Linksys router connets to network, unable to connect to internet,says unable to connect to dns servers
  • 121 Answers
Reconfigure tcp/ip
check for routers config: "firmware , authentication etc,,,
Posted on May 24, 2008
I CANT ACCESS A FEW SPECIFIC SITES.
Hi Pauline,
Try different using a different DNS address. OpenDNS provides free, fast servers that are used by millions. Here's how to do it with and without a router in your set up:
WITHOUT A ROUTER:
Mac OS X
  1. Go to System Preferences.
  2. Click on Network.
  3. Select the first connection in your list and click Advanced.
  4. Select the DNS tab and add 208.67.222.222 and 208.67.220.220 to the list of DNS servers.
  5. Click OK
Windows 7
  1. Click the Start Orb, then select Control Panel.
  2. Click on Network and Sharing Center.
  3. Click on your primary connection or Local Area Connection under Active Networks.
  4. Click the Properties button.
    Windows 7 may prompt you for permission to make network setting changes.
  5. Highlight 'Internet Protocol Version 4' and click Properties.
  6. Click the radio button 'Use the following DNS server addresses:' and type 208.67.222.222 and 208.67.220.220 in the Preferred DNS server and Alternate DNS server fields.
  7. Click OK button, then the Close button, then Close again. Finally, close the Network and Sharing Center window.
    At this point, we highly suggest that you flush your DNS resolver cache and web browser caches to ensure that your new configuration settings take effect.
Windows XP
  1. Select Control Panel from the Start menu.
  2. Click Network Connections from the Control Panel choices.
  3. Choose your connection from the Network Connections window.
    If you have more than one, choose your default/current connection.
  4. Click Properties button.
  5. Select Internet Protocol (TCP/IP) and click Properties.
  6. Click the radio button Use the following DNS server addresses and type 208.67.222.222 and 208.67.220.220 in the Preferred DNS server and Alternate DNS server fields.
  7. Click OK
Windows Vista
  2. Click on View network status and tasks.
  3. Click on View status.
  5. Vista may ask for your permission to make changes. If so, click the Continue button.
  6. Select Internet Protocol Version 4 (TCP/IPv4), then click the Properties button.
  7. Click the radio button "Use the following DNS server addresses:" and type in OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in the Preferred DNS server and Alternate DNS server fields.
  8. Click the OK button, then the Close button, and the Close button again. Close the Network and Sharing Center window.
WITH A ROUTER:
Generic Router
  1. Open the preferences for your router. Often, the preferences are set in your web browser, via a URL with numbers (example: http://192.168.0.1). You may need a password.
    If you're like us, and you set the router password long ago and cannot remember it now, you can often reset the password to the manufacturer default by pressing a button on the router itself.
    Or preferences may be set via specific application for your router, which you installed on your computer when you added the router.
  2. Find the DNS server settings.
    Scan for the letters DNS next to a field which allows two or three sets of numbers, each broken into four groups of one to three numbers.
  3. Put in the OpenDNS server addresses, 208.67.222.222 and 208.67.220.220, as your DNS server settings and save/apply.
Linksys Router
  1. Visit the router's IP address in a new browser window.
    http://192.168.1.1 is the default Linksys router IP address.
  2. Enter the Network password.
    The "Enter Network Password" window will appear. Skip user name and type the router's password (admin is the default password, if you haven't changed it) and click the OK button.
  3. Type in OpenDNS addresses, 208.67.222.222, 208.67.220.220, in Static DNS 1 and Static DNS 2 fields.
  4. Click Save Settings button.
Netgear Router
  1. Type the router's setup URL (http://www.routerlogin.net, http://192.168.0.1 or http://192.168.1.1) into a web browser address bar.
    http://192.168.1.1 is the default Netgear router IP address.
  2. Enter the password.
  3. Type in OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in Primary DNS and Secondary DNS fields.
  4. Click Apply button.
  5. Wait for the settings to be updated.
D-Link Router
  1. Visit the router's IP address (http://192.168.0.1) in a new browser window.
    If you are attempting to configure a D-Link router, take note of your computer's Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. Most D-Link devices use the 192.168.0.X range.
  2. Enter the router password.
    Note: if you have not changed the original settings, the default username is admin and the password is blank (nothing).
  3. Click on the Manual Internet Connection Setup button at the bottom.
  4. Enter the OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in Primary DNS Server and Secondary DNS Server fields.
  5. Click Save Settings button at the top.
Oct 07, 2014 | Computers & Internet
I am connected to the internet but can't connect to certain sites.
Check your poxy settings. Almost sounds as if there is a proxy server blocking access. Also check DNS settings. If you need to hard code DNS settings into the network connection. I use googles DNS free servers at 8.8.8.8 or 8.8.4.4 these are a global DNS server.
Sep 12, 2013 | Linksys E1200 Wireless Router - Ieee...
DNS server not responding on WRT54GL Linksys router
You are looking for DHCP server. It provides the IPs addresses for devices to connect. DNS resolves the IP into a name. Not really required unless you are setting up a virtual server, or the special setup.
Feb 12, 2013 | Linksys Wireless-G WRT54GL Router
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
To specify DNS server address settings, do one of the following:
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
I have a windows 2003 SBS Standard Edition and IP Address: 192.168.1.5 also a Linksys WRV210 and the IP address 192.168.1.1 I have setup a preferred DNS on all clients to 192.168.1.5 The internet is not...
For that connect your router to directly to lan ports of your server.and install another ethernet lan card on server so that ports connect with switch.
Then configure your router as bridge connection then set dns as your server ip in all computers.Then you can get 100% fast internet.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 15, 2009 | Computers & Internet
Problems conneting to Internet through Belkin 54G router
- Assigning of static DNS address on your computer will do to fix the issue.
Mar 15, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless connection, but no internet
Verified that the Internet connection is working good
- Now if your connected to the wireless network but unable to access a website try this:
- Open the control panel
- Open the network connection
- Right click on wireless networks (Choose properties)
- Choose Internet protocol then click properties
- Assign DNS Server address (Preferred DNS: 4.2.2.2, Alternate DNS: 4.2.2.3)
- Leave the DCHP as obtain IP address
Mar 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Linksys WRT54G wireless connection problems.
click on Start -> Control Panel -> Network Connections -> Wireless Network Connections -> Properties -> In the box in the middle scroll to and click on "Internet Protocol (TCP/IP)" -> Click Properties -> Make sure "Obtain an IP Address Automaticaly" is Ticked -> make sure "obtain dns address automatically" is Ticked. -> ok -> click ok
See if you can connect
Click on Start -> Run -> Type CMD and hit enter.
a command box will open. type in IPCONFIG/ALL
Please copy down the following numbers ---
IP Address
Subnet Mask
Default Gateway
DNS Servers
Please make sure you copy them correctly and post them here.
Dec 24, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
