Question about Indesit 24 in. D63 Free-standing Dishwasher
Dishwasher Mdishwasher does everything but fill with water makes all the right noises but NO water enters
  • Anonymous May 28, 2008
    my machine will not fill with water, if i manualy fill it and press start, after a few seconds it will begin draining but that is all it will not progress further! iv'e checked the suppy, the pipe, cleaned and flushed the drainage parts all to no avail, it seems it does not get a signal to open an inlet valve or something. any suggestions? the machine is about 6 / 7 years old and has always worked fine up untill this problem many thanks if you can help.
  • 868 Answers
Im shocked this washer lasted this long.Check for voltage at the water valve ,should have about 120V.
Posted on Jun 05, 2008
My dishwasher will not fill with water
There can be multiple reasons why the water is not entering the line. First thing to do is to disconnect both hoses from the dishwasher and place them in the sink. Turn on the water slowly and make sure that both hoses release water into the sink. If the water flows, get a plastic drain snake and attempt to push it into the water intake lines from the rear of the dishwasher to clear any clogs that may be in the lines. Look at the rotary head in the dishwasher for hole clogs and remove any debris found. Reconnect the water lines and make sure that all inlet valves are open. Turn on the water and attempt the fill again. If this does not work, then you will have to disassemble the rear panel of the dishwasher and look closer at all waterline connections.
Mar 06, 2012 | Zanussi 24 in. DA6153 Free-standing...
My dishwasher does not fill with water and makes a tinny rattling noise.
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 05, 2011 | Dishwashers
Kenmore 17621 model--wife says it's making all the right noises,but no water entering.removed bottom panel-no filter visible.obstruction in water supply line is my guess.
Open the door and look for the water level float in the bottom of the dishwasher.
Make sure there is nothing stuck under the float holding it in the up position.
Wiggle the float up and down to make sure it can move freely and then run the dishwasher again to see if it fills with water.
If the float is not stuck up then chances are you will need to replace the water inlet valve.
If you know how to use a volt meter you could check to see if voltage is at the valve during the fill cycle. If there is voltage to the valve but you are not getting any water then you know the water inlet valve is bad for sure.
I find that 90% of the time I need to replace the water valve on dishwasher that no longer fill with water and the other 10% of the time I find the water float is stuck.
Aug 07, 2011 | Kenmore Dishwashers
Makes humming noise and does not fill with water
heatman101
Mar 21, 2011 | Bosch 24 in. SHX46B05 Stainless Steel...
My dishwasher wont fill up with water it does come on and makes a noise but no water
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
heatman101
Feb 13, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
My haier dishwasher is not filling with water just making a loud humming noise
heatman101
Nov 11, 2010 | Haier Dishwashers
The bosch turns on but does not fill with water and makes a humming noise.
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Here is a tip that will help you to find out why water will not come into the dishwasher... <a href="http://www.fixya.com/support/t4715125-when_water_filling_or_rinsing" target="_blank"></a><br />Dishwasher Trouble No Water entering Dishwasher <a href="http://www.fixya.com/support/t4741705-no_h2o_fill" target="_blank"></a><br /><a href="http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering" target="_blank">http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span>
Aug 26, 2010 | Bosch Dishwashers
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Jul 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
NOT WASHING DISHES
heatman101
Apr 04, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Frigidaire Quietclean I "Not filling with water"
Sounds like you might have forgotten to turn the water on to the dish washer... it happens all the time
Oct 19, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Indesit 24 in. D63 Free-standing Dishwasher Logo
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
