My printer is not working properly and not printing what to do
    Problem Solver:
  • 16 Answers
First solution will be you can stop service called print spoller service and start it again. if still is not working then you can uninstall the drivers and try to install it again.
And to stop print spooler services
Go to run type command services.msc
Search for print spooler.
Stop it
And then start it again.
Posted on Sep 28, 2010
My printer does not print
> Install proper drive in you printer number.
> Clean virus in PC.
> Printer data cable check another printer, if cable not ok then problem solved.
> Check printer print setting option.
> Printer print LED active mode check. If not active mode not print output.
> Power section proper working or not.
More Technical Support Visit and call now.
Thanks..
Sep 06, 2013 | Lexmark F4270 Plain Paper Inkjet Fax
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
When i print from hp deskjet D1560 it dose not print. It automatically shows offline when i print even though it is not offline. And it dose not print self test page also. pls give an instant...
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Aug 19, 2011 | Office Equipment & Supplies
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Oct 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
The label prniting is not work properly, print two
you can calibrate from printer driver .Go to printing preference select advanced setup and select Calibrate
Or you can calibrate from printer.go to menu in the printer and select media and ribbon calibration it will calibrate ribbon and label
Aug 06, 2009 | Zebra S4M Thermal Label Printer
Says "document failed to print" constantly after printing half of 1st page
first u check the cable of the printer to system connected properly from both end if not then connect properly , after that problem not solved then change the cable and try if the printer is working then the old cable is faulty , if the printer not ok then uninstall the printer driver from system and restart the system then after restarting the system reinstall the printer driver properly by giving right port, after installing restsrt the system . After restarting the system check by giving a print
Jun 02, 2009 | HP OfficeJet 4215 All-In-One InkJet...
EPSON LX300+II PRINTS THE SMALL FONT & LEFT SIDE
change the fonts of the printer by pressing the font button on the panel (Refer user manual for more details)
Feb 04, 2009 | Epson LX-300+ II Matrix Printer
Ink cartridge (not) installed properly
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printer
try printing a test page. Make sure you have the right driver for your printer. Make sure all connection are secure and tight.
Mar 27, 2008 | Compaq Inkjet IJ650 Printer
37 people viewed this question
k24674
jasbo
jasbo
