Question about HP Pavilion a1410n (ER890AA) PC Desktop
Noise computer is 10yrs has a grinding sound. also sometimes will when i click it won"t go site. is slow and i have dsl. freezes, crashed./
  • szy387 May 24, 2008
    is it time to get new computer
  • 4 Answers
Responding to the grinding sound...my desktop starting having a grinding sound after 3 years and it turned out to be the fans used for cooling the unit. If the fans are going bad, replace them immediately. If they should fail, the system can overheat and the system can act oddly or crash permanently. Fans don't cost much usually, labor does. It's not hard to replace a fan.
Please note that this response does not address the other symptoms mentioned by szy387.
Posted on Sep 10, 2008
    Sergeant:
    Champion:
  • 359 Answers
Check your power supply a bad power supply can make your computer noisy and also slow it down
Posted on Jun 03, 2008
    Genius:
  • 2,785 Answers
Reload the operating sysytem
Posted on May 24, 2008
Brakes make a whistle noise when applied and sometimes a low grown or grinding when coming to a slow stop or start.
A grinding or rumbling noise can also be symptoms of a wheel bearing or constant velocity joint in a driveshaft. A worn wheel bearing can also cause a 'whistling' sound (as can a worn CV joint).
A grinding noise with brakes is either worn pads causing metal to metal contact on the brake disk/rotor, or the brake backing plate catching on a spinning rotor ... or a loose/missing anti squeal brake shim (they stop the pads from rattling and vibrating).
However, as you say a mechanic has looked at the brakes and can't find anything wrong .. I think I would begin to suspect a wheel bearing or constant velocity joint on the driveshaft (front wheel drive cars).
May 05, 2016 | 2007 Honda Accord Sedan
Grinding wining noise when slowing down cruising at slow speed, not turbo wine and the noise does not change when turning left and right. 2004 2.0 TDI Audi A3
This may sound obvious, but I would have your brakes checked out, just to rule them out. Many shops will do a free brake inspection.
If the noise is coming from the engine, look for a "Check Engine" light. If you see that, then have someone hook up a scanner to check the codes thrown by the car's computer and go from there.
A grinding noise is not something you want to put off or wait to fix.
Oct 25, 2013 | 2007 Audi A3
Noise my 03 xterra makes when I crank it up. One guy said exhaust manifold and another said knock sensor. Just need a second opinion.
Many times a bad starter motor makes noise like clanking, clicking or grinding when crank the engine. Replace the starter. Sometimes, if the starter motor is grinding the gears on the flywheel, the engine will have a metallic grating sound when you first crank it. This type of starter noise is normally indicative of a starter motor that is worn and about to fail. If you do need to replace your starter this site looks like it has cheap prices, free shipping and great reviews http://www.buyautoparts.com/starter.htm
Jul 05, 2013 | Cars & Trucks
Asus EEE netbook freezes while watching video or gaming. It freezes for about 2 minutes then recovers. Suggestions?
Netbooks have very slow processors and graphics cards compared to their laptop and desktop counterparts. You could try and see if their is an update for the video drivers but you might just be screwed. I had an acer netbook and it sometimes had problem with full screen video, it would glitch well watching it.
May 12, 2011 | Computers & Internet
It is running so slow!! It pauses and screen fades to light color! I cannont do my work!! Help!!
This could be for a couple of reasons, 1) you have a virus causing your laptop to crash or 2) you have a faulty Hard Drive.
Try downloading and running Hit Man Pro (an anti-virus software) that should clean up any viruses you have, download it here:
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2239_4-10895604&ontId=2239_4&spi=50fbf8256fc023103cca4ba60e4a71b1&lop=link&tag=tdw_dltext<ype=dl_dlnow&pid=11754089&mfgId=6302975&merId=6302975&pguid=CyZLHAoOYI4AAAxmYBAAAABD&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-2239_4-10895604.html%3Fspi%3D50fbf8256fc023103cca4ba60e4a71b1
Run the scan and remove and viruses it finds and reboot the computer...see if this makes any difference, if not, try booting up in the recovery partition and repairing Windows.
Let me know if this helps
Mar 21, 2011 | HP Pavilion dv2310us Notebook
Im not getting *** videos
1.Watch videos at off peak times, if possible 2.Do not run other programs while watching videos. They slow down computer ingeneral by making use of memory. 3.Add RAM on your computer. More RAM will make easy execution of heavy programson your system. 4.Get better and speedy internet connection. Talk to your ISP in this regard. 5.Regularly clean windows registry. Windows registry is vital place that storesinformation for important computing functions. A congested or corrupted windowsregistry makes computer slow that causes YouTube like freezes. For this, getthe best registry cleaner RegInOut cleaner and optimizer. Use it once in afortnight for fast computing to avoid YouTube freezes and system slow down.
Feb 25, 2011 | YouTube Videos
Xbox 360 is making grinding noises
H there,
I have made a tutorial for all those people having problems with their discs, such as;
•Dirty Disc Errors
•Games crashing half way through , due to reading problems
•Discs sometimes loading, and sometimes not being recognised
•the classic "OPEN TRAY" problem
•and also glitching FMV or slow loading games (some games are just slow, its normal so be patient)
Please remember to test the disc on another console to ensure you have burnt it correctly. This is so you dont go and adjust the pot when its actually ok.
Download from the link below..
http://rapidshare.de/files/22184766/XBOX_3...y_Moda.pdf.html
X-Scene mirror:
http://dwl.xbox-scene.com/tutorial/XBOX_36...1.0_by_Moda.pdf
Hope it works.
Regards,
Anirban Mazumdar
May 22, 2010 | Microsoft Xbox Console
Every time i turn on the computer it seems to crash. Sometimes it takes an hour before it crashes and sometimes i don't even get to login before it crashes. My definition of crash would be where the...
There are usually many possible problems.
Sounds like you have low resources.
Not enough RAM
Or your processor is having problems.
Depending on your OS, and or programs you are using.
Freezing is a sign of a need to upgrade.
Your pc is likely slow.
If this is not the issue, then you should provide more info.
Mar 16, 2010 | HP Compaq Presario SR5350F Desktop PC...
Not loading game
the reason it makes the "grinding" noise is because the motor that moves the lens to read the disk is dieing, this generally happens when you have played your ps2 for a long time, this only happens to older consoles.
Nov 01, 2007 | Sony PlayStation 2 (PS2) Console
HP Pavilion a1410n (ER890AA) PC Desktop Logo
234 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
