My RX520 has now come up with error message E-02, meaning the cartridge/s arn't correctly installed..but yesterday it was printing fine. I've removed and re-installed all 4 cartridges and even replaced all 4 with the same non-Epson brand, but I still get the same message. Epson themselves say to try their cartridges...what a surprise...but as the machine's now 4yrs old and worthless that's an expense too far. Ideas anyone?
SOURCE: Missing Toner Cartridge
Try first removing all paper from paper trays and then reinserting cartridge, etc.
Posted on Nov 09, 2008
SOURCE: Epson R320 printer will not recognize any of the ink cartridges
I tried two things of which one solved the problem. I am not sure which. Secondly, I have an R260 printer which is a less featured member of the printer family uses Claria inks like R360 and R380. I called Epson and they simply sent me replacement cartridges for the two black ink cartridges with which I had a problem. My printer did not recognize these new cartridges either. I noticed that both the ones I bought and the replacement ones have a slot hole near the green chip on the cartridge. The empty cartridge did not have this slot. They just had some circular depressions. So, I put a piece of masking tape over the slot and tried again but still no luck. However, when I removed the cartridge, this time a small piece popped out. This piece connects to pins on both sides. So, it is obviously an interface between the cartridge and the printer. I pressed this piece back in, replaced the cartridge with the tape on it back it and, voila, it works. Most likely this interface piece was loose and simply pressing on the cartridge didn't get it in far enough or who knows. You maybe able to take thiis piece out and replace it or merely push down on it with a pen but first, flash a light on it first to see if it is not sitting awkwardly.
Posted on Apr 13, 2009
SOURCE: Keep getting Toner Life End Message even after replacing with brand new cartridge. I'm sure it is installed correctly. The Brother 7420 machine won't recognise the new cartridge(TN2025).
Open front cover and hit "Options" button, you should see a prompt to "Change Drum". Don't hit 1 for yes or 2 for no. hit the "Start" button and then put in the number 11. You should see the word "Accepted" in the window. Close front cover and you should be all set.
Posted on Jun 08, 2009
SOURCE: Canon MP210 getting E5 message with PG-50
Sadly Canon cripple many of their printers so that they will not accept the high yield cartridges such as the 50 & 51. As a result your printer the MP210 will only accept the 37 or 38 cartridges which are only half filled, or the 40 and 41 which are fairly full, but don't contain as much as the 50 & 51. All I can suggest is that you could try to sell the 50 on eBay, and send a strongly worded email to Canon.
Posted on Aug 26, 2009
SOURCE: epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
Posted on Sep 21, 2009
How do I fix e07
I assume you have a Canon copier based on the E007 error code. The Fuser fixing film is torn and the Fixing film assembly or the entire fuser should be replaced. Very common issue.......You cannot reset that code without first replacing the part causing the code.
Dec 03, 2014 | Office Equipment & Supplies
My MP490 is saying that I do not have the print head installed. It worked fine when I last used it on yesterday. Today nothing! Can anyone help with how to lear the message?
The printhead not installed error means that the printhead and the printer itself are not communicating properly. This could be a temporary system error, the printhead (cartridge) having failed or the printer needing service.
Make sure that both cartridges (color and black) are installed correctly and are the Canon cartridges for this printer. Replace if they are low or have clogged with ink from going unused. (Note: the color cartridge goes on the left and the cover for each cartridge should close with a click and be flush against the cartridge.)
To check if this is a temporary error, with the printer on, unplug your data cable (USB), then remove the ink cartridges. When the printer indicates "Insert ink cartridges", unplug the power cable from the back of the printer. (I tend to unplug the data cable from both the computer and the printer and the power cord from the wall after removing it from the printer as well.) Wait a minute then plug the power cord back into the wall outlet (if unplugged) and then into the printer. Turn on the printer if needed. Then reinsert the ink cartridges when prompted to do so. (Make sure to fully seat the cartridges.) Close the scanner unit and print a calibration page if you see a prompt for one. Then reconnect your USB cable and try printing a job.
