Question about HP Pavilion a705w PC Desktop
Hp a705w pavilion how to properly installed the video display adaptor
  • 98 Answers
Place the video driver cd or usb in your pc.. then in my computer RIGHT-> MANAGE->device manager-> video card.... right click it then select update drivr specfy the location as cd or usb that you have.. remaining it ill do.. restart your pc to use of it
Posted on Nov 01, 2010
  • HP Master
  • 5,660 Answers
Since the HP a705w desktop computer comes with Integrated Graphics, I'm going to assume you are installing a graphics card.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00255589&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=435558
The above is HP Support > HP 705w desktop computer > Specifications.
(Graphics Card, Video Card, Graphics Adapter Card, and Video Adapter Card, all refer to the same thing)
The expansion slot used for a graphics card is a PCI slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00063244&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=435558
The above is HP Support > HP 705w desktop computer > Motherboard Specifications.
Scroll down the page to the motherboard illustration shown in Figure 1, and the motherboard photo shown in Figure 2.
In the illustration the PCI slots are at the bottom of the motherboard, and are named, PCI Slot 1, PCI Slot 2, and PCI Slot 3.
In the photo the PCI Slots are shown, and are White in color.
You can use any available (Open) PCI slot.
You can use a PCI graphics card. (PCI Video Adapter Card. Same thing)
Suggest you install the software (Drivers) from the CD disk that comes with the graphics card, First.
Turn your computer on, when Windows has fully loaded, install the disk into your optical drive. (CD/DVD drive)
Follow the simple instructions, install the software.
When the software is fully loaded restart your computer. Don't be alarmed as your computer won't use this software yet.
After Windows has fully loaded again, shut your computer down normally.
(Start > Turn Off Computer > Turn Off)
Unplug your computer from power.
Open the computer case.
Follow Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
(Processor, Ram Memory, Graphics Card, motherboard chipset, Harddrive, and so on)
With the computer unplugged from power, working on a table, computer case open, TOUCH the metal frame of the oprn computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, upon your return be SURE to Touch the metal frame again.
There will be a metal slot cover, installed on the outside frame of your computer case. (Expansion Slot Cover)
This flat piece of metal will cover where you want the PCI graphics card to be.
It has to be removed.
There are several methods that this metal cover will be attached, to the metal frame of the computer case.
[ NOTE*
The metal expansion slot cover you have to remove, will Not be inline with the PCI slot.
It will be over one slot
Once you attempt to physically install the PCI graphics card, you'll see what I am referring to ]
1) To remove this metal cover look for an + in it. A flat tipped screwdriver is installed in the +, and the screwdriver is tipped down.
(The handle of the screwdriver is tipped down)
Looking at the back of the computer the expansion slot metal cover is horizontal.
The cover is twisted in an up, and down fashion to remove.
(Twisting from the bottom of the computer, towards the top, and then back down again)
There are small metal tabs that hold the metal cover in place. You are twisting the cover to break these metal tabs.
2) The metal cover is held in place by a single Philips head screw.
Remove the screw, remove the metal expansion slot cover.
3) I don't believe the a705w had a cover plate. A cover plate is hinged on one side. Usually a single screw is removed, and this allows the cover plate to swing to one side.
This action allows removal of all expansion cards installed.
Once the metal expansion slot cover is removed, line up the contact pins of the Video Adapter Card with the PCI slot.
Insert the video adapter card straight down in the PCI slot.
Install the screw that holds the video adapter card in place, to the metal frame of the computer case.
Close the computer case.
Plug your monitor into the video adapter card.
Plug the computer back into power.
WAIT 1 minute, turn the computer on.
For questions please post in a Comment.
Posted on Sep 28, 2010
What type of videos does the hp a705w destop have, Need to know so I can go to the web sit and see if they have the Linux drivers i need or even if they make them
Hello! Follow the following procedure to know ur grapics card model. Go to RUN in Win XP and type dxdiag and press enter. It will take you to a DirectX diagnostic tool. From there, click the Display tab to know the model number under the label Name: For Win7 and Vista, go to start and type run in the box at bottom of start menu and follow the same procedure.
Aug 25, 2010 | HP Pavilion a705w PC Desktop
HP pavilion A750w starts up, but doesn't seem to go to POST, or at least there is no video once I turn on the machine. Used original, and newer monitors. Replaced onboard video with EVGA GEFORCE FX5500...
Hi there you need to make sure the monitor is properly connected and make sure you install the drivers for the new video card.If you still have the problem you should open the computer and check the memory by taking it out and put in into another memory slot on the motherboard.If you have more than one memory in the computer please take them out one at a time and restart the computer if that does not work you should replace them you new one that is compatible with your computer.
Jun 13, 2010 | HP Pavilion a705w PC Desktop
My hp pavilion a705w will not read 8 gb micro sd cards. I get an i/o error.
you need to get the reset disk for windows or open up the computer and wiggle it
Dec 13, 2009 | HP Pavilion a705w PC Desktop
HP Pavilion a705w PC Desktop\Ethernet Controller driver
obtain the driver from cd/dvd that was included as you purchased your desktop and try to check if the driver supports with the operating system you are using now. for example the driver available in your cd/dvd is only for windows xp and your operating system you are using now is windows vista of course driver not installed. try to download from internet the driver that are suite to your unit model and current operating system this can fixed your problem or else downgrade your os tha can support the driver that are available from your cd/dvd.
Oct 11, 2009 | HP Pavilion a705w PC Desktop
Connect projector to HP desktop
If you are attempting to connect an LCD projector to a laptop,you connect a monitor cable to your video card and the other end to the monitor input connector. You may have to use an adapter, I know on my LCD projector I had to use a DVI to VGA connector.
Can't say much more not knowing if you are having a problem with a particular brand of projector
Sep 21, 2009 | HP Pavilion a705w PC Desktop
Installing XP
DId you "Wipe" the hard drive or just "Format" it? There is a big difference?
Sep 17, 2009 | HP Pavilion a705w PC Desktop
HP Pavilion a705w PC Desktop Logo
426 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
