Question about GE Refrigerators
I have a GE SxS model number gss22jepabb that doesn't keep the refrigerator part cold. We have replaced both thermistors in the freezer and last night the motherboard. Refrigerator is still not cold and the freezer randomly defrosts itself. Also, we have replaced the defrost heater and timer. We have had the appliance for eight years and have about 300 dollars in repairs into it. Do you have any other ideas other than blowing the thing up??
  • 121 Answers
Close the doors and look to see if the fresh food door is down lower then the freezer door. If it is adjust the fresh food down up until it is at the same level as the freezer door. The reason why I suggest this is hard to explain but it is a legitimate repair. This page does explain http://www.appliance-repair-it.com/GE-refrigerator-repair.html Look under the section titled damper/door switch.
Posted on Sep 28, 2010
  • jcoon2 Sep 29, 2010
    The doors were level and needed no adjustment. Now the upper part of refrigerator is about 65 degrees and the bottom is about 40 degrees. I am concerned that when we replaced the motherboard, we may have blown it again. How can I tell if the first or second motherboard has gone bad? Should there be something visual to indicate the damage? I hate to give up on this refrigerator, but it is driving us crazy... thanks for your help..
I have a mitsubishi modelrs2545sh sxs . The refrigerator side works but the freezer side doesn;t possibly the control board ?
check several things, the freezer thermistors, the air damper flow control vent and knob, the control board, door seals,
Mar 22, 2015 | Refrigerators
Zis480mnc ge monogram built in refer temp varies from 34 to 48 several times a day.
Try replacing that evap thermistor. The diagnostics on thermistors can be wrong. If it is rounded on the end, replace it. There is a damper between the freezer and refrigerator. There may be a refrigerator fan motor in the damper assembly, It could be bad. It could be a bad control board. When you run diagnostics there is one function that checks all the fans.
Sep 25, 2014 | Refrigerators
Our freezer runs and our fridge has stopped cooling. what part needs to be replaced on our black GE side by side refridgerator model GSS22JEPABB?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 10, 2010 | Refrigerators
I have a ge sxs model #gss22jepcww fride not cooling i removed panel in freezer to inspect coils coils are froze up around coils,I thinking its a frost free problem this model has a circut board in back is...
If you have cold temps and humidity sometimes the coils freeze up and you need to unplug your refrigerator until the ice on the coil melts, clean the coils and plug in, you may overflow your condensate pan, so you might need a towel if it does.
Jan 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator is not cooling
If your freezer is frosting up, fresh food section is warm: bad fan motor,defrost drain stopped up and forming slab of ice between the freezerand the fresh food section. Check heaters andterminator(defrost thermostat) unplug the ice box and let it defrostcompletely. Clear objects from drain. Check timer. Note to find thelocation of your timer look up your model number online here: APPLIANCEPARTSPROS.COM.
Check under the bottom for the fan motor to be running and the cobwebs, dust, dirt, and pet hair, off the condenser coils. If the fanunderneath has quit then the ice box won't get cold. BASIC REFRIGERATION REPAIR MANUAL
AMANA SxS REPAIR MANUAL
BOSCH MANUAL
Monogram Manual
KitchenAid SxS with variable capacity compressor
GE LATE MODEL SxS MANUAL
F&P Reefer
Jan 11, 2010 | Maytag Refrigerators
GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Dec 10, 2009 | Hotpoint HSS25GFP Side by Side...
GE SXS Fridge/Freezer
if the fan in the freezer compartment is not running theres a problem.
verify power to the fan motor, if present replace fan motor.
if not hopefully theres a wiring schematic/diagram so you could trace that circuit back to the control board and verify whether thats bad or not..
WR55X10942 - BOARD ASM MAIN CONTROL
generally though if the fan by the compressor is running the fan in the freezer should also be spinning and have power..
by the way, it states in the parts listing that it is a dc motor
WR60X10074 - Motor DC Evaporator Fan
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | GE GSS20IEP Side by Side Refrigerator
Where is the thermostat on a GE profile refrigerator Side-by-Side
There is no thermostat ( cold control ) on your model refrigerator . It works off thermistors ( 3 in the refrig section and 2 in the freezer section ) . These thermistors , operate by the coldness which in turn , less resistance to the main control board the colder or warmer it will provide .
Sep 12, 2009 | GE Refrigerators
Refrigerator suddenly not cold, freezer seems fine.
Sometimes this happens when the control board located on the back is defective. The board part number is WR55X10656
Visit my web page below and enter the model number GSS22JFPCC into the search feature. We also offer free assistance and help for the problem you mentioned. Click on link below, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 29, 2009 | GE Refrigerators
Refrigerators Logo
185 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
