriate voltage; from what you say you want a transformer that provides the voltage of the 1.4 watt blue light, most likely 12 volts. When the switch that controlled the old lights is turned on, it will now provide voltage to the Malibu type transformer.
You can check out the Malibu web site for what's available or go to Lowes or Home Depot. Please let me know if you have questions.
Posted on Oct 01, 2010
Star trac sc4100
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
There is a battery in this unit. You should start with checking the voltage output. The following videos should aid in this procedure.
Feb 14, 2014 | Exercise & Fitness
How to replace light bulb on a clock 2004 Honda Odessey
Here are the steps:
1. Undo the panels to the left and right of the steering column.
2. Remove the panel that encloses the instrument cluster.
3. Replace the light bulb located on the back of the panel (removed in step 2).
4. Reinstall the instrument panel (removed in step 2).
5. Reinstall the panels on the left and right of the steering column.
Here are the details:
FIRST - Disconnect the battery. Be careful to locate the radio security code and radio station memory locations before you disconnect though. I chose to disconnect the ground (black wire) from the battery. Be careful to put the cable away from the battery terminal.
Step 1: Undo the panels to the left and right of the steering column.
a. Put on your parking break. You'll want to prevent the car from moving because you will soon put the car in gear.
b. Put your keys and turn to the starting position (but don't try to start the car). This allows the gear lever to move.
c. Move the gear shift to lowest gear. This puts the gear shift lever to a place nearly out of the way of the panel so that you can pry it out.
d. Using bare hands, pull smartly on the plastic edge closest to the steering wheel. Pry out the panels by hand as they are both held by tabs. This is hardest to do the first time. Keep in mind that these are pieces of plastic, so be careful. Once panels are out, let them dangle. You only need access to the instrument panel screws.
Step 2: Remove the panel that encloses the instrument cluster.
e. Remove the 8 screws that keep the instrument cluster panel in place.
o Two on left of steering wheel
o Two on top of instrument cluster (upside-down)
o Four on right side of steering wheel
f. Wiggle/pry out the instrument cluster panel. Be careful as the center is held in stronger than the sides. In addition to screws, there are different tabs that assist in holding this in place.
g. Before removing the instrument cluster panel, disconnect the clock and emergency light electrical connectors. While the clock connector disconnects easily, the emergency light has a locking tab that needs to be pushed in to disconnect. I used a small screwdriver to push in the tab to get the connector to disconnect.
h. Remove the instrument panel. Turn it over and locate the clock's protective cover.
i. Open the clock's protective cover by loosening the tabs. Be very gentle to these tabs.
j. Once the cover is removed locate the light bulb.
Step 3: Replace the light bulb located on the back of the panel (removed in step 2).
k. Unscrew the light bulb and remove.
l. Install the new light bulb. Check the light bulb before you install it. Be careful when rotating the new light bulb. in place. I've read in other posts that the light bulbs are VERY sensitive. I used a small screwdriver with plastic on the head to screw the light bulb. in.
m. Replace the clock's protective cover.
o. Reconnect the clock and emergency light's electrical connectors.
Step 4. Reinstall the instrument panel (removed in step 2).
p. Fit the instrument cluster panel back into it's original position. Be careful with the fan vents. I suggest aligning the fan vents first, then fitting the panel.
q. Screw in the 8 screws that keep the instrument cluster panel in place.
Step 5. Reinstall the panels on the left and right of the steering column.
r. Push both panels back into place.
s. Move the gear shift lever back to park.
t. Remove the car key.
u. [Optional - disengage the parking brake]
LAST - Reconnect the battery.
TEST - Reinsert your keys and turn them to the starting position (but don't start the car). The clock light should light up.
Note: Because the power has been reset, you will need to enter the factory stereo code and reset your radio stations.
May 25, 2011 | 2004 Honda Odyssey
Flash of my Canon PowerShot SD1100 IS not working at all
Has the camera been dropped at all? It may need a new bulb. Most camera stores replace them rather cheap.. But if you want to do it yourself..
How to Replace Your Digital Camera Flash Bulb Like any light bulb, your camera flash bulb can blow at any time. The rest of your camera might be state of the art, but the flash bulb itself is relying on some pretty old fashioned technology. Unlike a light bulb, however, replacing a flash bulb can be a little difficult. Depending on the type of camera or flash you have, some dissection might be required.
Step 1: Choosing the Bulb There are literally dozens of different shapes, sizes and connectors used for camera flash bulbs. These will typically vary depending on the manufacturer. However, be warned, many manufacturers will use different types of bulbs in different cameras. Just because you have a Fuji camera, for example, doesn't mean you can buy any Fuji flash bulb.
Step 2: Safety First Camera manufacturers will never advise you to replace the camera bulb yourself unless you know exactly what you are doing. This is because your camera's flash uses very high voltages. A capacitor will be charged up in order to fire the flash. This capacitor can stay charged for months, if not years. If you're not confident doing this job yourself, then you will need to take it to a camera repair shop.
Sometimes if the camera is too old, you might consider using it as an excuse to upgrade it for a newer model rather than repairing it.
Step 3: Dismantling the Camera Now, you will need to dismantle the camera carefully so that you have access to the flash bulb itself. This may be time consuming and nerve-wracking. One false move could end up breaking the delicate plastic case of your camera.
Once the camera is dismantled, you should then discharge the capacitor safely so that you can continue to work on the camera.
