Question about Siemens WFXD8400UC Front Load Washer
Siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If it won't flash any error code then the issue is with its Electronic control going bad and should be replaced. However, before replacing the panel check the door switch as if that's bad you'll have to replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 28, 2010
2 Suggested Answers
SOURCE: siemens serie iq 1430 start problems\r\nThe
siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
Siemens washing machine display F21 flashing. Fault is not resetting after power off.vario perfect iq 300.
Try this, unplug it and press and hold down the power button for 10 seconds and then plug it back in and see if the error code has cleared.
Aug 28, 2016 | Siemens Washing Machines
My siemens IQ washing machine model 1434 says "Tap Closed" on the digital display and wont work. My spare washing machine works so there is nothing wrong with the taps in the plumbing. Is this a com
the water intake solenoid valve has failed
or the control board is not able to open it
i would check there it voltage at the solenoid 2 pins {mains here 120 or 240 v}
this opens the water in
if you have no voltage at the valve
then the controller board has an issue
or the door isnt detected as closed
some machines do a self test so
is there an actual error code
tap closed is no inlet
all valves have a small filter on the inlet side
use a pair a flat nose plyers too pull the filter cone out
and give it a clean
other than this the valve has failed or is seized
Aug 30, 2014 | Siemens Washing Machines
The washing machine turn on but don't start
It could be a poor connection at your motor. Check the white plug which plugs into your motor. Take off the cap, you'll find one of the wires is burnt. Cut the wire back to behind the fault and refit.
Dec 08, 2013 | Washing Machines
I HAVE A SIEMENS SERIE IQ 1433 AND I CANT DEACTIVATE THE CHILD LOCK AFTER WASHING MY CLOTHES
Try this procedure to deactivate child lock on your washing machine:--- On Siemens washing machine to deactivate child lock set program to Easy-Care and hold option down arrow for 5 seconds. ---------------- set mode to rinse & then hold option down arrow for 5 seconds (toggles on/off). ---------------- -Set the mode to cottons, (dial clockwise once)
-Press and hold the option down touch button for 5 seconds or until you see the magic message 'Child lock released'.
----------- Check out.This will help.Thanks. Helpmech.
Jan 19, 2011 | Siemens WIQ1433 Front Load Washer
Sep 18, 2010 | Siemens WFXD8400UC Front Load Washer
Siemens iq 1430
I'm unable to remove the child lock on my seimens IQ 1430 washing machine
Sep 09, 2010 | Washing Machines
Dryer does not start after selecting a program
How old is the unit?
This was my experience...
http://www.fixya.com/ThreadAsker.aspx?thid=1179929#
Feb 09, 2010 | Siemens Dryers
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Siemens WFXD8400UC Front Load Washer Logo
452 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
