Question about Fuji FinePix F810 Digital Camera
The F810 keeps shutting down and will not stay on. Battery seems to charge!
Tip
How to get the most out of your iPod battery
When you first get the iPod make sure to fully charge it. Then only charge the iPod when it is so dead that it will not stay on long enough to play anything. Then allow the battery to charge until a screen appears saying fully charged. This may seem redundant but it ensures the batteries capacity will be maximized for as long as possible. There are only about 1800 charge cycles in an iPods battery life. This may seem like a lot of charging ability but when you wish to keep the iPod for more than a year and a half it becomes more realistic that it is not.
Above all else, never ever remove the iPod from the computer without ejecting it first.
If you are for some reason unable to properly eject the iPod, first shut down your computer before removing the iPod.
on Jan 14, 2010 | Audio Players & Recorders
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
Why doesn't my 25 h.p. briggs & stratton keep the starting battery charged?
Make sure it isn't a bad battery..try starting and then disconnect the neg cable it should stay running if the engines charging system is ok..if it shuts down the system will need checked out.good luck?
Jun 29, 2014 | Briggs & Stratton Garden
My battery light comes on first time out this season kept it charged through winter 2011 deluxe after i shut bike down battery light stays on and slowly fades out bike seems well charged open wire?
Not an open wire. What is the charge on the battery. Sounds like maybe the voltage regulator is defective and the battery is draining back through it possibly. Disconnect it or pull the main fuse and see what happens then.
May 12, 2014 | Harley Davidson FLSTN- FLSTNI Softail...
WHY IS TI THAT THE BATTERY KEEPS LOOSING ITS CHARGE AND IT DOES NOT HOLD CHARGE?
put a volt meter on the battery,,,,it should read 12.6 before starting..and 14.25,,when running.....and 13.75 when you shut it down,,,,,if not its not charging...you need a good battery to turn on the regulator/alternator/stator/rotor to charge the battery,if its not 12.6 your dead in the water
May 05, 2013 | 2007 Vento Phantom R4i
My john deere la125 seems to be drawing power wile shut down, it take a week for the batter to go dead, i've pulled the batterer and it stays charged up , I've checked the charging unit and i
What you do is power off the machine, and disconnect the negative battery cable. Put a test light or volt meter between the battery negative terminal and the disconnected negative battery cable.
You will likely have a light or voltage reading...Then you start disconnecting things....I suggest the alternator.
When you have the correct component disconnected and the test light or volt meter shows no current.
If this component is the alternator, they have diode sets inside (or somewhere else in the charging circuit) Typically one diode fails and this causes the draw that you describe. The system often still charges, but at a slightly lower capacity with the failed diode.
Doc
Nov 23, 2012 | Garden
Netbook will only stay on for a few seconds
Take the battery out and see if it will boot up. be sure to insert the power plug.I suspect that your battery is not charging up and the level is so low that the machine stays on for just a few seconds and shuts down to conserve the battery to keep itfrom going flat. Your charging circuit may not be working correctly, allowing your battery to be fully charged or your battery may be defective and cannot be charged up.
Dec 27, 2010 | Sylvania G-Netbook
Smart pro keeps shutting down
it seems that the internal battery is bad, even if it is new but if it stays in the shopping store for long time it may become bad and not charge.
Dec 09, 2008 | Tripp Lite Smart Pro UPS System
Keeps shutting down.
The solution is found! There's no need to format your HDD
So.
- Unplug the battery;
- Press and hold the reset button for 20-25 sec;
- Put the battery back to it's place;
- Charge your device (when you plug the cable in, it turns on (note that a blinking lightning icon appears on the charging indicator), then it turns off with it's "shutting down" message, dont pay attention on this, just let it charge for about 10-15 minutes (note that the CHG bulb won't be lit));
- Turn on your device. The CHG bulb is lit, Archos doesn't shut down
- Enjoy
Jan 08, 2008 | Archos 504 500870 Digital Media Player
Fuji FinePix F810 Digital Camera Logo
32 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
