Question about Intel Motherboard
Sata with xp>>>>>>
Win xp>>>do,nt setup with sata anlees putting FLOPPY
    Scholar:
  • 160 Answers
for solving do the following
1. Get the XP Cd having the latest service pack 2 or later
2. Place the CD and follow the instructions for installing the XP
Let me know if your problem is solved and rate me as FIXYA!
Posted on May 24, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 202 Answers
Check your copy of xp cd if it is bootable or try and go to bios setup and enable the first boot to be cd-rom, atapi cd-rom. But it is really obvious that your xp copy is not bootable.just try out the procedure above. good luck
2 Suggested Answers
  • 7 Answers
SOURCE: ASUS P4P800S-X SATA problem
It could be a bios thing have a look a there for a option to chage from IDE to SATA
Posted on Apr 03, 2012
Testimonial: "It was BIOS... not the options, but the version, althought it was a very good tip... Thank you!"
Instal xp on panasoc cf 71
had same problem with loading win xp proff on cf 74 toughbook mk1.
soution for me was downloading sata hdd controller from panasonic toughbook support site, loading the driver onto floppy drive, using usb floppy with driver ready to use, loading win xp profesional and on first loading win screen pressing f6 when prompted at beginning of win intallation, when on screen instructions to load sata driver appeared, i followed on screen instructions and loaded 3rd option from floppy sata drive mobile driver, left usb installed untill xp loaded and running, do not remove usb floppy untill win loaded, i really hope this helps you
Mar 25, 2013 | Panasonic Toughbook CF-27 Notebook
Mar 31, 2012 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
Hi i have a Toshiba Satellite Pro L300 i have reformatted the hard drive and am trying to instal windows xp Professional Genuine CD. I can access bios utility no problem and i start install for winxp it...
This because you dont have AHCI drivers required for Win XP and you set in BIOS either sata controller or ide controller to an AHCI. You must set to native IDE or anything else like that.
If you wish set an AHCI driver you must press F6 during starting windows XP setup. And put the drivers (get it here) to floppy disk, it will prompted to install required drivers..
Another way to install driver without floppy disk you must inject the driver to windows XP installation CD...
P.S : you cant put the drivers onto floppy, because it wont be read by Windows XP setup..
Aug 08, 2011 | Toshiba Satellite Pro L300 Notebook
Am trying to reistall Win XP. Have run Fdisk and reformatted HDD. PC will not recognise install CD, keeps coming up with errors, does not find CD or HDD. Hav also tried running setup from floppy, again...
IF the hard drive is a SATA hard drive, you will first of all need to download the SATA drivers for te motherboard and copy them to a Floppy drive on another computer if yours will not work, this may also affect why it is not "seeing" the Cd drive if this is a SATA one too
Try installing Windows and when the message " press F6 if you want to ...." appears, have the floppy inserted in teh floppy drive so it can find thr SATA drivers, it will then recognise the Hard drive and install
If you have further problems please repost
Jan 03, 2011 | Gateway GT5056 PC Desktop
I want istall win xp o/s so i need to change bios setup to detect the hardisk drive. how can i change bios srtup?
Here is what you need to do to install XP on your laptop that came with Vista or Win 7.
If your hard drive is SATA (pretty much standard these days) you will need to search the manufacturer's site for a floppy disk SATA driver install package.* You will need a USB floppy drive for installing XP.
* Copy the SATA drivers (should be denoted as "F6 drivers" or similar) to a blank disk.
* Have the USB drive connected. It should automatically map as A:\.
* Go into BIOS and find a setting for ACPI Compatible and set on.
* Now install XP normally from the CDROM, and when it says "press F6 to install third-party drivers", press F6 and follow the options to get the SATA drivers from the disk.
* Complete setup as normal.
or
You can check the following link for more detailed info.
Thanks !!
Please rate the solution if it helps you.
Nov 23, 2010 | HP Compaq nc6220 Notebook
Intalling window xp over vista
XP does not include SATA drivers in the distribution. You need to get the SATA drivers for your particular model from HP's website and watch for the prompt to hit F6 when prompted to install SATA or RAID drivers.
The trick is that the mechanism to add these drivers at this point assumes that you have a floppy drive which is rare these days. There are a number of work-arounds for this, here is one:
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Aug 18, 2009 | Compaq Presario Notebook
I am tring to install win XP with sata drive and
Make sure it is listed in your system CMOS before starting the XP install. Make sure cables are correct, and the drives are not turned off in CMOS. Some setup will allow you to set the drive types to AUTO, so you can also try that.
Jun 30, 2009 | MSI 661FM3-V Motherboard
I con not setup win xp on the hard without floppy disk
Start your computer. Enter BIOS SETUP. Select "Boot Order". Configure to make the CD/DVD the *FIRST* boot-device. Put the Windows CD/DVD into the drive. Save/Exit from BIOS SETUP. Your computer will restart, and will "boot" from the Windows disk in CD/DVD drive.
Jun 08, 2009 | ASUS P4S800D-X Motherboard
Sata hdd cant install
hi
go to your bios setup
go to advanced option your sata hdd is disable enable it.
if it is enable then boot your sys with bootable disk
go to dos mode.
type FDISK
Y
4 TO DISPLAY INFO OYUR PARTITION.
IF YOUR PARTITION ARE NON DOSE DELETE IT
THEN RESTART YOUR SYS.
U CAN INSTALL XP NOW.
Mar 25, 2008 | Mercury KVM800M Motherboard
Intel Motherboard Logo
135 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
