Question about Home
The water is leaking from the wall of the 1st floor of my home, i suspect that this is happening from the toilet above it. but the water is leaking on only one side of the wall. give me the solutions for this problem
  • 2,100 Answers
Does it leak all the time or just when you flush it? It could be just the wax gasket has given out and is letting water by when it flushes. You can pull the toilet real easy to check. A new wax ring cost $2. If it is a pipe, then, you will have to bust open the wall and make the repair, and patch it back up. But don't put it off, the water will do more damage the longer you wait, it also grows mold and attracts termites. They love wet wood. Hope this helps.
Posted on Sep 28, 2010
I have a water leak in bathroom not from toilet. How can I check the pluming in that area?
Your idea may correct. But majority of cases it is floor/ground seepage....leaks through your tiles or waterproofing layers and so on..To chk...keep on pouring water to the ground of the bathroom, near wetting areas, and close the freshwater line leading to the bathroom taps
May 18, 2016 | 2006 Tahoe Transport
It leaks water on the floor around the base when flushed. Only leaks when flushed Godfrey
The wax ring seal on the bottom of the toilet has let go. It isn't tough to fix. Two nuts hold the toilet down. Shut the water line in back off, take the 2 nuts off, and move the toilet aside. You;ll need a new wax ring, so you'll have to scrape the old one off. It will show you how to set it in and set the seat on. It only looks tough, but it's actually simple. Good luck!
Mar 18, 2015 | Home
Water leaking onto the floor after flushing
check around where the tank meets the bowl and see if water appears when you flush and if so you need a new tank gasket. If it's coming from where the toilet meets the floor you will have to change the wax seal underneath. That happens when the toilet rocks and ruins the wax gasket.
Oct 08, 2014 | Home
Leaking from water tank
Is the water leaking from the tank onto the floor or at the water valve located where it comes in from the wall.
Feb 08, 2013 | Toto Toilet - Elongated Bowl, Dual Max -...
I have a new Kohler Toilet that has a different flushing system from other Toilets. It's about 1 year old now and I'm noticing a Drip noise on the 1st floor under this Toilet. It looks to me like the water...
Basically, if water is flowing out of the overflow tube, then water must be coming in...I would suggest that you check the intake valve, it is probably not shutting off completely when the float comes up to the prescribed level,and continues to leak some water into the tank. That is what the overflow tube is there for.
Mar 17, 2011 | Kohler Toilet - One Piece with Ingenium...
Do you recommend 'sealing' the bottom of a toilet with silicone?
no, it will yellow if p gets on it. Use a flexible acrylic caulk, but not an acrylic adhesive because it will make it hard to lift the toilet in the future without damaging the floor.
Sep 24, 2010 | Kohler Home
Mystery self-fixing toilet bowl leak
Check hose going to toilet maybe small leak-check that your toilet is tight to floor-also check tank make sure all fittings are tight,not much can go wrong pretty simple system!!Good Luck!!!
Jun 24, 2009 | Home
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
