Ceejay reads 100 pages in an hour . give the ratio of her speed in reading in minutes.
  • 2,567 Answers
Ceejay reads 1.6666666666666666666666666666667 pages per minute.
Posted on Sep 28, 2010
What's RPMs means in automatic gearbox and where does one need to check the RPMs on car
revolutions per minute and is read from the turbine shaft in the transmission
it reports the input drive shaft speed to the TCM so that the TR knows to change ratios
the engine rpms engine revolutions per minute are recorded on the tachometer in the dash so don;t confuse the two different readings
take it to an accredited auto transmission shop to have the sensor replaced
May 28, 2017 | Cars & Trucks
Would a 4.88 ring and pinion gear lower my speed too low for street driving for my '93 chevy s-10 2.8 engine 2 WD w/a 5 speed manual transmission?
normal street diff ratios are in the 3:1 or 3.5: ratios as these give best performance speed and economy
fitting that ratio will give a lower top speed and may affect the economy as it makes the engine seem more powerful so less throttle is need for take off
it also will have higher rpms at your normal driving speed
(example -- normal ratio --60 mph 3000 rpms new ratio 60 mph-- 3250 rpms )
the speedo reading will be out as well enough to get into trouble with speed cameras
if you are not a led foot and take you time in traffic it will be just a bit slower
the only real way is to try it and see if you like the result
Jan 02, 2017 | Cars & Trucks
What diifference will it make to my speedo reading if my front tyre is size 120/60 ZR17 instead of 120/17 ZR17 on m1993 suzuki rf600r bike
If I am reading the tire size right you are dealing with a different width and not circumference. If in fact it is width it want make any difference, however, if it is circumference then if the tire is smaller the transmission is going to have to turn faster to get 50 MPH or any speed. The speed of your car is measured at the back of our transmission. Smaller tires will make the speed-0-meter read fast and larger tires will give you a slow reading. This is the one that will get you in trouble. With a larger tire and you meter reading 50 you might be doing 60 or more. You can figure the speed of any tire on a car just take the circumference of the tire [how many inches it travels in one revolution] and divide it into 5280' for miles then Multiply it by T=time taken to travel distance then figure in the RPM's and drive your self crazy trying to figure it out.
Again as I said if they are the same circumferance then your speed -o- meter will not change.
Col. Dana Gillespie
Jul 05, 2014 | 1993 Suzuki RF 600 R
Speedometer repair
Definitely! When you put a larger or smaller tire it will effect it and so will changing any gear ratios. The speed- o- meter is calibrated for a specific tire size and a certain gear ratio and anything that deviates from that will cause the speed- o- meter to show faster or slower depending on the change. Think if it this way a 16" tire will travel farther in one revolution than a 14" will. Therefore if your car/truck came out with 14" tires and you put 16" tires on it then the speed O meter will show you are traveling slower than what you are. The opposite applies if you downsize. Changing differentials that have a different gear ratio can also affect it. It's a good way to get a speeding ticket. If you put smaller tires on one then the speed- o- meter will show you going faster than you are and it will take more RPM's to reach the same speed, thus causing it to use more fuel.
If you are going to change the tie size or gear ratio very much I would suggest investing in a good Radar Detector! Good luck.
Col. Dana Gillespie
Mar 23, 2014 | 1993 Harley Davidson FXR Super Glide
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Our detecter reads from 10 to 12 what levels are dangerous?
A Reading of 10-12 is nothing to be worried about.
Thirty-five ppm in an 8 hour period, is the maximum exposure allowed by OSHA in the workplace.
100 ppm Slight headache within 2 to 3 hours
400 ppm Frontal headache within 1 to 2 hours, Widespread headache within 2.5 to 3.5 hours
800 ppm Dizziness, nausea, convulsions within 45 minutes
1600 ppm Headache, dizziness and nausea within 20 minutes, Death within 1-2 hours.
3200 ppm Headache, dizziness and nausea within 5-10 minutes, Death within 1 hour.
6400 ppm Headache, dizziness and nausea within 1-2 minutes, Death within 25-30 minutes.
