Pioneer amph sa 9500 II
Dear my frıend
I have an amph pioneer sa 9500 II
is ıt possibe to find left output part
thank you for your assisit.
Regards
Ali Yalaz
  • thiru sambanth May 11, 2010
    Pl.tell me about what are inputs and output having your amplifiers,then i can solve ur problem
  • 1,512 Answers
Hi yalazogeday
Your amp is fitted with two 2SD588A (NPN) and two 2SB618A (PNP) power transistors in the output stages. Click on the part for a place to get them from. These parts are no longer available from Pioneer, nor are the prescribed replacements. (the amp was built in 1978) Because of the unusual transistor package used, you may have to upgrade to a more modern transistor, and modify the mounting also.
robotek
Posted on May 28, 2008
  • Tobias Mixer
    Tobias Mixer Dec 27, 2010
    Hey there,
    My amp is the sa-9500II and it clicks off periodically. Is that caps or transistors in your estimation? If so is a full cap replacement the only method here or is there a know cap you'd target? Thanks
How many fuses?
Simply disconnect from the power source, take the top off and have a look. There is usually only 2 on the input side of the power supply. If blowing fuses check the DC rectifiers or your connections.
Mar 08, 2016 | Pioneer Vintage Legendary Sa-9500 Ll Sa...
Need service manual for pioneer sa-600
Head straight to the (European) electrotanya website, which offers free downloads of a wide range of service manuals. No registration is required either.
The Pioneer SA-600 schematic shows both voltages and currents. For this amp, the total current for left & right output modules (no signal) is 60mA. No-load voltage is 58 volts, dropping to 48 volts (one channel driven, 25 watts out).
PIONEER SA 600 SCH Service Manual free download schematics eeprom...
Feb 26, 2014 | Cameras
Pioneer model SA 9500 stereo amplifier problems.
Is the dc voltage reading on the base of the outputs 0.6 with emitters reading 0.014 or there about. Depending on the outputs used you might read 1.2volts on the base. Your collectors will read the power supply voltage of 50 or 60volts or more. If this is what you are reading on your meter the problem is in the speaker protection circuit. This circuit is what drives the relay you tested.
Jun 27, 2012 | Pioneer Audio Players & Recorders
Programming the cn101a timer
CN101A programmable weekly digital timer
Buttons
C = Master Clear, erases all program settings and current day/time.
C/R = Control/Reset, used to access programming mode and to clear individual programs.
You must press and hold this button for approximately 4 seconds to enter programming mode if there is a lower case "a" to the left of the time display. The system will revert back to active mode (with the lower case "a" to the left of the time display) after 30 seconds with no buttons pressed.
If this button is momentarily pressed while viewing a program, that program will be erased, but ONLY the On or Off program that is being viewed will be reset. The corresponding On or Off program in that cycle will NOT be reset.
Clock = In programming mode, this button is held depressed at the same time as one of the D+, H+, or M+ buttons to set the current day and time. When editing the programs, this button is used to exit when done.
P = Program select, each press will advance through the On and Off programs (presets). There are 16 On/Off cycles available (1 On, 1 Off, 2 On, 2 Off, ... 16 On, 16 Off).
D+ = Used to change the day when setting the time, or day(s) when changing a program.
When changing a program,
the following 15 different day combinations are available using the "D+" button.
MO; TU; WE; TH; FR; SA; SU; MO/WE/FR; TU/TH/SA; SA/SU; MO/TU/WE; TH/FR/SA; MO/TU/WE/TH/FR; MO/TU/WE/TH/FR/SA; MO/TU/WE/TH/FR/SA/SU.
H+ = used to change the hours when setting the time or a program.
M+ = used to change the minutes when setting the time or a program.
Manual = This button will cycle the output relay from AUTO to Manual OFF, back to AUTO, then to Manual ON, and finally back to AUTO. Programming mode must first be accessed using the C/R button to use the Manual feature. The manual On or Off settings will override all programs until switched back to AUTO.
There is a Lithium Ion battery which is intended to keep the clock going for up to 3 years during loss of external power, but the output relay will not work on internal battery power.
Jan 17, 2012 | Hardware & Accessories
Speaker wire specs for front and rear on the pioneer deh-p580mp
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
hopes this helps
pls rate
Aug 17, 2010 | Pioneer Premier DEH-P580MP CD Player
I have a Pioneer DEH-P6400 head unit. I need a wiring diagram so i can reinstall it.
the standard radio diagram is
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
grey fr right +
green rear left +
purple rear right +
that should help u
Aug 13, 2010 | Pioneer DEH-P6400 CD Player
What are the speakers wire colors on a pioneer car stereo?
fr left + white
fr left - white/black
fr right + grey
fr right - grey/black
rear left + green
rear left - green/black
rear right + purple
rear right - purple/black
hope this helps thumbs up pls
Aug 11, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
I have a Pioneer SA 1050. All the lights come on
check your speaker selector switch to see if its on the correct setting ie; speakers one ( not speakers 2 ) also check your speaker cables by reversing them, ie; put right speaker cable into left channel and vice versa with the left etc? check also to see if your amp is set to headphone output by mistake in which case no sound will come out until you select the speakers instead? good luck.
Jun 24, 2009 | Pioneer Audio Players & Recorders
Hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Oct 15, 2007 | Audio Players & Recorders
1,081 people viewed this question
 Grubhead
Grubhead
