Question about EliteGroup Computers & Internet
Hey,I have ecs motherboard p4m890t-M my power led and hdd led and usb1 and usb2 and all other indicators are unplugged and i don't know in which pin s to plug them plz help me
mewms_14904
  • 1027 Answers
SOURCE: pin alignment on motherboard for led switches
Connecting the Front Panel Header
Table 6. Front Panel Header (J9H3)
Pin
Signal
In/Out
Description
Pin
Signal
In/Out
Description
Hard Drive Activity LED
Power LED
HD_PWR
Out
Hard disk LED pull-up (330 ω) to +5 V
HDR_BLNK_GRN
Out
Front panel green LED
HDA#
Out
Hard disk active LED
HDR_BLNK_YEL
Out
Front panel yellow LED
Reset Switch
On/Off Switch
5
Ground
Ground
6
SWITCH_ON#
In
Power switch
7
FP_RESET#
In
Reset switch
8
Ground
Ground
9
+5 V
Out
Power
10
N/C
Not connected
Posted on Apr 01, 2008
  • 13433 Answers
SOURCE: Soltek SL-75FRN2-L how to connect power button..
Front panel connector in bottom right corner, if you look very closely you can see the connector info written into the motherboard in white.
If its too small you need to get the manual for your motherboard to see the connections.
Posted on Jun 25, 2008
compdoctor20
  • 172 Answers
SOURCE: Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Posted on Dec 05, 2008
mbase213
  • 728 Answers
SOURCE: audio problem
Hi reynaldo_sos,
I'm not real sure that your problem is the motherboard. Have you checked to make sure that mute isn't on, and looked inside sound icon in your control panel to make sure that windows recongizes the sound card? If not, I'd check the easy stuff first. And if that doesn't work, you can find the drivers for that sound card HERE! Make sure that's the same version that you want.
Good Luck,
Mark
Posted on Jan 14, 2009
ebay312
  • 118 Answers
SOURCE: MS-7142 motherboard:connecting jusb1 and jusb2 from panel of emachine
I have had some pretty good luck using MSI motherboards.
If you follow this link, you will be able to download your drivers and owner's manual for your motherboard.
You'll find a picture in the manual with instructions for those front USB ports.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=173
good luck
tony
Posted on May 20, 2009
I lost all conection from mother board (USB2 and
there is a label on the mothereboard on what connector you will put..youll see hdd,pwr something like that
Dec 13, 2009 | Foxconn 865G7MF-SH Motherboard
Connecting the power swtch cables and others
I understand from this post that you need to connect the mobo to your casing/chassis.
There is a detailed diagram that can be found on the owner's manual that ships with your board. In case you do not have this, you can find one from this site:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Hope this helps.
Jun 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
How to connect my led lights[that is the red nd green light ] with my 865 chipset''......where r those pins on the motherboard ??
in *********** board where the reset & power botton is connected same place you can find HDD LED for Harddisk and Power LED for power, please be carefull with the sign designation about (+) and (-) it is indicated in the board and pin.
Jun 12, 2009 | EliteGroup ECS 865PE-A7 Intel 865PE...
Tower top mounted USB portss
The cables from the front panel USB connectors have a key in them that will line up with the missing pin on the board's USB headers. Just line up the connectors and plug them onto the board. It doesn't matter if you use USB1 on the board for the plug marked USB1.
Apr 12, 2009 | Computers & Internet
Abit Kg7-Lite motherboard USB2 pin Locations desperately needed!
Lay case down with the bottom in front of you. Looking straight down at the row nearest the case bottom reading right to left there will be two rows of four pins.
Reading right to left the row closets to the case bottom the first lead is vcc1, next usb1-, next usb1+ and grnd1.
Top row reading right to left is vcc2, next usb2-, next usb2+ and grnd2.
I just replaced bad caps on my kg7 and had to remove the motherboard for the repair so I just reinstalled my front case usb ports.
Help this helps.
anon paranoid
Feb 18, 2009 | Abit KG7-Lite Motherboard
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Need to connect Mercury PVM900M motherboard cables
my name is Allan kaitila from Tanzania
I bought a motherboard Mercury PVM900M,but i dont know how to conect it.
So may I have its Diagram that shows
The following wires and send it to me through allanafricanboy@yahoo.com
1. SYS_FAN
2. CPU_FAN
3. ATX_12V1
4. POWER SW
5. RESET SW
6. H.D.D LED
7. POWER LED
8 MIC
9. L-RET
10. L-OUT
11. R-RET
12. R-OUT
13. G
14. USB1
15. G
16. USB2
17. G
18. SPEAKER
Feb 25, 2008 | Mercury P4VM800M7 Motherboard
Power switch
You could try searching for the manual for the motherboard, I have the same problem every time I disconnect a motherboard.
Sometimes it is printed on the motherboard in dead small writing which wire goes where.
Also usually motherboard manufacturers follow the "unofficial" standard io connectors.
+PLED -PLED +PSW -PSW NC NC NC NC
+HDD -HDD -RST +RST +SPK NC NC -SPK
Key:
PLED = Power LED/Message LED
HDD = Hard Drive LED
RST = Reset Switch
PSW = Power Switch
SPK = Speaker
NC = Not connected (sometimes not even there)
Note quite often the Reset switch is the reverse of everything else! (i.e. on most if the + is on the right the + is on the left for the Reset
The USB ones usually always follow the following standard
VCC -DATA +DATA GND NC (USB1)
VCC -DATA +DATA GND NC (USB2)
And usually one of the NC pins is no pin as some USB cables have that pin blanked out to ensure you connect them the right way. Note also with USB you start with the VCC then you go straight to negative data, then positive, then ground (again the - and + data bits, like the reset are in reverse of normal reading - the are right to left, not left to right!)
Finally if your not sure which cable is + and which is - the - ones are normally either black or white (most of them are white, except the speaker ones which are black - I presume that goes back to the colour scheme of red and black for positive and negative in audio equipment) and the + ones are normally some colour.
Dec 11, 2007 | Abit nForce2 NF7-S2 Motherboard
P4mmv2 motherboard
see the diagram below for front panel conections
Sep 02, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
188 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
