Question about Whirlpool GB2SHKXL Bottom Freezer Refrigerator
Model GX5FHDXVB03. ICE BUILDUP IN FREEZER DRAWER AND WALLS, MOSTLY ON THE SIDE WITH THE ICE MAKER.
  • 183 Answers
SOURCE: Frost buildup on ice/water dispenser
Your problem is definatly caused by air entering freezer either from the ice shute flap or door not sealing correctly, try putting a bright torch in frezzer and closing door look for light escaping around edge of door, if you can see the light then change door seal, the fault cannot be anything else. Regards Advisor
Posted on Aug 30, 2007
Oceti
  • 51 Answers
SOURCE: Frigidaire model # FRS26ZNHB2 side by side not cooling
T
From your description, you have a bad evaporator fan motor. The part number for a replacement motor is #5304445861.This is not a direct replacement but is more reliable.Remove everything in the freezer, take off the back panels and you will see the fan.
If there is a large frost buildup on the coils and the fan is turning you have a defrost problem. If that is the case, please call me at 334-347-0000 and I will walk you through it.
Posted on Jan 14, 2008
gaeb7
  • 25 Answers
SOURCE: Frost build up in the freezer section of my side by side Kenmore
Replace the defrost clock.
Posted on Feb 25, 2009
landsend
  • 1066 Answers
SOURCE: Ice maker stopped working
sadly you need to turn off the fridge let it dry out with the doors open then turn it back on.
Posted on Mar 31, 2009
freetek
  • 5568 Answers
SOURCE: pan that catches water under freezer side overflows
That is pretty unusual unless you live in a humid area. Some units have a switch that allows you to adjust for this and it simply defrosts every 12 instead of 24 hours. Also, the fan that cools the coils under the unit may not be running at normal speed since the warmth of the coils and the fan generally suffice to return the accumulated water into the air. You are right to check the door seals since if these are no longer seating well, external humidity will be gathered by the cooling coils and subsequently become the water collected below that is plaguing you.
Posted on Apr 30, 2009
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
Ice maker leaking into ice storage tray
start with hose replcement buy parts at sears water hose to main ice maker might have crack in it or the stopper is bad get in ther look close with brite light
Oct 14, 2008 | Refrigerators
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
My freezer has ice building up on the bottom
Defrost freezer, and make sure the door close well each time
Mar 07, 2010 | Frigidaire Freezers
Ice cubes are turning into a clump of ice
I found a high density foam and a plastic retainer under the freezer drawer, inspected ice maker and found a wire with a rectangular senser hanging down. Removed freezer drawer and door to gain access to icemaker. Reinstalled foam piece and plastic retainer to lower front of icemaker (there are recess and a small retainiing tab) Reassembled freezer door and drawer, system working normally
Feb 23, 2010 | Whirlpool Refrigerators
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
Remove door and icemaker from bottom freezer model 59673914200 -- icemaker wont turn
The ice maker switch had come unattached due to excess ice buildup, and frozen to the ice pack. The ice in the ice maker had also frozen into a solid block due to not being able to rotate. After removing the drawer trays and protecting the frozen food, turning off the refridgerator, I used a hair drier to melt and remove the ice from the ice maker, gave it time to dry out, -- No gears wer stripped,- the ice maker now works normally.
Aug 23, 2009 | Kenmore Refrigerators
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
GE Side by Side Not Cooling
Hi , the refrigerator having problem with enfeller fan stuck it needed to defrost manually to drain all ice buildup inlet of refridgerator hole after 3 hour try start refrigerator.
Feb 05, 2008 | GE GSS25JEMWW Side by Side
Whirlpool GB2SHKXL Bottom Freezer Refrigerator Logo
283 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
