Question about Refrigerators
Top left shelf is accumilating water, can't figure out wht is causing problem. Water isn't leaking anywhere else.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 28, 2010
Refrigator icing at bottom then leaking
bad door seals causing condensation and water accumilates in fridge
Aug 25, 2014 | Whirlpool Refrigerators
I have a maytag side by side refrigerator and water is colectiong on the top shelf of the fridge side at the side by the freezer. what could be causing this?
That sounds as if the door gasket isn't fully sealing and warm air is entering and condesating resulting in the water ya see on the shelf. Check and see espicially in the corners if the gasket seems to ripped or curled up instead of being flat and flush to the outer edge of the door rim.
GENE
Oct 06, 2011 | Maytag MSD2454G Side by Side Refrigerator
I have a Kenmore Refrigeraor Model No.72132100 and I have noticed water leaking on the upper left shelf. I have tried changing the settings on the refrigerator and freezing setting but no improvements....
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 26, 2011 | Refrigerators
Leaking under left side. water lines ok. too close to ground to see where water is. hardwood kitchen floor is buckled. ice maker is putting out too much ice and falling out onto shelf. what do i need to...
It sounds like the water tray for the defrost mode is full, you need to check if the tray has moved or maybe the door rubber are not sealing and this will cause extra ice built-up, and will cause the leak.
Jun 02, 2011 | Refrigerators
I get ice build up in lower shelf of freezer and water leaking into top shelf of refrigirator What should I o?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 02, 2011 | Whirlpool Refrigerators
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Leaking water in refrigerator
This is a common problem that happens when the defrost condensate line becomes blocked. Sometime it will leak and freeze inside the freezer and other times it will find a place inside the fresh food compartment. I'm going to add a couple of links below for you to read and review so you can get a better idea of what is happening. On the first link you will need to scroll down a little. Let me know if this is helpful, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
kitchenaid-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Jul 21, 2009 | GE Refrigerators
I have a baxter mini rack electric oven and water started leaking out of the right side of the oven while cooking bagels. any ideas on what is causing this
Sounds like you have a water leak! The right side panel needs to come off. Here you will see your copper water lines. Try steaming while watching to see where the water is coming from, most likely its coming from the two spray nozzles that enter the oven near the top in the front and rear. If the leak isn't obvious have an authorized technician service the oven. A leak in this part of the oven left unattended could cause more damage and potentially a fire.
Feb 03, 2009 | Baxter OV300E Stainless Steel Electric...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
