Question about Dell Latitude D600 Notebook
How do fix my laptop charching point
I woke up last week to switch on my laptop only to discovered that it has charging problem and since then i've not been able to use it. can u pls help me with good instruction on how to fix it. thanks
  • okali May 24, 2008
    system does not recognize external hard disks connected to the usb port as hard disk; printer connected to the usb port malfunctions and does not print completely.
  • primadonna May 08, 2009
    my dell latitude d600 wont charge either and just bought if off line through pricegraber refurbished 3 months ago...i wl neva do that again...can anyone help me?? I tried another batttery and charger light still wont come on but charger works for my daughter's computer.
  • 148 Answers
Most of the time with laptops that wont charge the issue is at the connector either at the cord or where the connector is soldered to the motherboard.  Before you get to any of that please check the obvious first. is the power supply plugged in, does it have it a green light, is it lit. You can try taking the model number of your laptop and finding a replacement power cord like one made by targus.  if that doesnt do it, you will have to take your laptop to a qualified technician for repair.
Posted on May 24, 2008
    Problem Solver:
  • 10 Answers
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
  • 1,027 Answers
If the on board voltage regulating chips are no good and your battery won't charge, MAKE SURE IT IS NOT THE BATTERY THAT HAS FAILED, then the only alternative is an external battery charger, or a new motherboard. External units run from $60-$80 but they will solve your mobile needs. Motherboards are around $160
But, like I said make sure the battery is not the problem. Most batteries have a life span of 500 charging cycles.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
Take the system to a good technician who will check on the charging port, and see if needs to be chnaged or soldered. please don't open unless a reputable and qaulified personel do that. good luck
Bantum rocam 1.6 not charging battery. the no charging warning light does`nt show any mulfanction. is there any fuse or relay related to battery charching ?
removing the battery lead when running is a very good way of blowing the rectifier pack, voltage regulator or line diode
take it in for a charging system check to see what was done wrong
Jan 20, 2018 | Cars & Trucks
I have a newer 58v Echo trimmer. Worked fine last season, but when I use it now it runs for a few seconds and then completes shuts down. If I try again, it runs for a few seconds and stops again.
This appears to be a good news problem. There is an easy fix/work around! Consumer reports found the same problem that you have discovered.
Holding down the check battery switch allows the unit to operate. Read the link around the sixth paragraph the story is told.
Echo Trimmer Can Be Tricky to Start
"Our testers discovered the fix by chance. Pressing the check battery button, a last-ditch attempt to get the trimmer working, made all the difference. While this button ordinarily indicates the battery's charge status, in this case it also served to keep the battery from switching into protection mode and cutting off power to the motor. The next time you fully charge the battery, however, the problem can reoccur."
Hope this has helped?
Feb 27, 2016 | Echo Garden
Okay I have been using my HP G61, for a while now. I bought it 3 months ago. And I used it for college everyday. I used it last night before I went to sleep. I've closed it and left it charging all...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 28, 2013 | Computers & Internet
Can you help me fix my Dell Studio 1558 laptop? It doesn't boot?
Dropping a laptop is never good news. Have you tried to Cold-Start the laptop, unplug. remove battery, leave battery out for now, plug in try to start normally. If that fails, Did you remove the HDD and reseat? The damage from the drops may have jarred something loose. Do you get activity, light blinking, from the HDD? The DVD/CD?
Nov 14, 2012 | Computers & Internet
I left my 6month old pb laptop on. Barge overnight a d when I woke up the next morning there was,what currys said,was an internal crack on my screen,could this happen due to overheating,my pc is only...
Wow, what a bummer. I've never heard of a laptop cracking the screen just because it was left on overnight. Did you leave it on with the Lid closed? Even if you did I would think at some point the laptop would go into sleep or hibernation mode to turn itself down to minimal power usage. Can you see where the crack is? I mean can you open your internet browser and where the crack is things are not visible? If so you surely have a crack, but i still can't believe leaving it on caused it. Anyway since curry won't help you get a quote from your local computer shops, or ask curry for a repair quote, then try the guys at They will repair it and ship it back Fedex or UPS and their price will probably beat any quote including the shipping charge.
Mar 14, 2012 | Computers & Internet
How do i fix problem for p1684
Simply means that your battery was disconnected or got very low at one point in last 50 starts. If you've been having problems with charging system, or battery that has been corrected, it will erase itself eventually after so many starts, if still having battery, or start problems, have charging system & Battery checked.
Dec 17, 2011 | 2001 Chrysler 300M
Can`t get further than switch on
It sounds like the BIOS is no longer valid.
It will have to be re-flashed.
If you are brave enough, download the bios from Toshiba and reinstall it. They have instructions on their site.
Good luck.
Apr 17, 2010 | Toshiba Tecra 500CDT Notebook
2008 maytag refridgerator tripping my breaker
take it back as it's a fire hazard.  Get a replacement.
Apr 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Dell Latitude D600 Notebook Logo
127 people viewed this question
Alun Cox
