Question about Dishwashers
Water wont come into the machine - Dishwashers
  • 17,130 Answers
The inlet valve is not triggered- if so the program controller is faulty.
If voltage is present and the valve is not working then it can be faulty , remove clean or replace. check the inlet filter for dirt clogging the flow.
Posted on Sep 28, 2010
Water wont go into the machine but the wash light comes on here a clink but dosent fill with water an start cycle help plz
IF YOU ARE SURE THE WATER SUPPLY IS ON. SHUT OFF WATER TO MACHINE AND REMOVE HOSES ON BACK OF MACHINE AND CK SCREEN ON VALVE THEY CAN BECOME PLUGED AND WILL BLOCK WATER FLOW. PUT THE HOSES IN A BUCKET AND TURN ON JUST TO BE SURE IT IS NOT ANOTHER PLUMBING PROBLEM.
Apr 21, 2014 | Indesit WA 115 Front Load Washer
Washer wont fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
My machine wont drain the water or go to the spin
Drain Vlve command no activated. Or The valve is faulty. Check wiring also.
Mar 28, 2010 | Indesit W 123 Front Load Washer
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Jan 16, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Spin cycle wont work
First : The machine will not spin with water in it. So you will half to start by checking the drain pump.
The water valve is what you will first need to check the cold water.
Jan 07, 2010 | Washing Machines
Help my machine hotpoint ultima wma 60 wont empty water tried 5 times water sitting there had turn machine off
p my machine hotpoint ultima wma 60 wont empty water tried various times water sitting there had turn machine off
Dec 21, 2009 | Hotpoint Washing Machines
Machine hoses wont work when attached to machine
SOUNDS LIKE INLET VALVE IS PLUGGED. THIS SHOULD NEVER BE CLEANED ONLY REPLACED.
Jan 28, 2009 | Washing Machines
Machine wont start
fill it with water start the machine when hot open side valve to let water out if it doesnt do the job remove water tank in the kit of the machine there a little pump put water in the pump in the water hole force water in there with side valve open let me no pierre
Jan 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Dishwashers Logo
Top Dishwashers Experts
