Question about Samsung Televison & Video
On my Samsung 32" tv model #lb-t3253h,when I turn on the power the red power light flashes a few times then goes back solid red,but the tv does not turn on .what could be causing this?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Blinking light means that the power is getting to the unit however, as its not working which means that the power board should be checked. To start with open the back of the unit and then check the power supply board for any bad (bulged/swollen) capacitors. Power supply board is the board where all the power cords/plugs goes into. After you have checked that also check the main board and if you can use a multimeter to test the components on these boards. However, from your earlier posts it seems to be the main board that is bad and should be replaced. All this should only be done if you have knowledge of internal circuitry of the unit as the components consists high voltages even when in off position. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 28, 2010
Samsung ln46c530 lost picture, now won't turn on. Indicator light turns on solid red when on, flashes five times when shut off
The fault is with its main board itself. Troubleshooting to this board is not an easy work to a user can do. It will be best to contact any service technician. google.com/+GopakumarGopalan
Nov 24, 2013 | Samsung LN46C530 TV
I have an lg plasmas model # 42pc5d-uc the tv is not turning on. When I push the power button the red light flashes a few times I hear a click & nothing happens it goes back to a solid red light...
All put the name in with the model. Its a LG .Your power supply is down. This could be capitator or transitor bad if the caps are swelled up replace them with the same value .
Mar 01, 2011 | Televison & Video
When i try to turn it on, the light that's red flashes blue a few times and then goes back to red. Nothing else happens.Otherwise the tv runs fine. It's happened before a few times and after a little bit...
That's a classic problem with the Polaroid TVs.
Most of the time it is problem with the power board, but there are a few models - particularily 37'' ones - where the main board goes away.
It will help to know the model of the TV to provide better help, but I bet if you simply google for it you will find the answer yourself.
The 32'' Polaroids from a few years back are *notorious* for this problem.
Bobby, www.coppelltvrepair.com
Mar 15, 2010 | Polaroid Televison & Video
When i plug in my samsung 32 lcd the power button just flashes red. sounds like it trying to turn on but just flashes red light.
Check your manual that came with the tv. You can try resetting by usually unplugging a few minutes, then plug in and hold the power button on for a few seconds when you turn it back on. Check manual, though; they're all very different/
Nov 17, 2009 | Samsung LN32A330 32 in. LCD TV
Samsung TXN2668WHF Does not power on, blinking red light
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 10, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
Samsung LNT4665FX LCD-Clicks before coming on
Bad power relay get it fixed before you have more issues the psu cost around $25 bucks on ebay good luck!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 15, 2009 | Samsung LN-T3253H 32 in. LCD Television
My flatscreen emerson tv will not turn back on.
I found a way around this problem. When this happens, don't use the remote.
Walk up to the TV, then HOLD DOWN the power button and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
Then your screen will turn on. No idea why this works. Just stumbled on it while getting ********** that this TV, I had less than a month, suddely would not come on anymore. I was about to unplug the whole thing to take back to WalMart and just started pushing button combinations and found this worked.
Mar 30, 2009 | Emerson LC320EM8 32 in. LCD TV
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Open Questions:
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
