Question about LG Televison & Video
The television does not power up - LG Televison & Video
  • LG Master
  • 17,130 Answers
Your power supply is not working and so it can be a failure of the SMPS. I have some tips for repairs please checkthis link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Sep 28, 2010
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Hey there! Just replaced the lamp in my sony KDF70xbr950 and now it will not even come on I have 4 flashing red lights and then goes back to a solid red light can some one help!! ...
    The LAMP light is flashing or blinking.Solution
    If the LAMP light is flashing, first attempt to perform a power reset on the television. If this does not resolve the issue, then the lamp inside the LCD projection television may have burned out and will need to be replaced. If this appears to be the case, consult the Replacement Lamp Part Number table to determine the correct replacement lamp for use with your projection television.
    NOTE: The LAMP light is not the same as the POWER/STANDBY light.
    How to perform a power reset on a Sony® television.Solution
    Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.Unplug the television power cord from the electrical outlet. Let the television remain without power for 60 seconds.Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.Turn on the television.
    Sep 16, 2011 | Sony Grand WEGA KDF-70XBR950 70" Rear...
    HAS NO POWER AT ALL
    If your television is totaly no power,first step to do is to check the power outlet if there's a power output.Then check the power cord,if good,the problem is inside the television.Maybe the fuse is busted.So remove the back cover of the television and find or look the power supply.The fuse is located at the power supply.Replace same amphere of fuse if busted or open.Try to power on if you already replace fuse.Thanks...
    Aug 21, 2011 | Hitachi 42HDS69 42 in. Plasma Television
    Will not power up
    If your television will not power up, there is just one problem related to this, and that is the power panel. But before You confirm it is the power panel, You will have to run a test on some components to be sure that it not other components before You go ahead to replace the power panel of the television. The components to tests are the power outlet, check if the voltage is not too high or too low to power on the television. Then You also test if the cable that connects the television to the power outlet is not bad by using it on another television and trying to use the another power cord on the television, then You confirm if it is not a blown fuse on the power cord. Once that is confirmed, then You can go ahead to replace the power panel of the television. To replace the power panel:
    1. Get a screw driver, a glove a cup and a replacement power panel,
    2. Unplug the television and put on Your gloves,
    3. Turn to the back and unscrew it open,
    4. Keep all screws in the cup in order for them not to get missing,
    5. The power panel is the panel that the power cord is attached to at the back of the television, remove it,
    6. Fix in a new one
    7. Reverse the process to reassemble the television back together,
    8. Plug it into the power outlet and power on the television.
    It should turn on now.
    Hope this helped. Thank You for using FixYa!!!
    Jan 21, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
    Sony kp-61V45 will not power on but you can hear static coming through the speakers. The power button will not light up
    The problem with the television is from the power panel of the television, it is receiving power but not getting it to the main panel of the television so as to power the screen that is why you are having the static sound from the speaker of the television.
    Once you can replace the power panel of the television, your television will be in good condition once again. You can locate the power panel, it is the panel the power cable is connected to, so once you open up the back of the television, then trace the power cord to the panel it is connected to.
    A replacement will do the job.
    Take care
    Oct 10, 2010 | Sony KP-61V45 61" Rear Projection...
    Dead set, no power
    It is obvious that the television is not receiving power from the source that is why you have no power at all.
    The problem is from the power panel of the television. So what you have to do is replace the power panel of the television, by doing so, your television will be in good condition once again and would be able to power up.
    Take care and good luck
    Oct 09, 2010 | Televison & Video
    The power cord was crushed and no power is getting to the tv. Is the plug able to be replaced as this has happened below the splitter???or whatever the thing is on the cord. thanks Shelley
    If the power cord comes off the television you can replace it with a standard power cord. You have to tell the Radioshack employee how many volts and hertz. That should be on the back of the television. If the power cord does not come off the television you can find someone perhaps a tv repair guy that can attach another power cord to the one on the television. My dad actually did that when his older television would no longer power on. He took the bottom part of a power cord from a fan that was no longer working and attached it to the television's power cord. It has been working like a charm ever since for years.
    Sep 28, 2010 | Televison & Video
    No picture or sound?? status light flashes in four blinking intervals. I was told it could possibly be the lamp it has never been replaced.
    The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
    1. Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
    2. Unplug the television power cord from the electrical outlet.
    3. Let the television remain without power for 60 seconds.
    4. Plug the power cord back into the electrical outlet.NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    Aug 08, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
    TV Zoom mode
    Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
    Then, always try the quick reset:
    1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
    4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    May 16, 2008 | Sony KV-32FS13 TV
    No video, no audio, only blinking red light on standby power
    The STANDBY light is flashing on the television and there is no picture or sound. Solution
    sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
    If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
    OR GO TO SONY.COM, TROUBLSHOOTING, OR THE FANS NOT WORKING.
    Aug 16, 2007 | Sony KV-35S42 35" TV
    Televison & Video Logo
    87 people viewed this question
