Question about Lexmark X5495 All-in-One &USB Cable/Ink/Paper/Software InkJet Printer
I own a Lexmark X5495 printer. for the past 3 days, any time I try to print, I can't b/c error messages appear on the screen and on the printer that 'Left Cartridge Incorrect'. Both cartridges are relatively new and they were working fine.
  • Lexmark Master
  • 17,130 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . press down the cartridges to contact before it is reset back to the PC.
Posted on Sep 28, 2010
Ihave a Lexmark x5495 It says left cartrage incorect Its a genuine Lexmark cartrage
It could be just a slight communication problem between your cartridge and the printer. Try to remove the left cartridge from the printer > close the printer cover > unplug / re-plug the printer into the power source to reset it > when the printer turns on, reinsert the cartridge and then close the cover. If no error appears, try to print a document to verify that the problem is fixed.
You may also try to insert your old cartridge or a different known working cartridge to determine if it's a faulty cartridge issue.
If you still need assistance, please contact Lexmark Technical Support Center.
Sep 12, 2011 | Lexmark X5495 Printer
What is error #1203 and how can it be fixed
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads. Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X5495 Printer
Is the Lexmark x5495 wireless? If it is, how do you connect it to a laptop. I lost my installation disk.
The Lexmark X5495 printer is not a wireless printer, however, you have the option to connect it to a wireless print server. You can then connect the wireless print server to your wireless network so all the computers connected to your network will have access to the printer.
To connect the printer to your laptop, please visit the Lexmark website at http://bit.ly/hsBChY to download and install the printer driver. Execute the file and follow the instructions on your computer screen.
Aug 11, 2011 | Lexmark X5495 Printer
My lexmark 5300 all in one gives me a "web gateway encountered a problem..." message and the printer's functions will not work.
Does your printer print when you try to make a copy using the Copy button on the printer operator panel? If yes, then it could be a printer driver problem. Try to re-install the printer driver on your computer. You can download the Lexmark X5495 driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file. After the installation is successful, try to print again.
Jun 14, 2011 | Lexmark X5495 Printer
Trying to scan I get the error message ''A Sharing violation occur
Create a new windows user account .Try to scan the document in the new admin user account.
Aug 17, 2009 | Lexmark X5495 Printer
Lexmark x5495
Lexmark does not allow refilled cartridge on any of their products.
Lexmark, HP and Canon and-many other vendors use proprietary code to protect themselves against the damage of OEM inks.
All companies will void warranties.
Apr 24, 2009 | Lexmark X5495 All-in-One &USB...
Lexmark X5495 Feeds paper in part of the way
I own this printer, it has to do with how you load the paper, it's very touchy, just keep readjusting the paper and you will get it right, you don't want the paper to far into the printer, or you will get a paper jam error, but if it's not in far enough it will sound like it's printing but not feeding the paper. Hope this helps, Julia
Dec 21, 2008 | Lexmark X5495 Printer
Refilling Ink Cartrdige failer!
I have a Lexmark X5495 printer and I had it refilled a couple of weeks ago, suddenly i have a message that goes "Order new ink" or something and i check the cartridge but it is still full. I try restarting the printer and even the computer but the printer STILL won't let me print.
Oct 11, 2008 | Lexmark X5495 Printer
Lexmark Printer Install - No Communication Error
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jul 19, 2008 | Lexmark X1150 All-In-One InkJet Printer
is the printer in its own USB port? Some printers that "talk back" to the PC do not like to share a port so do not have it on a USB HUB.
Apr 17, 2008 | Lexmark X2500 All-In-One Printer
Lexmark X5495 All-in-One &USB Cable/Ink/Paper/Software InkJet Printer Logo
149 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