Step 4: Removing the Old Bulb Most bulbs are soldered directly onto the circuit board. In this case, you will need to use a soldering iron to heat up the solder at the back of the bulb and carefully pull it away from the board. This can be difficult, as you need three hands to do it properly. With the old bulb removed, try to clean up the solder pads as much as possible so that the new bulb can fit properly.
Step 5: Replacing the Bulb Push the legs of the replacement flash bulb in position through the holes in the circuit board. Then, using a soldering iron and some solder, fix it in place. Be as accurate as possible to prevent shorting out the circuit. With the bulb in place, cut back the legs of the flash bulb so that it doesn't stick out too far from the board.
Step 6: Reassembly With the replacement flash bulb fitted in the digital camera, you will then need to reassemble your camera. This will be easier if you kept all of the screws in a safe place.This is the one occasion where it's a good idea to assemble before testing simply because of the high voltages involved.
Step 7: Testing Now, put the battery back in the battery and try taking a photo with the flash. Check whether it works; if not, you will need to investigate the cause of the problem
Nov 03, 2010 | Canon PowerShot SD1100 IS Digital Camera
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Need to replace headlight bulb 2007 hhr
H13 HALOGEN HEADLIGHT BULB, SOLD INDIVIDUALLY -- Low 55/high 65-watt halogen bulb; 12.8 volts; P26.4t base; A high quality, direct fit OE replacement headlight bulb
How to Replace a Headlight Bulb
(DIY Complexity: Easy / Time: 0.9 hour)
Parts:
1. Headlight Bulb
Tools:
1. Screwdriver
2. 1/4 in. Drive Ratchet
3. Socket Set
Steps:
Step 1 Open the hood and locate the headlight assembly.
o Tip: Most headlight assemblies have a place in the rear to gain access to the headlight bulb.
o Tip: It is recommended that headlight bulbs are replaced in pairs.
o Tip: Always make sure the struts on the hood can fully support the weight of the hood so that it does not close on you while working. The use of a hood prop can securely hold it in place.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
Step 2 Gain access to headlight bulb.
o Tip: It is a good idea to check the high beam and low beam headlight bulbs at this time.
Step 3 Disconnect the wiring harness and replace the old headlight bulb with a new one.
Step 4 Turn on the headlights and check high and low beams to verify repairs.
Hope this help (remember rated this help). Good luck.
Mar 30, 2010 | 2008 Chevrolet Hhr
How to change the license tag light bulb on 2005 Deville Cadillac?
1- OPEN THE TRUNK LID
2-PUSH THE RIGHT HAND SIDE OF THE BULB FRAME TO YOUR LEFT AND PULL DOWN. NOT THE CLEAR LENS BUT THE FRAME AROUND IT.
THE BULB ASSEMBLY WILL FALL OUT SO THAT YOU CAN EASILY REPLACE THE BULB.
3- CANT DO IT? THEN DO THIS. (BE CAREFUL)
TAKE A FLAT BLADED SCREWDRIVER AND PLACE IT BETWEEN THE CHROME AND THE RIGHT HAND SIDE OF THE BULB FRAME AND DO STEP 2.
THIS DOES WORK I HAVE DONE IT (WITH THE SCREWDRIVER) ON BOTH LIGHT ASSEMBLIES.
Jun 04, 2009 | 2005 Cadillac Deville
How to replace a fog lamp with replacement bulb only on 2002 toyota 4runner sport edition???? the three screws on the bottom?
Well, these are the steps and I will post the pic here in a second...looks like 2 screws...but like I said, you can see the picture for direction on this.
Remove or disconnect the following:
Front turn signal lamp
  • Connector
  • 2 screws
  • 2 claw fittings
  • Fog lamp assembly
  • Fog lamp bulb as shown
  • Fog light unit
  • To Install
    1. Install or connect the following:
      • Fog light unit
      • Fog lamp assembly latch the 2 claw fittings and 2 screws
      • Connector
      • Front turn signal lamp
    Trying to post the pics now....
    May 14, 2009 | 2002 Toyota 4Runner
    Moved, now can't get the TV downstairs
    it went down the stairs in one piece it should come up the same way
    Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
    How to change break light bulb 1997 geo prizem
    Step #1 Open Trunk, on inside of the light housing close to the trunk latch area are 2 bolts, Remove them, on mine they were 10mm
    Step#2 Inside the trunk are 2 Black clips that hold the carpet down They have flat heads that look like screws but they are actually clips that pop out
    Step#3 Peal back the carpet in the trunk and look in the corner of the rear of the light assembly by the fender You will see a nut and the end of a bolt On mine these were gold colored, Remove the nut
    Step#4 On the outside of the vehicle again take a screwdriver or such and gently pry the outside edge of the assembly to dislodge the pin holding it in place You cant see it but you will feel when it gives and the whole light assembly will come out toward the rear of the car
    Step#5 The brake lights are the bulbs to the inside of the assembly, gently twist the socket counter clockwise and remove it from the housing, Then push down on the bulb and twist it to remove it from the socket, Replace with the new bulb and reassemble everything and You are home free!
    Hope this helps, Took me a long time to figure this one out without an owners manual!
    Take Care and good luck
    Allen
    Oct 02, 2008 | 1997 Geo Prizm
    Hammering Logo
    69 people viewed this question
    Top Hammering Experts
    John Trevino
    Steve
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Hammering Expert? Answer questions, earn points and help others