12,800 PPM Death within 1-3 minutes
Dec 17, 2010 | Kidde Nighthawk Combo Gas/co Detector
Blood pressure reading is not consistent and accurate.
blood pressure reading is not really consistent. for example; the reading of client's blood pressure at 8AM it doesn't mean that you have the same reading on the next minute/ hour. because the blood flows is not also consistent.it varies on people..for example; he has a reading of 100/80 it doesn't mean he has 100/80 on the reading..it varies on what the clients doing prior to that reading.but on those client with cardiac problems it should really monitor the Blood pressure closely. for that simple negligence it would the client to enfarction
Aug 11, 2010 | Lumiscope Health & Beauty
Alina read 56 pags in 3 hours. At the same rate, find the number of hours it will take her to read the remaining 40 pages
> Alina reads 56 pages in 3 hours.
Alina reads 56/3 pages in 3/3 hours.
Alina reads 18 pages in 1 hour.
Alina reads 18 pages in 60 minutes.
Alina reads 40 pages in (40/18)*(60) minutes.
Alina reads 40 pages in (40*60)/18 minutes.
Alina reads 40 pages in 2400/18 minutes.
Alina reads 40 pages in 400/3 minutes.
Alina reads 40 pages in [about] 133 minutes.
Aug 02, 2010 | Computers & Internet
We need instructions for a contour 100 payphone, it is asking for a pin number and we dont have one as we bought this 2nd hand
Welcome to FixYa
Dear User,
Here is the Instruction Manual for you{it may take few minutes to load depends on Connection speed} Click here and Save it..Read carefully to get all details of your product...
It is necessary to Know Old Pin to Change your PIN.Contact the Person who sold the Product to you...He can give PIN Number...And Make Change it...
.If you for got PIN contact Helpdesk
  • Changing your PIn:Page 34
  • Contact Help Desk Details on Page 2 Right side
Hope you got an idea... If this Helps-DONT FORGET to RATE ME......Thanks for Contacting FixYa....
Jul 03, 2010 | Lands Phones
How too change time
Norstar Merdian Press Feature.
Enter "**8463".
Enter the password (default is 266344). The display shows
Hour: 01
Next Change
Select CHANGE. Display shows:
Hour: __
Cancel
Enter two digits for the hour. Chose AM or PM when Prompted.
Select NEXT.
The display shows:
Minutes: 00
Next Change
Enter the minutes.
Press the RLS button to end, or press NEXT to change the date.
The diplay shows:
Year: 99
Next Change
Enter the two-digit year.
Select NEXT and repeat to change the month and day.
Press the RLS key to save the time and date and exit programming.
Top of Page
Norstar Meridian CICS Time
  • Press "FEAT".
  • Press "*".
  • Press "*".
  • Press "266344" (CONFIG) or "23646" (ADMIN).
  • Enter password "23456" (ADMIN) or "72787" (SCPLUS).
  • You will see "Terminals & Sets".
  • Press "Next" five times.
  • Press "Show"
  • When you see "Hour", press "Change" or "Next" to skip.
  • Type in the hour using military time as a 2 digit number.
  • Press "Next".
  • When you see "Minutes", press "Change" or "Next" to skip.
  • Type in the minutes using a 2 digit number.
  • Press "Next".
Date:
  • When you see "Year", press "Change" or "Next" to skip.
  • Type the year in 2-digit format.
  • Press "Next".
  • When you see "Month", press "Change" or "Next" to skip.
  • Type the month in 2-digit format.
  • Press "Next".
  • When you see "Day", press "Change" or "Next" to skip.
  • Type the day in 7-digit format.
  • Press "Next".
  • When you see "End of List", Press "Rls" to exit.
Top of Page
Nortel Norstar Telephone Systems Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
  1. To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
  2. Enter password (default = 266344) - display should read "Terminals & Sets"
  3. Press "NEXT" 5 times - display should read "Time and Date"
  4. Press "SHOW" - display should read "Hour:___"
  5. Press softkey "CHANGE"
  6. Enter hour - display should read "AM OK or Change"
  7. Select AM or PM
  8. Press "NEXT" - display should read "Minutes:___"
  9. Press softkey "CHANGE"
  10. Enter minutes
  11. Press "NEXT" - display should read "Year:___"
  12. Press softkey "CHANGE"
  13. Enter year
  14. Press "NEXT" - display should read "Month:___"
  15. Press softkey "CHANGE"
  16. Enter month
  17. Press "NEXT" - display should read "Day:___"
  18. Press softkey "CHANGE"
  19. Enter day
  20. Press "NEXT"
Sep 15, 2008 | NorStar T7316E Corded Phone
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
