Does not come on......i checked connections and they seem ok
I have had sucess by unplugging the power cord for a few minutes and plugging back in. Sometimes may take several tries.
Posted on Sep 30, 2008
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
How do I get my eurorack 1622 to work
Evidently it is not connected correctly or it would have sound. Take to a car steep installer and have them check it. Probably won't cost more than $50 and it might just save your car's electrical system.
Nov 25, 2014 | Vacuums
The motor of crazy fit vibration massage does not work, only the panel lights light up
Without knowing what vehicle you have it is not likely anyone can advise you.
Nov 23, 2014 | Cars & Trucks
I've put the batteries in the battery compartment but the motor does not work
Do u have it in the right way around?? The bigger battery terminal should have a next to it , and that connects to the red cable. The smaller terminal should have - and black cables
Dec 26, 2011 | Cars & Trucks
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
Hotpoint WT761 washing machine - Error code F-10 The machine is filling with water, then signalling F-10, then pumping the water out. So the fill solenoid and the pump are working OK. If I set the machine...
Thats strange, F10 means no cold fill.
Ok back to basics, you can check the pressure switch by taking off the tube and gently blowing into it and I mean gently, you should hear a click if its ok - make sure the other end is'nt blocked, blow it out with a cycle pump near the drum end
Sep 19, 2009 | Washing Machines
Computer doesn't seem to recognise LG KU990i via usb
first check ur usb port that is it ok? sometimes some usb has problem when it become old. then check ur usb cable is that ok? if everything are ok then format ur pc and install usb 2 software for ur usb system. thanks
Aug 08, 2009 | LG KU990 Viewty
Machine will not power up
power out let ok ?
fuse on the power cord ok ?
if all ok then it could be the internal fuse in the power supply unit
dont try and replace it you need a new 1
Mar 24, 2008 | E-Machines eMachines T3830 PC Desktop
26 people viewed this question
jasbo
jasbo
