Question about Vacuums
How do I clean out my iron - proctor silex ultra ease 17115? I've had the iron for several years and no longer have the maintenance instructions. Thank you. -Diane
  • 43,501 Answers
I would try the white vinegar...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Posted on Sep 28, 2010
How much do I need to spent to get a quality vacuum?
Cost isn't the main factor to get a quality vacuum. There are plenty of vacuums in all price ranges that may work great the first year or two. Some expensive vacuums have problems and require lots of maintenance. Most vacuums in the hundred dollar price range are good for about a year. Bagless vacuums require a lot more maintenance than a bagged vacuum. Filters must be cleaned frequently to insure good airflow, and the filters and belts should be replaced at least once per year on most models. Filter replacement on bagged vacuums is not as critical because the dirt goes into the bag keeping the insides of the vacuum a lot cleaner which makes it last longer. Some vacuums, Hoover Windtunnel for example are available as a bagged or bagless model. The bagged models perform much longer than the bagless models for the average consumer, mainly because most people do not maintain their vacuums properly. There are a few really great vacuums in the two to three hundred dollar range that can work great for 10 years or more with nominal routine maintenance. The best place to find one is at a reputable vacuum store.
Mar 07, 2017 | Vacuums
Free instruction manual for bissell 4104
I've found step by step video demonstrations for cleaning, belt replacement, basically maintenance of different appliances on "YOUTUBE" you might want to check it out. Just type in Bissell 4104 beater bar replacement. Hopefully there will be a video showing you exactly how to replace it properly.
Jan 04, 2012 | Bissell 4104 Bagless Upright Cyclonic...
I need instructions on how to clean Digital Advantage Iron. I have lost my manual.
any iron can be cleaned by running a little water and vinegar through it several times, it loosens the scale build up that gets in all irons over time, be sure and try to clean out the venting steam holes in the face of the iron, Once you do this, run clean clear water through it and you should be fine, if possible, always use bottled water (purified) water in irons
Jun 02, 2011 | Vacuums
I have a shark iron model G1495N It has a cut in the wire inside the rubber hosing that goes around the cord from the base of the iron When using it yesterday I didn't see the cut and it sparked...
It's probably best to replace the device, when dealing with sparks and exposed wires.
If you're electrically-inclined, feel free to pry it apart (when unplugged!) and see if you can re-attach things, but generally soldering or gluing within an iron is a bad idea.
So... two and a half years is longer than most Hollywood marriages. It's been a good run. Time for a new iron.
May 06, 2011 | Vacuums
How to clean sunbeam ultra 60 platinum iron. Can't find instruction booklet!!!!!
Do you mean the Sunbeam Ultura 60 Platinum iron? Wipe the exterior of the iron with a damp soft cloth and then dry the iron. To clean the steam valve, turn the Steam/Dry dial to Clean so that the tip pops up. Gently scrub the tip of the valve with a steel wool pad moistened with warm water. Rinse and dry with a soft cloth. Replace the valve and turn clockwise to lock into place (reset the dial to Dry when storing the iron). Clean the steam holes of any build up, use a cotton wool tip moistened with methylated spirits. The teflon plate should be cleaned with the damp soft cloth, just like the rest of the exterior of the iron. If you have ironed a polyester that melted onto the iron, then iron a damp cotton cloth when the iron is hot.
The manual for several Ultura irons, including the 60, is available here: http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1485 . The link for the manual is in the center of the page above the Image Gallery.
I hope this helps.
Mar 06, 2011 | Sunbeam Vacuums
My dyson slim scope does not have any suction at all. i"ve checked the tubing for any clogging, and there is none. What can it be?
Sorry to hear you've experienced a problem with your DC18. I note this question was posted several months ago - hopefully you've resolved your issue since then. If not, you may find it helpful to visit the Support section of our website. These simple steps should help you determine whether everything is correct with your cleaner:
http://www.dyson.com/support/help.asp?article=1453&product=DC18-ALLFLOORS
If you've tried this and are still having difficulties, please get in touch with us free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some simple checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Jan 17, 2011 | Dyson Slim DC18 All Floors HEPA Bagless...
I lost the directions for the proctor silex waffle maker
Try this site
http://www.proctorsilex.com/use-and-care.php
you will need to enter your model number and type of product. The use and care manual then can be downloaded. There are also recipes on the site as well.
Dec 29, 2010 | Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
Theres water pouring out of my t fal iron's little holes when I begin to iron my shirt...why!
The iron needs to be cleaned as I have just discovered myself. I have a hinari and the instructions are as follows. Fill the water tank and turn the iron on to medium. When heated press the steam button and hold it over the sink or a container so that the water can run out of it. It will take sediments with it. The cleaning of the iron should be carried out once a month.
I experienced the same trouble and carried out the instructions and all is well again.
Jun 28, 2010 | Vacuums
Vacuums Logo
323 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
