How to format my c drive help by dos - Computers & Internet
    Scholar:
  • 99 Answers
If you are running DOS(Command prompt) in Windows, your windows Operating System is installed in C drive and is Up and running then it is impossible to format the C drive because the whole thing is running in C drive and windows won't allow you to do so.
But if you are using a separate DOS O.S. and want to format C drive and If you want to format any other drive than c drive when your system is up and running then you can use the FORMAT command followed by the drive letter that you want to format.
here is an Examle to write in DOS..
Format C: /q
you can replace the C letter by any drive that you want to format. The /q Option is use to perform Quick Format. Here is a list of mostly used Option
Formats a disk for use with Windows.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/C] [/X]
"volume" Specifies the drive letter "/FS:filesystem" Specifies the type of the file system (FAT, FAT32, exFAT, NTFS, or UDF). "/V:label" Specifies the volume label. "/Q" Performs a quick format. "/C" volume will be compresse by default. "/X" Forces the volume to dismount first.
Hope this will help for sure.....cheers:)
Posted on Sep 28, 2010
I have a IOMEGA 1TB hard drive, and I formatted It and it gives me only 92.7MB free out of 92.8 MB and not the full 1TB and I'm using on my PC windows 8 pro and It won't back up all my files what do I do?
I would connect drive and from dos prompt run diskpart. Make sure you have extended dos partition that has the entire drive space. You can type at the dos prompt: diskpart ? for help. Once you have partitioned the whole drive format it with NTFS.
Oct 25, 2013 | Iomega Prestige 1 TB USB 20 Hard Drive
When Formatting the C: in DOS (Format C:) what does it mean when you get the following error: Format cannot run because the volume is in use by another process. Format may run if this volume is...
If the computer is running you will not be able to format the C: drive. You will need to restart the computer with a boot disk, boot to a DOS screen, and format C: drive from there. Just remember this will wipe everything on C:, including your operating system, so you will need your windows reinstall disks handy.
Jan 10, 2011 | HEWLETT-PACKARD HP G71-445US Notebook
I installed just as the instructions said and i cant get my pc to recognize my 1.5tb hard drive
First download this disk iso and add fdisk to the disk and burn ituse this link:
http://www.bootdisks.us/ms-dos/5/ms-dos-bootable-cd-images.html
download fdisk from this link FDisk 6.22
http://www.uv.tietgen.dk/staff/mlha/Download/dos/#FDISK
Once you have downloaded and burnt the disk, make sure the drive is showing in the bios, then set to boot using the cd/dvd-rom and insert the disk.
When loaded, at the command prompt type fdisk, find the 1.5tb hardrive and create a primary dos partition, it may take a while so be patient, once done take the cd-rom out of the drive and reboot the mechine, goto my computer and you should see the drive, and it will have a drive letter next to i. It want contain anything as it has not yet been formatted.
To format just right click on the drive and choose format, choose ntfs and press ok, it takes a while so again be patient, and you should now have a usable new drive. hope this helps, any problems post back.
Apr 06, 2010 | Koutech Systems IO FLEX-PSA150...
How to format only C: Drive( in NTFS) in 160 GB Hard disk
It sounds like you are booting into DOS. Dos is an old system which does not recognize NTFS partitions, only FAT/FAT32.
What you need to do is use Hiren's Boot CD (download off google).
Use it to boot and use the NTFS4Dos utility first. Then start Dos:
Or once you boot into Dos mode with the CD, type:
A:\>NTFS4DOS
.............it will list harddrive partition letters.........
A:\>C:
The above may look different as A:\> can be any drive the cd assigns. C: is also an example as you will see your drive letter in the list of harddrive partitions detected.
If you need more laptop computer repair help please visit our Tech Tips page at http://www.laptopmart.ca
Mar 09, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Cannot format hard drive on my T40. How can I tell
Depends on what kinda format u doing..if it's thru the XP Disk ..if it is stuck at certain stage for too long and can hear rattle sound near the HDD ...it's mostly HDD error..Try dos format using dos bootable...or i would try installing Windows NT old version and upgrade..it helps huge some times..hope this is help full..good luck..cheers
Dec 14, 2009 | IBM ThinkPad T40 2373 Notebook
Giga ONe hard drive reformat
You can format your giga one hard drive in MS-Dos mode.
1. Go to Start--> Run
2. type CMD to enter the DOS
3. select the giga one drive path (i.e. if it shows as E drive then simply write E: in DOS and hit enter.
4. type format
thats all that you have to do to format the giga one drive.
Jul 28, 2009 | Jobo GX1040 GIGA ONE Silver 40GB Portable...
Not able to format 32gb kingston usb pen drive
go to start>
run>
type cmd
ms- dos window appears
if your drive is g: then type following codes on dos
format g:
y
either your drive is f: then
type
format f:
y
donot forget to rate if it becomes formatted
by Nischal nisc
if you are using vista then
go to my computer right click on my computer
manage>
then you can format by entering device manager
Mar 29, 2009 | Electronics - Others
I have 8GB pendrive of transcend. when ever i want to format it, screen shows that window is unable to format it. i have window XP SP2
format it by dos
start>
all programs>
run>
type cmd
format it by
format g:(you type in ms -dos)
if you drive is f then
type
format f:
Mar 20, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I need to know how to reformat my acer extensa 4220. I have no boot disk and I have a virus that is not allowing me to see my system information or MYcomputer and so forth
first create a boot disk.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
You Will Have your own Boot Disk.
Backup Your Data.
Boot With the help of BootDisk.
Load a new XP.
Virus Scan All the Drives and Data.
Sambeet
Sep 19, 2008 | Acer Computers & Internet
Computers & Internet Logo
David Payne
David Payne
