Hi. i cant connect to print server d-link dp301p+ IP to configure it?! who knows what IP by default it have? 192.168.0.10 doesnt work... Thanks, Mike
    Problem Solver:
  • 12 Answers
First find out the IP address , Subnet mask,and Gateway addresses of your ISP ( Internet Service Provider ). According to above addresses, you have to complete the network settings of your printer by mentioning the different IP address .
To find out the above mentioned addresses, first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , the gateway may be 192.168.0.1 Or any number. And the subnet mask may be XYY.XYY.XYY.0.
According to your ISP addresses you have to complete the network settings of your printer. First press the additional functions -> system settings -> network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your network connection with the printer to your computer will be automatically solved.
Posted on Sep 28, 2010
TL-PS110U. Can't find my print server
Type IP address (ex. 192.168.0.10) directly into your browser...should identify it and give you some direction on the problem..
Jul 04, 2011 | TP-LINK TPLink Single USB20 PORT Fast...
How to access homepage of dlink DP-301 P+ print server, when u have forgotten its ip address
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Mar 07, 2011 | D-Link DP 300 (DP-300) Print Server
I have print server DP-301U Pls let me know the default IP address for configuration
Hi
As far as I can remember the default IP is 192.168.0 .10, subnet 255.255.255.0
If this isn't the correct IP address, you'll need to reset the d-link print server Hope this helps
Regards, c0d3
Feb 09, 2011 | D-Link DP 301P (DP-301P) Print Server
How do I connect with my WGPS606 if there is no setup cd and the default ip does not work? My router has encryption and the WGPS needs the info.
you need to set your print server for dhcp, you need to log in and verify the settings OR just set it back to default because dhcp is default. gl
Nov 06, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
How do you connect to the DP-311P to reset it when you don't know the proper IP address you can't open its engine even when the wireless is connected
Hi you can Verify IP address and port information on the print server by using either telnet or PSAdmin.however you can try using the the default IP address is 192.168.0.10. Let know if it helps?
Apr 09, 2009 | D-Link Air DP-311P Print Server
Can we reset ipaddress of fast ethernet 301p print server can u please help me.
put the current IP in your browser and configure it as per the manual
ftp://ftp.dlink.com/Printserver/dp301p+/Manual/dp301P+_manual_101204.zip
if you do not know what the current IP is, try using the mapping in Vista Network and Sharing center, your security suite, or log into your router and look for attached devices (also the drivers that are already installed for the printer should show the IP Port
Feb 03, 2009 | Computers & Internet
D-Link DP-311P Wireless print server reseting
Hi Luis,
Sorry, it had been my mistake, did not realise your model does not have ethernet port at the back.
On D-Link printer servers that do not have cable connections it requires a couple more operations, you must do the following to connect safely to the server and open configuration:
  • On the rear panel of the DP-311P you fiind a switch to set server to Config mode. Set the switch to
  • Now go to the computer that is connecting wirelessly to the D-Link, go to wireless adapter properties, for example using control panel, and set the adapter to Ad-Hoc mode.
  • Change manually the wireless adapter IP Address so that it is in the same IP Address range
  • as the DP-311P, set the wireless adapter to a static IP address comprised within 192.168.0.2 and 192.168.0.255 excluding 192.160.0.10.
  • Always in wireless adapter settings >> IP configuration, set subnet mask to 255.255.255.0.
  • Ensure you click OK, or Apply in network settings Window, and restart the computer to apply new network settings.
  • Open Internet Explorer and type the IP Address of your wireless print server in the address bar. The default IP Address is 192.168.0.10.
You also find procedure explained at page 7 of the user manual here : D-Link DP-311P
Then follow instructions at page 15 to reset the server.
After you have finished configuring the DP-311P, to save the changes, you must toggle the mode switch on the rear panel of the print server back to “Normal” mode.
Oct 25, 2008 | Office Equipment & Supplies
Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
I went and got static IP addresses from internet provider...Must of caught them on a good day
Apr 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
Cant find the Print Server IP
when you tried to ping the restored ip for the print server did your computer was in the same subnet? if not try to configure your machine ip to be in the same subnet for your print server ip.
Jun 14, 2007 | Hawking HWPS1UG Print Server
Emulex NetQue Pro2 Print Server how do I connect to it
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Oct 04, 2006 | Emulex NetQue Pro2 (NP02) Print Server
Computers & Internet Logo
447 people viewed this question
David Payne
David Payne
