Question about Toshiba Computers & Internet
Laptop battery issue - Toshiba Computers & Internet
  • Pankaj Sep 28, 2010
    Please calrify what is the exact Problem!!
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 28, 2010
Hi Friend My Laptop Lenovo G580,last week m y battery is not charge and Power light and Battery light frequently blinking.Can plz suggest.I am so Afraid about this issue.battery is still good
Price on battery $33-90. Will he laptop work OK RUNNING ON THE BATTERY ?? u can buy a new charger on E/BAY COST AU ,$18.05... Cheer's
Jun 28, 2016 | Lenovo G580 Laptop
No power to my hp mini
I also have an HP and also had the same issue with a no power, go and remove the battery from the Laptop and try to connect the AC Adapter again and try to power on the Laptop if the Machine turns ON without the Battery in it then the issue can be 2 things it is either the battery is dead or the battery bay on your laptop need to be checked for repairs on the issue...
and the only people to got to best would be HP, also if you can try a known good battery that works and connect it to your Laptop to check if it will turn ON that may also work and if the Laptop does turn ON using a known good Battery then the issue is just the battery and nothing related to the battery bay on the lsptop, which makes thing easier since a new battery is easier to buy than having your laptop sent back to the manufacturer for repairs.
I hope that the issue is just the Battery.
Try a known good battery first before having someone open your Laptop :)
have a Good Day .
Oct 22, 2012 | HP Mini 1000 Netbook
My acer aspire 5515 the battery died last night and it wont pick up charge it wont even come on to seek it what can I do?
the laptop will work with just adaptor plugged in and the battery removed
however your issue could be an issue the adaptor causing the battery to discharge as there is no charge getting to the laptops battery or it could be an internal issue with the motherboard
try just the adaptor if that works then replace the battery
hoping this will work
THNX
Jan 05, 2011 | Acer Aspire 5000 Notebook
Everytime i try to use it turns to a black screen. How can i fix this?
1. Disconnect the ac adapter and remove the battery from the laptop.
2. press and hold the power button for 30 seconds
3. replace the battery and connect the ac adapter.
4. turn on the laptop.
this should resolve the issue.
if the issue persists then remove and replace the memory modules of the laptop and check for the issue
if the issue persists, then it is a hardware issue and your laptop needs to be serviced.
Jun 17, 2010 | Computers & Internet
Sony vaio won't charge new battery
i believe it is a charger issue not a battery issue replace your charger
Apr 08, 2010 | Sony VAIO VGN-CR410E/W Laptop
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Battery won't charge
It can be a defective battery, return it and get another one if you can, if that not the problem then its a laptop internal issue. If its a laptop issue take it to a mom and pop computer shop to pin point problem. Can be several issues if its the laptop. Have to look at it .
Aug 15, 2009 | Toshiba Satellite M35X-S149 Notebook
Doesnt charge
This could most probably be a battery issue. To check if it is really a battery issue, remove the battery and plug in the AC adapter. If the computer powers up, then this is definitely a battery issue and you'll need to purchase a new battery or call your computer's manufacturer and ask them if they have battery exchange programs.
Sep 17, 2008 | Acer Aspire 3050-1733 Notebook
Power or Battery??
try to take out the battery and plug it into the wall and turn it on to see what happens.
if it powers on its a probably a battery issue,
if it still doesnt
try it the other way around put in the battery and unplug it turn it on if it powers on its a problem with your cord
May 30, 2008 | Toshiba Satellite P105-S6104 Notebook
Computers & Internet Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
