Vista hi , i have a dual boot vista and xp ,not happy with vista, how can i remove vista ,and also retaining xp at the same time,also , is it possible to resize the hdd back to its original size ,ie before it was just xp on the whole drive thanks in advance regards paul welter
    Problem Solver:
  • 5 Answers
I'm taking it you have a partition on your HDD right? well if the case is this than simply "delete" the contents on the partition (this is called cleaning up) so it was how you bought it, clear. next just oh i don't know how you would say it. you have to compbine the partitions. i guess you can just delete the partition so your left with drive C:
Posted on May 29, 2008
How to uninstall Windows Vista
You must use a full retail or OEM version of XP (not the cd from your old computer) this makes life really easy and can usually be downloaded from the web.
You must also have a genuine XP key, which has not been used on another system.
Next you should know or find out the specifications of your system, to do this goto Manufactures website.
The most important step is to find out if your hardisk is using SATA interface (if so you will require the SATA XP drivers and a floppy disk, as this is the only way that XP can install these drivers.)
Install XP via cd rom by booting cdrom at system start (if you cannot do this then you must access your system bios at first boot by pressing F2 or Del keys(or whatever key your system uses) and change the boot option to cdrom as first drive.
If your system uses SATA press F6 when XP prompts “press F6 to install other” at very beginng of XP install and install sata drivers from floppy.
Jun 12, 2009 | Microsoft Windows Vista Home Premium SP1...
About driver
I think it would make the most sense to reinstall Vista with a functional Vista disc (should be DVD). Alternatively you can check HP's Website for XP drivers which may not exist if it came with Vista. You could also reinstall Ubuntu. If you want a dual boot with Ubuntu you should install Windows first and Ubuntu will provide that option when setting it up and allow you to resize the Windows partition and create separate partitions for Ubuntu.
Dec 30, 2008 | Compaq Audio card Sound Card
Dual Boot Ubuntu
1st, install windows or if you have already its good .
Then, download Linux distribution that suits You better
Download It and burn into a CD or DVD with ISO file you can use Magic ISO or other manufacturer
then Go to BIOS setup and set 1st priority is the CD or DVD drive and save and exit
and install follow the instruction of linux.
also if you chose capacity of windows or linux is to little dont worry you can make install a partition magic and resize what you like....
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Sep 07, 2008 | Canonical Ltd. Ubuntu
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I formated D: drive than also first time starting two option xp or vista than I want vista's option remove...
Boot to Vista. Then
  • right-click "my computer", then "properties".
  • click the "Advanced" section (Vista: on the left side bar).
  • In the section that says "Startup and Recovery", click "settings".
  • Under "Default operating system", choose "Windows Vista".
  • REMOVE the checks next to "Time to display list of..." and "Time to display recovery options..."
  • click ok to everything.
Now you will need to remove Windows XP.
IMPORTANT: for the next step make sure you boot to Windows Vista. Otherwise you could corrupt your computer.
  • Go to "Start", "Control Panel"
  • Open "Administrative Tools"
  • next, open "Computer Management".
  • On the left, there's a side bar. Under "Storage", click "Disk Management".
  • Now, If windows XP is on drive C:\,
    right click C:\ and select "Format"
  • Click "OK".
hope this helps.
Aug 04, 2008 | Microsoft Windows XP Professional
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I D: is format than also first time starting two option xp or vista than I want vista's option remove please...
hi,
To remove starting option boot with XP and go to run type cmd. then go to c: prompt. type edit boot.ini and remove the line that refers the vista. and save it.
Aug 03, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Windows XP
It should have come with the 32. For dual boot on this machine, go in and set up XP on the same partition as Vista. When the machine starts up it will go to a screen that allows you to choose which op system you want. You shouldn't, but if you run into conflicts you will need to create a separate partition for the two op systems.
Jun 18, 2008 | HP Computers & Internet
Dual boot
Hi abc_19 ,
Before I answer your question , let me tell you that you need to back up your data.Also, make sure that your system hardware supports Vista.
You also need to have genuine windows XP and windows Vista disks handy with you.
1. Partition your hard drive. In Windows XP, using the $50 PartitionMagic or (according to one of our readers) the free GParted Live CD, create a new "primary" partition to install Vista on. Make it at least 20 gigabytes in size.
2. Install Vista on the new partition. Pop in the Vista CD and point it to your newly-created partition as the installation destination. Installation will restart your machine at various points.
3. Choose your operating system on boot. Once Vista is installed on your newly-created partition, on boot up, you'll get a choice to start XP or Vista. The default is Vista. However, this can be changed using Vista's boot manager.
When you're up and running with Windows Vista, be sure to check our our Vista upgrade power tips.
The original article appears below for posterity, and it's still got relevant screenshots and other info for those of you looking to dual-boot XP and Vista.
http://www.youtube.com/watch?v=nNZi5fLpqus
(WATCH THE ABOVE VIDEO FOR MORE HELP)
Cheers :-)
Jun 05, 2008 | Dell Latitude D600 Notebook
Cannot run Fujifilm Software for FinePix with Windows Vista
1) If you right-click on the executable file, can you use the
"Compatibility" TAB to run it as an XP program?
2) Many XP device drivers will fail to install or execute properly
under windows VISTA, and I suspect it is the camera's USB
or Fire-wire (IEEE-1394) based device driver that is causing
the problem, not the main application.
Unfortunately there is NO easy solution for this,
except to get an upgraded software package (for Vista)
from the Camera Manufacturer.
3) There are also two possible work-around(s), but both require
some knowledge and software installation:
DUAL-BOOT
Install both Windows XP and Windows Vista on your
computer using two separate hard-drive partitions, and
a boot manager.
A partitioning tool like "Norton Partition Magic", formerly
"Power Quest" or "Acronis Tools" can be used to partition
the hard-drive non-distructively (your data is preserved):
a) Resize (shrink) the existing Windows partition.
b) Create a new partition for Windows XP (about 10 Gigs)
c) Install Windows XP-Pro onto the new partition,
d) Add both the XP and Vista partitions to the BOOT.INI
file on the boot drive.
Both windows XP and Vista do have multi-boot capability,
but the Windows XP boot manager may not recognize Vista,
in which case you may have to re-install or re-pair the Vista
installation. The Vista boot manager will recognize WinXP.
Running VISTA is generally a bad idea, because it is obscenely
slow and inefficient compared to XP, and because it is infected
Microsof't draconian and arrogant copy protection schemes,
known as DRM = Digital Rights Management.
Towards this end, Vista also insists that all installed multi-media
devices must be "Recording Industry" compliant and approved,
to make music and movie piracy more difficult. Many media
copying programs and CD-rippers will also refuse to run,
by design.
All this "Added Technology" is stealing your money, your
computer resources, your performance, and your right to
backup your media, at your expense, for the benefit of
the movie industry Mafia.
Use Vista only when you have to, boot to Windows XP for
most of your applications.
VIRTUAL MACHINE
Both Microsoft and VM-ware (as well as others) make
a software product called a Virtual-PC, which allows you
to emulate multiple operating systems under windows,
including older windows, MAC and Linux.
VMWare is by far the best, the most reliable and the
most flexible, at about $200 US.
Martin
May 07, 2008 | Computers & Internet
Adding xp on same computer with vista
Are you comfortable with running GPartEd, Gnome Partition Editor. There is a linux bootable cd for gparted, from there you chang partition size of the ntfs.
full instructions are on this site.
http://apcmag.com/5023/dual_booting_xp_with_vista
Make sure before you do this that you have defragged XP.
Mar 08, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
