Question about MSI 945P Neo3-F (7236-040(945P NEO3-F)) Motherboard
Msi 945gcm7 not starting, no beeps, no video. ram tests ok. fan on cpu &extra fan working ok. Monitor& cable working ok.
  • 54 Answers
SOURCE: monitor
Reset the Cmos battery,check the RAM,check the smps or check the motherboard ground, I think you problem will solve.
Posted on Feb 16, 2008
  • 10 Answers
SOURCE: MSI P6NGM Issues
I would put the old ram back in, and then reset the bios by following the instructions in the motherboard manual. (usually with putting a jumper on some pins)
Harris
Posted on May 01, 2008
  • 987 Answers
SOURCE: drivers cd for xp of msi motheroard 945GCM7-l lost.
http://asia.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=1416
here u can download drivers...
Posted on May 10, 2009
  • 77 Answers
SOURCE: msi 945gcm7 lan driver free
here u can find all drivers of msi 945gcm7 all versions.
http://exehub.com/msi-945gcm7-f-msi-ms-7507-ver-1-4motherboard-drivers/
Posted on Feb 14, 2011
Ms-7108v1
1 long beep dram refresh failed
remove everything
JUST INSTALL MIN. RAM, CPU, CPU FAN, POWER CONNECTION, THAN TURN MACHINE ON, IF OK, CONTINUE INSTALLING I DEVICE AT A TIME UNIT YOU IN COUNTER AN ERROR THAN YOU WILL KNOW WHAT IS WRONG.
now a few things to check video card, ram, cpu fan plugged in right area,
you mite want to reset the cmos, by jumping the connectors for few seconds, then turn machine off, remove jumper, than just install cpu and fan, ram, speaker, keyboard, turn on if ok add video card, turn on , if ok, than install hhd, 1 at a time, than restart system if boots ok than move to next device, keep doing this until you installed everything you want or have to have in the system
Jun 07, 2014 | MSI 848p-neo2-v-848p Neo2-v Intel 848p...
Ram ok ,power sap ok ,lcd ok, cpu fan raning but no dimply, msi 7312 ver 1.0 plzz help
Hi, you can download a manual and drivers here:
http://www.msi.com/product/mb/K9MM-V.html#/?div=Manual
You can add a AGP screen card if the onboard graphics
does not work.
Check the connections for the screen cable.
Try even with another monitor.
Sep 08, 2011 | MSI K9MM-V Motherboard
There is no beep or display....cpu fan is ruining but no display Ram is ok.how can i solve this problem?
IF YOU HAVE A VIDEO CARD TRY TO USE THE VIDEO CARD...
BUT FIRST IF YOU HAVE EXTRA MONITOR TRY THE OTHER ONE...
BUT I THINK IT WILL SOLVE THE PROBLEM IN VIDEO CARD...
Oct 18, 2010 | MSI 945GCM5 Motherboard
Sony pcv rx550 beep codes?
Hi , here are the codes. listen closely.
Beeps
Error Message
Description
1 long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly. Repeating (endless loop) Memory error Check for improperly seated or missing memory. 1 long, 3 short No video card or bad video RAM Reseat or replace the video card. Repeating High/Low
CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat.
Check the CPU fan or BIOS settings for proper fan speed.
Phoenix BIOS beep codes
Beeps Error Message Description 1-1-2 CPU test failure The CPU is faulty. Replace the CPU. Low 1-1-2 System board select failure Replace the motherboard. 1-1-3 CMOS read/write error The real time clock CMOS is faulty. Replace the CMOS if possible. 2-x-x RAM failure Replace the RAM module if possible. 3-2-4 Keyboard controller failure The keyboard controller has failed. Replace the IC if possible. 3-3-1 CMOS RAM power bad Replace the CMOS battery or CMOS RAM if possible. 3-3-2 CMOS configuration error The CMOS configuration has failed. Restore the configuration or replace the battery if possible. 3-3-4 Video memory failure There is a problem with the video memory. Replace the video adapter if possible. 4-3-1 RAM test failure System RAM addressing circuitry is faulty. Replace the motherboard.
Good Luck
Mark
Sep 17, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
My PC is on,but i=I do not see nothing in my monitor,already changed the video card and still don,t see nada. I notice a ambar smmall light in the motherboard.
the driver is not working- it didn't load on startup- or- the monitor isn't working at all- disconnect it and hook it up to another computer...to test
Aug 06, 2009 | EliteGroup 915G-M Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Ga gigabyte mainboard trouble
Just because it doesnt beep doesnt mean the vid is not gone
place board on a non metal surface hooked to
monitor
keyboard
mouse
powersupply UNPLUGGED RIGHT NOW
cpu with heatsink and fan attached
ram
plug power supply in (will not shock you just dont lick it ok)
if board does not come on take a small flat head screw driver look at where the power wire would slide on cross those two pins should come on. again will not shock you.
still no video try pci (most basic video mobos support) card
still no video could be cpu I have had several of these be bad caouse no video also
try anouther cpu same setup
still no vid mobo shot sorry
Oct 24, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
No Video
Its easy to test your MB and CPU.
Just remove all components from *********** board, like CD-ROM, DVD disk, HDD, FDD or any PCI or USB component.
Add a speaker to *********** board.
Add CPU, and without RAM.
Now switch on, there must be along beep for RAM not found, if you don't get any beep it means your MB or CPU is faulty.
In other case if you got the long beep, then switch off and add your RAM to MB and switch on again. Now you will get an ok beep. It means every thing is ok.
Now attach your Keyboard and monitor and listen if you get the ok beep or not and also see the monitor there must be light on your screen and message to insert bootable disk.
If every thing is passed ok, then add your HDD and boot.
I think you can do the rest..
Thanks
Iqbal
Mar 10, 2008 | MSI K9VGM-V Motherboard
Monitor
Feb 16, 2008 | Computers & Internet
MSI 945P Neo3-F (7236-040(945P NEO3-F)) Motherboard Logo
350 people viewed this question
Top MSI Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Terry Hair
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
