Question about BenQ FP91G+ 19" LCD Monitor
When i turn it on it says no signal? Does this
When i turn it on it says no signal? Does this mean its dead like i was told? Could it be something else? Thanku
  • Rommel Cana
    Rommel Cana Sep 28, 2010
    check first your computer if it is booting up, or try other monitor to verify , if it is really your monitor
  • 4,234 Answers
The no signal can either be "no signal" or a signal that is out of range. Check first by connecting the monitor to a known good video output (ie another computer). If that works, then the problem is with the source and not the monitor. Sometimes the source computer has its resolution set too high and the monitor will not be able to process that resolution. The no signal message will occur then as well.
Dan
Posted on Sep 28, 2010
Left signals not working. Flashers work
Check and see if you have separate fuses for left and right. If not that would only leave the turn signal switch is bad.
Feb 20, 2016 | 2004 Jeep Grand Cherokee
The car hesitates when accelerating, usually at around 1500RPMs. It seems ok otherwise, like there is a bad spot in the TPS. I was told this has a different set up that TPS. Any ideas?
I cannot be certain, but from what I can gather, your car has an electrical throttle system rather than a cable to the throttle body. That means you have an electrical device at the gas pedal that is similar to the TPS sending an electrical signal to the ECM, which in turn sends a signal to the throttle body to control the throttle plate. Chances are the dead spot may well be in the gas pedal sending unit. They have had issues with some vehicles since they are down near the floor with dirt and grit contaminating the sending units.
Feb 04, 2016 | 2008 Saturn VUE
How to repair left turn signal and brake light, changed bulb, No voltage in fuse box, fuse is ok
No voltage. Replace the turn signal switch. All the exterior lights run threw it. Except the rear high brake light.
Apr 08, 2015 | 2013 Jeep Wrangler
I charged my phoe an its heats then someone told me the battery is dead,i bought a new battery but it still does the same thing
If you still can't charger it, it means there is something wrong with the charging circuit.
Need help? you can contact us here: ezbuy batteries and chargers
May 15, 2014 | Cell Phones
Left turn light stays lit though battery is dead
have a load test done on the battery as there may be a dead cell Have an auto electrician check the reason for the indicator light staying on
Feb 27, 2014 | Mazda Cars & Trucks
1999 Lincoln Continental was in for repairs and now my turn signals and break lights dont work. Im being told it's something to do with the anti theft system because the battery was unhooked. The...
I suspect there is a problem with the turn signal/ hazard switch. turn the turn signal on left or right, if it doesn't flash, grip the hazard button and gently wiggle it around, if the signals start flashing, replace the turn signal switch. The Brake lights are wired through the turn signal switch, if the 3rd brake light works, the brake switch is OK. I don't think it has anything to do with the anti theft system (at this time)
Sep 21, 2011 | 1999 Lincoln Continental
Dead spot, no signal
Easiest fix is try another location in the house, unless the dead spot means no wireless signal any where. Then make sure the wireless is turned on in the router. Problem is really vague.
Nov 30, 2010 | 2wire (1000-400108-001) Router
I locked my doors this morning and a few hours later someone told me my car was clicking, i unlocked which wouldnt work with remote so i used key tried to start and nothing no power to anything use turn...
The battery is dead. I don't know why it dies so quickly. I have the same problem. If my car sits for two days without driving it then it dies. My car was on the side of the road for three days and it wouldn't start. Something is draining the battery.
Apr 26, 2010 | 1998 Oldsmobile Intrigue
Loud High pitched noise
That's interference from some microwave transmitter on a tower. The interfering signal is covered up by a strong satellite signal. When you lose the strong satellite signal, then the ground-based microwave signal takes over, which your receiver trys to play back. (It's an unintelligible encrypted signal)
Is there a tower with a big "drum" pointing in your antenna's general direction? Are there "stunned" (or dead) birds in your parking lot from time-to-time? Your antenna must be moved to a different part of the roof, or even relocate it to the side of the building where you have direct line-of-signal to the satellite.
Hope this helps!
Sep 19, 2009 | Audio Players & Recorders
BenQ FP91G+ 19" LCD Monitor Logo
783 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
