The picture on my Hitachi Plasma TV has been "flickering" lately... this morning the picture is ghostly... can't see it! It is only 4 years old. What can be the problem? This was a VERY expensive TV.
  • sami1333 May 24, 2008
    I don't think it's a rear projection... it just hangs on the wall.
    Thanks... but this TV is HUGE! I wouldn't know where to start. I guess I should call a professional, huh?
    Thanks for you help!
    President:
  • 2,712 Answers
It could be the convergence IC's that need replacement. It could also be a problem with the many capacitors/resistors around the IC's.
If you are confident enough to try a DIY, here is a good step by step guide with pics to assist you. But beware, if you have no prior experience, I wouldn't recommend opening the set, as there are voltages inside that can KILL.
I suggest you get a qualified service technician to take a look and get the TV fixed.
Posted on May 24, 2008
  • Swilin Sampson
    Swilin Sampson May 24, 2008
    OOPs..I see that it is a Plasma TV..Please ignore the previous post regarding convergence IC's.
    The problem is most likely a loose connector ribbon. Also make sure that all the cables and connectors have clean contacts. You can try wiping them with a bit of isopropyl alcohol to clean the contacts.. ALso be aware that Plasma TV's are pretty sensitive to temperature and voltage fluctuations.
    Try this as well:
    Unplug all cables from all inputs to the TV, the see if the screen
    flickers on the menu screens. If it does not , you have a ground loop
    problem, which can be identified by plugging back the cables until the
    problem reappears. The problem could be due to defects in the video processing circuits.You would need a Video Isolator on this input.
    In any case, it is better to get an on the spot diagnosis by a qualified technician. The solutions provided above are all based on long distance evaluation, and will give you something to go by... But an on the spot inspection would be the best way to go..
    Hope that helps. If you have any further questions, please post back.
  • Swilin Sampson
    Just a side note:
    As a rule of thumb, you should never, ever touch your plasma television. That is what a remote is for and if
    you are wise, you will encase it in glass. This is no joke as plasma screens are very delicate. Also, you should dust your screen on a regular basis to prevent what appears to be rainbow colored dots on the screen.
  • 19,396 Answers
If it is a rear projection it is likely to be a convergence problem, what is the model?
  • Ginko
    Ginko May 24, 2008
    Sorry, on a plasma tv you need to perform service adjustements ( convergence, rgb, etc.).
    Download service manual, here is the one for Hitachi 43'' in may possess, I just uploaded it . Service procedure should be same for all hitachi plasma tv. Check from page 32 to page 48.
    Follow badongo instructions for download.
    Using service procedure involve risk of causing further damage to your tv, contact a technician if you are not confident with this kind of service on TVs.
    If after performing procedure tv still has the problem, then it is probably the Ysus board in need of replacement.
Hitachi 42" plasma 4 yrs old
I have the 55HDS52 and it flickered like crazy. The firmware was V0101.0001 and I called Circuit City and they sent a tech out with the latest fimware for my TV which is V0102.0001 and now the flicker is gone. I kept my settings all the same and watched the same reference scenes over and over and could not get it to flicker anymore. I'll post if anything changes but it seems that this worked for me. please have a look at THIS very long forum on Hitachi Plasma Noise
Dec 03, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi Plasma EDTV has green dots flickering all over screen
that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Mounted hitachi plasma tv
The satilite works. The TV won't turn on al all, teied everything.
Nov 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi Plasma screen flickers
Got sound but the picture intermittendly flickers on and off. checked all cables and connections had the tv about 3 years now.
Thx
Sep 06, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Picture flicker
You can get info at ctechnicians.com
Dec 22, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Flickering
I have a42hds52a and someone threw something at the screen and broke it. so I am looking for someone who is willing to get rid of thier tv1.gif or looking to buy one for parts.
call Richard At916-308-9272
raystockett@inbox.com
Nov 01, 2007 | Hitachi 42HDT52 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