If this doesn't solve the problem, then decide if the printer is worth servicing if it is out of warranty or conact Canon if it is in warranty.
I hope this helps.
Aug 12, 2011 | Canon MP490 InkJet Printer
10.1000 supply memory error
hi,
10.00X is the error code displayed when
  • Cartridge is not installed correctly
  • Use of refilled cartridges
in your case x is 0 which means that black color cartridge had a problem
problem may persist in slot holding black cartridge and /or in the cartridge
just do steps below
solution 1: check all cartridges are in right slot it is better to remove and fix it again
solution 2:
clean the surface of metal contacts with lint-free cloth
the image below will show metal contacts
solution 3: Insert the problem print cartridge into a different slot
Follow these steps to determine if the print cartridge or the slot it sits in is causing the error.
  1. Open the print cartridge door completely.
  2. Press the blue handle on the print cartridge drawer to release it, and then pull the drawer out completely.
  3. Remove one of the non problem print cartridges from its slot.
  4. Install the problem print cartridge into the empty slot.
  5. Install the other print cartridge into the slot of the problem print cartridge.
  6. Close the print cartridge drawer completely.
  7. Close the front access door completely.
  • If the error message persists , replace the problem cartridge with new one(problem is in cartridge)
  • If the error message is gone , contact HP to troubleshoot a faulty slot.
regards,
cseian
Dec 16, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
I have the same problem but mine is with a canon mp190. also says E5 error on lcd and 2,114,0 eror when i try and scan. what can i do
According the Canon the error code means this:
E, 4/ E, 5 The FINE Cartridge cannot be recognized
The FINE Cartridge may not be installed properly, or the Cartridge may not be compatible with this machine. Open the Scanning Unit (Cover), and then make sure that the FINE Cartridges are installed properly and that the installed FINE cartridges are compatible with the machine.
If the error is not resolved, the Print Head may be damaged. Contact your Canon Service representative.
The "fine cartridge" means the black printing cartridge. The black should be installed on the left and the color on the right.
Double check to make sure your cartridges are installed on the correct sides.
After verifying that they are on the appropriate sides, then turn off your printer and unplug it from the power source.
Remove and reinstall the black cartridge.
Plug the printer back in and turn it on. If the error code is still there, press the menu button and scroll using the arrows until you see the "maintenance" area on your printers display. Then press enter or "ok". Continue scrolling until you find the "clean print heads" function and then again press enter or "ok" Follow the instructions and clean the print heads at least two times.
If the cartridge is full and installed correctly, the according to Canon the print heads have trapped old ink in them and this could be cloggin the ink flow. Cleaning the print heads should solve that problem. If you still get the error code after cleaning the print heads a couple times then I suggest contacting Canon for a possible warranty repair.
Nov 25, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Try to print but: get General Printer error 0x61000f6
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Jun 22, 2010 | HP Photosmart C3180 All-In-One InkJet...
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Wrong cartridge message
It appears that the problem is not in the ink cartridges at all but rather the print head assembly. Upon disassembly of the print head it can be discovered that the thing appearing to be a logic chip, is probably responsible for several standard commands including cartridge status. One should replace the printhead and then followed the instructions on aligning the printhead. This solves the problem. It can be  bought from Canon for about $45.00 including shipping. Hopes this helps. Thank you, Have a nice day...!
Sep 19, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Message on Epsom Stylus DX6000 reads E-02. How to fix?
E-02 is an ink cartridge error, possible causes incude faulty ink cartridge chip, incorrectly installed cartridge, dirty contacts, ribbon cable not fitted correctly to carriage or faulty CSIC board in the carriage.
Your first step would be to remove all of the cartridges and clean the contacts and cartridge chips with contact cleaner or alcohol wipes. Refit cartridges ensuring that they all click into place and check the ribbon cable into the carriage is secure.
Hope this helps, please take a moment to rate this solution. Thanks.
Mar 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Nov 26, 2008 | Lexmark C510 Laser Printer
331 people viewed this question
jasbo
jasbo
